[waves2Foam] porouswavefoam/gambit mesh
Old   June 20, 2014, 13:45
Default porouswavefoam/gambit mesh
da14 is on a distinguished road
Hii
Im try to simulate a porous breakwater with wave generation on waves2foam using porousWaveFoam with Gambi mesh.
My problem is that when i run fluentMeshToFoam to convert the msh file the porosity zone is not defined at cellZones. So when i run the solver the porosity information is not found so i get error.
Can you help me?
Regards
Diogo Afonso
da14 is offline   Reply With Quote
Old   June 21, 2014, 06:57
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good morning,
@DA14: This is a pre-processing/meshing question, so please refer it to an appropriate thread.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
Last edited by wyldckat; October 8, 2018 at 11:26. Reason: removed answer to another post that was on the main thread
ngj is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
