[Other] Coupling solidBodyMotionFunction with sixDOF solver in OpenFOAM-v1812
Old   April 29, 2019, 06:14
Default Coupling solidBodyMotionFunction with sixDOF solver in OpenFOAM-v1812
Ajit Kumar
ajitkumar22 is on a distinguished road
Dear foamers,
OpenFOAM provides a solidBodyMotionFunction class which is convenient for solving flow around moving bodies. However, all the option under this class like, linearMotion, rotatingMotion, etc all seem to solve flow around prescribed motion. I have written a new sixDoFDynamicMotion class, which is a child of solidBodyMotionFunction, which has a private member motion_ of the type sixDoFRigidBodyMotion. The member motion_, is responsible for integrating pressure and shear force around the given patch, and solve for the resulting translation and rotations. The resulting motion is returned as a septernion, through the transform() function. This is tested on two examples. Trajectory of a projectile motion, and a simple pendulum. Source code can be found here.
https://github.com/krajit/sixDoFDynamicMotion
Examples here look ok to me.
Feedbacks are most welcome.
Ajit Kumar,
Dept. of Mathematics,
Shiv Nadar University
ajitkumar22 is offline   Reply With Quote
Old   February 20, 2024, 09:41
onurlands
onurcanpiskin is on a distinguished road
Originally Posted by ajitkumar22 View Post
Dear foamers,
Ajit Kumar,
Create time
--> FOAM Warning :
From void* Foam::dlLibraryTable:penLibrary(const Foam::fileName&, bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 188
Could not load "liboversetAndAMR.so"
liboversetAndAMR.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
Could not load "libsixDoFDynamicMotion.so"
libsixDoFDynamicMotion.so: cannot open shared object file: No such file or directory
Create mesh for time = 0
Selecting dynamicFvMesh dynamicOversetFvMesh
Selecting motion solver: multiSolidBodyMotionSolver
Applying motion to entire mesh
Selecting solid-body motion function sixDoFDynamicMotion
--> FOAM FATAL IO ERROR: (openfoam-2312)
Unknown solidBodyMotionFunction type sixDoFDynamicMotion
Valid solidBodyMotionFunction types :
9(SDA axisRotationMotion drivenLinearMotion linearMotion multiMotion oscillatingLinearMotion oscillatingRotatingMotion rotatingMotion tabulated6DoFMotion)
file: constant/dynamicMeshDict/multiSolidBodyMotionSolverCoeffs/front at line 25.
From static Foam::autoPtr<Foam::solidBodyMotionFunction> Foam::solidBodyMotionFunction::New(const Foam::dictionary&, const Foam::Time&)
in file motionSolvers/displacement/solidBody/solidBodyMotionFunctions/solidBodyMotionFunction/solidBodyMotionFunctionNew.C at line 47.
FOAM exiting
I am getting an error like this, how can I solve this problem?
onurcanpiskin is offline   Reply With Quote
overset, sixdof
Coupling OpenFOAM with Elmer? tutu10 OpenFOAM 2 November 23, 2020 15:48
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
Parallelisation of a new solid solver in OpenFOAM Jibran OpenFOAM Programming & Development 3 August 25, 2017 07:41
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
