[waves2Foam] model a solitary wave impacts on a fixed plate above SWL
Old   June 30, 2014, 17:36
Default model a solitary wave impacts on a fixed plate above SWL
yalong cai
pizicai is on a distinguished road
hello, Niels,
I want to model a solitary wave impacts on a fixed plate above SWL. in this model, the wave is generated by Wave2Foam and the mesh is created by snappyHexMesh, that means the plate is just digged out from a plate (this is a 2D model), whose surface is defined as walls. the model could be seen in photo named "model description"
my problem is: before the wave comes through the plate, the water close to the plate produce velocity, you can see the details in the photo named "velocity_graph_before_wavecomes", as a rusult, the plate carry some force from water before wave comes, which could been seen in the photo named "plate_genwave_z"
i am suspicious that there is some problems with "waveProperties.input". you can find it in the zip-file named "plate_solitary_model"
I wonder if it is obligatory to set outlet BC as potential wave when I just want the water flow out smoothly, could I just set a relaxationzone without setting potential wave? what is interesting is water in the whole domain rotate with a small velocity from start, which i assume is caused by potential wave?
(all files could be found in dropbox, link has been attached)
https://www.dropbox.com/sh/duwtl5pym...JzR62FjTZJFB4a
pizicai is offline   Reply With Quote
Old   June 30, 2014, 18:07
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good evening,
@Pizicai: I am unfortunately not in a position, where I can help you with resolving your problems. It sounds like a classical generation of energy on refined meshes due to non-balanced momentum equation in interFoam.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
Last edited by wyldckat; October 8, 2018 at 11:20. Reason: removed answer to another post that was on the main thread
ngj is offline   Reply With Quote
Old   July 1, 2014, 17:52
yalong cai
Hello, Niels,
Thanks for your prompt reply. Actually, I found the mistake afterward. This is supposed be a 2D model, however, after snappyHexMesh, the mesh around the plate has more than one grids, after I run extrudeMesh, the chaos around plate before wave comes disappears. sorry to ask this question without a careful check.
By the way, my last question still exists, I wonder if it is obligatory to set outlet BC as potential wave when I just want the water flow out smoothly, could I just set a relaxationzone without setting potential wave? I tried delete 'wave type' part and kept
relaxationzone definition part of the "outletcoefficients section', and the result is it cannot run.
Old   July 5, 2014, 10:47
ngj
Good afternoon,
@Pizicai: The use of relaxation zones is the way to have waves smoothly leaving the domain in waves2Foam. There are other methods in the literature, but they are not implemented in waves2Foam. You cannot define a relaxation zone without defining all the required properties.
Kind regards,
Niels
[waves2Foam] Waves2Foam Related Topics ngj OpenFOAM Community Contributions 660 August 20, 2018 13:39
Solitary wave Kourosh Hejazi Main CFD Forum 4 July 24, 2003 15:37
simulation of breaking solitary wave mehdi icho Main CFD Forum 0 July 2, 2002 05:35
Supersonic flow over flat plate - best model Chris Rand FLUENT 4 October 3, 2000 07:58
Ocean Wave Model with FLOW3D Haryo Armono Main CFD Forum 0 January 28, 1999 14:11
