[waves2Foam] converting interDyMFoam to waveDyMFoam with OpenFOAM 2.1.1
Old   May 30, 2014, 06:49
Default converting interDyMFoam to waveDyMFoam with OpenFOAM 2.1.1
Manoj
manoj_nav is on a distinguished road
Hi Everyone
I am trying to modify waves2foam for coupling it with dynamic mesh motion so that I can simulate boat motion in head waves as per tutorial given at following links,
http://openfoamwiki.net/index.php/Co..._with_dynamic_
https://sites.google.com/site/jordim...ic-mesh-motion
but when I compile waveDyMFoam I get errors,
waveDyMFoam.C:43:28: error: relaxationZone.H: No such file or directory
waveDyMFoam.C:56:36: error: readWaveProperties.H: No such file or directory
In file included from waveDyMFoam.C:55:
/home/manoj/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readGravitationalAcceleration.H: In function ‘int main(int, char**)’:
/home/manoj/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readGravitationalAcceleration.H:5: error: redeclaration of ‘Foam::uniformDimensionedVectorField g’
/home/manoj/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/readGravitationalAcceleration.H:5: error: ‘Foam::uniformDimensionedVectorField g’ previously declared here
In file included from createFields.H:96,
from waveDyMFoam.C:57:
In file included from waveDyMFoam.C:57:
createFields.H:134:
error: invalid initialization of reference of type ‘const Foam::dictionary&’ from expression of type ‘Foam::volScalarField’
/home/manoj/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/findRefCell.H:57:
error: in passing argument 2 of ‘void Foam::setRefCell(const Foam::volScalarField&, const Foam::dictionary&, Foam::label&, Foam::scalar&, bool)’
In file included from waveDyMFoam.C:74:
setDeltaT.H:37:
error: ‘maxAlphaCo’ was not declared in this scope
setDeltaT.H:37: error: ‘alphaCoNum’ was not declared in this scope
waveDyMFoam.C:109: error: ‘relaxing’ was not declared in this scope
Kindly help me to understand the error and correct them. I am new to openFOam.
With warm regards,
Manoj
manoj_nav is offline   Reply With Quote
Old   June 4, 2014, 01:23
Manoj
Hi Everyone
I am compiling waveDyMFoam.C and getting following error ..
Making dependency list for source file waveDyMFoam.C
could not open file relaxationZone.H for source file waveDyMFoam.C
could not open file readWaveProperties.H for source file waveDyMFoam.C
SOURCE=waveDyMFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I.. -I/opt/openfoam211/src/transportModels -I/opt/openfoam211/src/transportModels/incompressible/lnInclude -I/opt/openfoam211/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam211/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam211/src/finiteVolume/lnInclude -I/opt/openfoam211/src/dynamicMesh/lnInclude -I/opt/openfoam211/src/meshTools/lnInclude -I/opt/openfoam211/src/dynamicFvMesh/lnInclude -I./../../../../../src/lnInclude -IlnInclude -I. -I/opt/openfoam211/src/OpenFOAM/lnInclude -I/opt/openfoam211/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/waveDyMFoam.o
waveDyMFoam.C:43:28: fatal error: relaxationZone.H: No such file or directory
compilation terminated.
make: *** [Make/linux64GccDPOpt/waveDyMFoam.o] Error 1
Kindly help.
Regards,
Manoj
I am following below link to compile waveDyMFoam .
After I change -I./../../../../../src/lnInclude to -I./../../../../../src/waves2Foam/lnInclude i.e pointing to the right source I am able to compile.
Last edited by wyldckat; October 8, 2018 at 11:33. Reason: merged posts a few minutes apart
Old   June 5, 2014, 03:52
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good morning,
@Manoj (and others): The guides on converting interDyMFoam to waveDyMFoam are outdated, as they do not follow the most recent structure of the source code.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
Last edited by wyldckat; October 8, 2018 at 11:31. Reason: removed answer to another post that was on the main thread
ngj is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
Segmentation fault running waveDyMFoam solver (mod. interDyMFoam solver - waves2Foam) Ed R OpenFOAM Running, Solving & CFD 5 July 2, 2013 12:36
OpenFOAM Foundation Releases OpenFOAM® Version 2.1.1 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 May 31, 2012 10:07
[Gmsh] Error converting Gmsh mesh to OpenFOAM format Martin_ OpenFOAM Meshing & Mesh Conversion 3 December 9, 2009 10:35
