[waves2Foam] Video showing a little example of wave2foam coupled with dynamic mesh motion
Old   January 26, 2012, 03:36
Default Video showing a little example of wave2foam coupled with dynamic mesh motion
Jordi Muela
jordi.muela is on a distinguished road
Hi All,
here i share a video showing a little example of wave2foam coupled with dynamic mesh motion. I've modified the waveFlume example:
http://youtu.be/YKbj_7JMRl8
Thanks for noting the difference I hope you can benefit from my work!
- Niels
Sure, until now i was working with groovyBC when i need to generate waves, but my principal problem is the wave absortion, and i'm working with a modified version of interDyMFoam where i added a artificial damping coeficient in momentum equation, using a scalar field for act in the zones of interest, i.e. a numerical beach. But the relaxation zones that you implemented seems to work much better, so thank you again.
Jordi.
jordi.muela is offline   Reply With Quote
Old   January 26, 2012, 04:58
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi all
@Jordi: Neat! Is it a free floating object or have you applied mooring lines? You might have noticed, but waves2Foam has already been made ready for a numerical beach; merely two things are missing, namely (i) define the variation(s) of the artificial viscosity and (ii) add the source term in the momentum equation in the solvers. The latter part is really easy, since the needed interface is already in place as can be seen from the wiki. Again it is made with runTime selection in mind.
Kind regards,
Niels
Last edited by wyldckat; November 4, 2018 at 14:40. Reason: removed answer to another post that was on the main thread
ngj is offline   Reply With Quote
Old   January 26, 2012, 05:36
Jordi Muela
I've used a constraint plane XY and moments of inertia very highs in the three axis (that's the reason of the small pitch), to assure the stability in this simulation test.
Old   April 17, 2014, 10:24
Default request for files of the model (Thx)
yalong cai
pizicai is on a distinguished road
Originally Posted by jordi.muela View Post
Hi All,
Jordi.
Hi, Jordi,
I downloaded the model files you uploaded on
https://sites.google.com/site/jordim...ic-mesh-motion
however, I can not compile the waveDyMFoam successfully. I am sure i followed the steps suggested in Wiki.
__________________________________________________ _______________________________
SOURCE=waveDyMFoam.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam222/src/transportModels/twoPhaseMixture/lnInclude -I/opt/openfoam222/src/transportModels -I/opt/openfoam222/src/transportModels/incompressible/lnInclude -I/opt/openfoam222/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam222/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam222/src/finiteVolume/lnInclude -I/opt/openfoam222/src/dynamicMesh/lnInclude -I/opt/openfoam222/src/dynamicFvMesh/lnInclude -DOFVERSION=222 -I./../../../src/lnInclude -I/opt/openfoam222/src/meshTools/lnInclude -I/opt/openfoam222/src/fvOptions/lnInclude -I/opt/openfoam222/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam222/src/OpenFOAM/lnInclude -I/opt/openfoam222/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/waveDyMFoam.o
waveDyMFoam.C:44:28: fatal error: relaxationZone.H: No such file or directory
compilation terminated.
make: *** [Make/linuxGccDPOpt/waveDyMFoam.o] Error 1
__________________________________________________ _____________________________________
Thanks.
pizicai
pizicai is offline   Reply With Quote
velocity BC to provide flow rate relative to dynamic mesh motion oschi OpenFOAM Running, Solving & CFD 1 May 21, 2019 05:02
How to ensure good cells with dynamic mesh motion? petr.f. OpenFOAM Running, Solving & CFD 1 December 27, 2016 12:40
Dynamic mesh - exclude mesh motion in bc Tscar OpenFOAM Running, Solving & CFD 0 May 10, 2016 06:14
Turbulent problems during Dynamic Mesh Motion arturojortega FLUENT 2 June 2, 2009 11:33
Automatic Mesh Motion solver michele OpenFOAM Running, Solving & CFD 10 September 26, 2005 09:21
