[waves2Foam] confusions about the term 'initializationName' suggested in waveProperties.input. |
June 18, 2014, 22:09 |
yalong cai
Rep Power: 12 |
Hello, Niels,
I have some confusions about the term 'initializationName' suggested in waveProperties.input. this term appears twice in openfoamWiki 1. The entry initializationName in waveProperties defines which sub-dictionary is used for initialising the wave field. 2. //Used by setWaveField and it is the sub-dictionary, // which defines which wave theory to be used for initialization what confuses me is why the term 'initializationName' is set to 'outlet' in each 'waveProperties.input' file rather than 'inlet'. actually, after I change it to 'inlet' error comes out: FOAM Warning : From function setWaveField::setWaveField( const fvMesh& mesh, volVectorField& U, volScalarField& alpha, volScalarField& p) in file preProcessing/setWaveField/setWaveField.C at line 77 The specified value of Tsoft is non-zero in the waveType: `stokesFirst' specified in the sub-dictionary waveProperties::inletCoeffs Consequently, the initialised `wave field' is set to a horizontal free surface with zero velocity. thanks for your attention. |
June 21, 2014, 06:57 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Good morning,
@Yalong: The program does the right thing. The choice of using the outlet for initialisation is merely random. When Tsoft > 0 it does not matter. If is only if you want a non-flat initial field that you have to think about the zone to use and the magnitude of Tsoft. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. Last edited by wyldckat; October 8, 2018 at 11:26. Reason: removed answer to another post that was on the main thread |
momentum source term | zwdi | FLUENT | 14 | June 27, 2017 16:40 |
How does fluent discretize the viscous term? | motorbean | FLUENT | 3 | August 25, 2015 17:38 |
Smagorinsky term in SGS kinetic energy equation | Ivan | Main CFD Forum | 3 | January 21, 2013 16:22 |
Source Term Question | Blackhawks84 | Fluent UDF and Scheme Programming | 1 | July 31, 2012 16:44 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
