[waves2Foam] stokes 1st wave propagation in 3d domain diverged after mesh refinement
Old   March 19, 2019, 12:15
Default stokes 1st wave propagation in 3d domain diverged after mesh refinement
Ontario
chliu is on a distinguished road
I am working on stokes 1st wave running up a truncated circular column, following the paper “2016 Applied Ocean Research. Liang Sun. Regular waves onto a truncated circular column: A comparison ofexperiments and simulationsL.” Currently I am using foam-extend4.0 together with waves2Foam package.
In the first step I performed simulation of stokes 1st wave propagation in 2d domain (uniform mesh). Grid convergence test was performed and the simulation result was validated by theoretical solution. Then I tried to run a 3d case(uniform mesh) by an extension in spanwise direction. I succeed in the coarse mesh (1 grid in a wave height) as shown in the attach. However when I try to increase the mesh resolution (uniform mesh) it always burst suddently after many time steps, even though both of the time step and CFL number is very small. My case is shown in the attach, could anyone help me pinpoint my mistake? Many thanks!
system/controlDict
FoamFile
version 2.0;
format ascii;
class dictionary;
object controlDict;
application interFoam;
startFrom latestTime; //startTime;
startTime 0;
stopAt endTime;
endTime 40;
deltaT 0.001;
writeControl adjustableRunTime;
writeInterval 10;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
adjustTimeStep no;
maxCo 0.25;
maxAlphaCo 0.25;
maxDeltaT 0.001;
functions
#includeIfPresent "../waveGaugesNProbes/surfaceElevationAnyName_controlDict";
constant/polyMesh/blockMeshDict
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
//nx 140;
//ny 56; //28;
//nz 56;
nx 280;
ny 56;
nz 112;
xl -152.88;
xr 229.32;
yl -76.44;
yr 38.22;
zl -76.44;
zr 76.44;
vertices
// ( 0 -0.4 0 )
// ( 18 -0.4 0 )
// ( 0 0.2 0 )
// ( 18 0.2 0 )
// ( 0 -0.4 1 )
// ( 18 -0.4 1 )
// ( 0 0.2 1 )
// ( 18 0.2 1 )
($xl $yl $zl)
($xr $yl $zl)
($xl $yr $zl)
($xr $yr $zl)
($xl $yl $zr)
($xr $yl $zr)
($xl $yr $zr)
($xr $yr $zr)
blocks
hex (0 1 3 2 4 5 7 6) ($nx $ny $nz ) simpleGrading (1 1 1)
edges
patches
patch inlet
(0 4 6 2)
wall bottom
(0 1 5 4)
patch outlet
(1 5 7 3)
patch atmosphere
(2 3 7 6)
patch front
(4 5 7 6)
patch back
(0 1 3 2)
mergePatchPairs
waveProperties.input
FoamFile
version 2.0;
format ascii;
class dictionary;
object environmentalProperties;
seaLevel 0.00;
// A list of the relaxation zones in the simulation. The parameters are given
// in <name>Coeffs below.
relaxationNames (inlet outlet);
initializationName outlet;
inletCoeffs
// Wave type to be used at boundary "inlet" and in relaxation zone "inlet"
waveType stokesFirst;
// Ramp time of 2 s
Tsoft 7.0;
// Water depth at the boundary and in the relaxation zone
depth 76.44;
// Wave period
period 7.0;
// Phase shift in the wave
phi 0.000000;
// Wave number vector, k.
