January 22, 2019, 18:10 |
How to compile sediFoam?
tooran
Rep Power: 10 |
Hi .
I am trying to install sediFoam according to https://github.com/xiaoh/sediFoam/wi...-to-compile%3F. But tin the last stage to run wmake command. Doese anybody have the experience to install sediFoam? Thanks alot. |
January 27, 2019, 16:34 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: Please keep in mind that a vague question will likely only result in a vague answer... if you get any answer at all. That's why this thread was written: How to give enough info to get help
The best answer I can give you is that you properly describe the problems you are having with installing, at the Issue tracker that sediFoam has got: https://github.com/xiaoh/sediFoam/issues
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 07:05 |
How to compile OpenFOAM-1.7.x on CrunchBang linux 10 | gwierink | OpenFOAM Installation | 0 | April 5, 2011 05:38 |
PV3FoamReader compile error.... | PEM_GUY | OpenFOAM Installation | 6 | April 5, 2010 18:22 |
Error compile file udf | czfluent | Fluent UDF and Scheme Programming | 24 | September 26, 2009 14:24 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 22:51 |
