[waves2Foam] Draft sensitive solution
Old   February 19, 2014, 00:16
Default Draft sensitive solution
Nima
nima3906m is on a distinguished road
Dear all
I am trying to simulate a floating body in 2D. The body is a simple rectangular box and the wave is airy. To my understanding the boundary condition for the floating object should be movingWallVelocity and the mass of the object should be equal to the mass of the displaced water. However my problem starts here! when I try to change the body draft and make it lower say half of the height of the body in the water the simulation crashes. While when it is 0.8 or higher the simulation runs perfectly. I can't understand what is wrong the only thing I see is that there exist undesired pressure region under the body for low draft values! and before it crashes it seems that the body has buoyancy problem . ( Do I calculate the mass in a wrong way ? ) Does it have a meaning for the centre of mass to be at sea level?
nima3906m is offline   Reply With Quote
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 22:22
Why 3D solid-pore geometry showing diverged solution? Sargam05 OpenFOAM 0 December 3, 2012 16:45
Analytic solution for 2D steady Euler equations jojo81 Main CFD Forum 0 October 15, 2012 13:05
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