direction (1.0 0.0 0.0);
// Wave height
height 2.54;
// Specifications on the relaxation zone shape and relaxation scheme
relaxationZone
relaxationScheme Spatial;
relaxationShape Rectangular;
beachType Empty;
relaxType INLET;
startX (-152.88 0.0 -76.44);
endX (-100.00 0.0 76.44);
orientation (1.0 0.0 0.0);
outletCoeffs
waveType potentialCurrent;
U (0 0 0);
Tsoft 7.0;
relaxationZone
beachType Empty;
relaxType OUTLET;
startX (152.88 0.0 -76.44);
endX (229.32 0.0 76.44);
turbulenceProperties
| \\ / F ield | OpenFOAM Extend Project: Open Source CFD |
| \\ / O peration | Version: 1.6-ext |
| \\ / A nd | Web: www.extend-project.de |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object turbulenceProperties;
simulationType laminar;
transportProperties
| \\ / O peration | Version: 2.1.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
FoamFile
version 2.0;
format ascii;
class dictionary;
object transportProperties;
phase1
transportModel Newtonian;
nu nu [ 0 2 -1 0 0 0 0 ] 1e-06;
rho rho [ 1 -3 0 0 0 0 0 ] 1000;
CrossPowerLawCoeffs
nu0 nu0 [ 0 2 -1 0 0 0 0 ] 1e-06;
nuInf nuInf [ 0 2 -1 0 0 0 0 ] 1e-06;
m m [ 0 0 1 0 0 0 0 ] 1;
n n [ 0 0 0 0 0 0 0 ] 0;
BirdCarreauCoeffs
nu0 nu0 [ 0 2 -1 0 0 0 0 ] 0.0142515;
k k [ 0 0 1 0 0 0 0 ] 99.6;
n n [ 0 0 0 0 0 0 0 ] 0.1003;
phase2
nu nu [ 0 2 -1 0 0 0 0 ] 1.48e-05;
rho rho [ 1 -3 0 0 0 0 0 ] 1;
CrossPowerLawCoeffs
BirdCarreauCoeffs
sigma sigma [ 1 0 -2 0 0 0 0 ] 0.00;
constant/g
FoamFile
version 2.0;
format ascii;
class uniformDimensionedVectorField;
object g;
dimensions [0 1 -2 0 0 0 0];
value ( 0 -9.81 0 );
system/fvSchemes
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
// default CrankNicolson 1.0;
default Euler;
gradSchemes
// default cellLimited fourth 1;
default Gauss linear;
grad(U) Gauss linear;
grad(alpha1) Gauss linear;
divSchemes
// default Gauss linear;
div(rho*phi,U) Gauss limitedLinearV 1;
// div(phi,gamma) Gauss vanLeer;
// div(rho*phi,U) Gauss MUSCL;
div(phi,alpha) Gauss MUSCL;
div(phirb,alpha) Gauss interfaceCompression;
// div(rhoPhi,U) Gauss limitedLinearV 1;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
pd;
pcorr;
gamma;
system/fvSolution
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSolution;
solvers
/* pcorr PCG
preconditioner DIC;
tolerance 1e-10;
relTol 0;
pd PCG
preconditioner DIC;
tolerance 1e-7;
relTol 0.001;
pdFinal PCG
preconditioner DIC;
tolerance 1e-7;
relTol 0;
pcorr GAMG
tolerance 1e-7;
relTol 0.0;
smoother DIC;//GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
cacheAgglomeration true;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
pd GAMG
tolerance 1e-7;
relTol 0.0;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
mergeLevels 1;
pdFinal GAMG
tolerance 1e-8;
relTol 0.0;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
mergeLevels 1;
U PBiCG
preconditioner DILU;
tolerance 1e-09;
relTol 0;
UFinal PBiCG
tolerance 1e-09;
relTol 0;
gamma PBiCG
tolerance 1e-07;
relTol 0;
PISO
cAlpha 1;
PIMPLE
pdRefCell 0;
pdRefValue 0;
momentumPredictor yes;
nOuterCorrectors 1;
nCorrectors 3;
nNonOrthogonalCorrectors 1;
nAlphaCorr 1;
nAlphaSubCycles 1;
0.org/alpha1.org
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object alpha.org;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type waveAlpha;
refValue uniform 0;
refGrad uniform 0;
valueFraction uniform 1;
value uniform 0;
bottom
type zeroGradient;
outlet
type zeroGradient;
atmosphere
type inletOutlet;
inletValue uniform 0;
value uniform 0;
front
type zeroGradient;
back
type zeroGradient;
0.org/U.org
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U.org;
dimensions [0 1 -1 0 0 0 0];
internalField uniform ( 0.0 0.0 0.0);
boundaryField
inlet
type waveVelocity;
refValue uniform ( 0 0 0 );
refGradient uniform ( 0 0 0 );
value uniform ( 0 0 0 );
bottom
type fixedValue;
outlet
// type fixedValue;
// value uniform ( 0 0 0 );
type zeroGradient;
atmosphere
type pressureInletOutletVelocity;
front
type zeroGradient;
back
type zeroGradient;
0.org/pd.org
FoamFile
version 2.0;
format ascii;
location "0";
object pd;
dimensions [1 -1 -2 0 0 0 0];
boundaryField
inlet
type zeroGradient;
bottom
type zeroGradient;
outlet
type zeroGradient;
atmosphere
type totalPressure;
U U;
phi phi;
rho none;
psi none;
gamma 1;
p0 uniform 0;
value uniform 0;
front
type zeroGradient;
back
type zeroGradient;
stokes1-3d.zip
wave-3d-coarse.pdf
chliu is offline   Reply With Quote
3d simulation, diverge after mesh refine, foamextend-4.0, stokes 1st wave, waves2foam
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 09:07
[snappyHexMesh] Disturbance in the mesh after the addition of layers Dorian1504 OpenFOAM Meshing & Mesh Conversion 0 June 13, 2017 03:27
Sudden increase the residual of Maxwell's equations hsezsz CFX 2 October 13, 2016 07:58
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
