[Other] [foamExtend4.0] Help with coupling some equations |
March 27, 2019, 07:53 |
Elwardi Fadeli
Rep Power: 10 |
Hi all,
I've been fiddling with this for quite some time now without a clear success.I really do hope someone could help with this problem of mine. I was solving a coupled problem in a traditional segregated manner: Code:
fvScalarMatrix SwEqn ( porosity*fvm::ddt(Sw) + fvc::div(phiw) ); // phiw = phiP + phiG // Explicit Sw SwEqn.solve(); fvScalarMatrix pEqn ( fvm::laplacian(-Mf, p) + fvc::div(phiG) ); pEqn.solve(); phiP = pEqn.flux(); // Then Update fields with phiP and proceed in time The previous approach sets some constrains on deltaT, so a fully coupled solver is desired. I'm trying to choose between: 1- Solving these equations (where phiw comports an implicit term) with Newton-Raphson classic method, and 2- Solving them using the block coupled library supplied with foam-extend 4.0 I decided to go step-by-step about this and try to solve the "segregated" problem first ( This may not be possible at all, but it may give valuable insight into matrix construction/solving ). Code:
// pSw is a fvBlockMatrix<vector2> blockM(pSw); // Define pEqn and SwEqn as defined previously // Then blockM.insertEquation(0, SwEqn); blockM.insertEquation(1, pEqn); blockM.solve(); // retrieve solution and update BCs |
block-coupling, coupled, foamextend |
Fluid Thermal 2-way System Coupling Dynamic Memory Allocation Error | Tiger23 | CFX | 6 | February 8, 2020 01:25 |
2-Way FSI Coupling Error (Oscillating Plate Tutorial) | EmiS | ANSYS | 2 | June 29, 2018 10:09 |
Difference between stagger/coupling iteration and coupling step | Jiricbeng | CFX | 1 | September 13, 2016 03:37 |
Continuity and Momentum Equations for Turbulent Flows | alibaig1991 | Main CFD Forum | 3 | March 22, 2016 13:51 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
