[swak4Foam] Swak4FOAM installation for OpenFOAM v1806
Old   March 14, 2019, 12:54
Exclamation Swak4FOAM installation for OpenFOAM v1806
Raheem Nabi
exx110 is on a distinguished road
Dear all,
Currently I am in the middle of compiling an acoustic solver for ultrasound in OpenFOAM v18 on windows and that requires that I additionally compile the swak4Foam library to implement the "groovy BC" boundary condition. The error "wmake: hg: command not found" keeps popping up during this compilation thus the library is not able to compile. On researching this, it appears that "hg:command not found" indicates that I need to download an additional package called "mercurial". Naturally I got hold of and attempted to compile a tar file for mercurial 4.9 but the compilation encounters errors for either two reasons
1) I don't have permission to access my root directory (indicated by " .../.../.. permission denied")
or when I change the installation directory (which in this case I specified to be my home directory)...
2) the following error appears "abort: couldn't generate documentation: docutils module is missing please install python-docutils or see http://docutils.sourceforge.net/"
Naturally I took the step to compile a Docutils tar file- and once again I run into a "could not create '/usr/lib/python2.7/site-packages/docutils': Permission denied" error.
Bearing in mind that I am compiling the code on the windows docker version of OPENFOAM taken from the OPENFOAM subsidary website of ESI, my question is two-fold:
a) The docker version does not recognize user-permission commands such as "sudo" or "--user" so is anyone aware of any commands related specifically to this platform that can give me file root access
b) Is there a simpler away of obtaining a groovy BC library as this is proving incredible long winded for a simple pressure boundary condition.
best,
Raheem
exx110 is offline   Reply With Quote
Old   July 5, 2021, 21:07
Alejandro
ancolli is on a distinguished road
Hi, I am interested in your acoustic solver for ultrasound in OpenFOAM. Do you have something published or something u can/want to share?
ancolli is offline   Reply With Quote
[swak4Foam] swak4foam >>>> INSTALLATION PROBLEM steven123 OpenFOAM Community Contributions 35 January 11, 2021 17:53
[swak4Foam] [OpenFOAM plus] [v1612+] swak4Foam installation problem in Windows (Allwmake) LThomes OpenFOAM Community Contributions 7 October 6, 2020 14:36
[swak4Foam] swak4Foam 0.3.1 OF2.2.2 Installation Issue scnsc OpenFOAM Community Contributions 3 August 20, 2014 08:59
[swak4Foam] swak4foam installation bharathbs OpenFOAM Community Contributions 6 April 28, 2014 09:20
[swak4Foam] About installation of swak4Foam mmkr825 OpenFOAM Community Contributions 10 December 14, 2012 02:24
