[waves2Foam] trying to modify the waveFlume tutorial by changing the geometry and inlet
Old   July 9, 2014, 09:06
Default trying to modify the waveFlume tutorial by changing the geometry and inlet
Dmitrijs Gavrilovs-Stepanovs
Dmitrjs is on a distinguished road
Good afternoon everyone,
Hopefully you all are having a good summer and I was wondering if you could help me with the following problem.
I am trying to modify the waveFlume tutorial by changing the geometry (increasing the domain) and wave inlet conditions. Everything runs OK, but when I view it in paraFoam, the wave flume stops at certain point in the tank as if there is a relaxation zone. If I change the period to larger value, then the wavelength becomes longer and waves reach the relaxation zone I set up at the outlet, however, I need to use a lower value of period. Here is my waveProperties.input file:
seaLevel 0.00;
// A list of the relaxation zones in the simulation. The parameters are given
// in <name>Coeffs below.
relaxationNames (inlet outlet);
initializationName outlet;
inletCoeffs
// Wave type to be used at boundary "inlet" and in relaxation zone "inlet"
waveType stokesFirst;
// Ramp time of 2 s
Tsoft 2;
// Water depth at the boundary and in the relaxation zone
depth 1.0;
// Wave period
period 1.0;
// Phase shift in the wave
phi 0.000000;
// Wave number vector, k.
direction (1.0 0.0 0.0);
// Wave height
height 0.033;
// Specifications on the relaxation zone shape and relaxation scheme
relaxationZone
relaxationScheme Spatial;
relaxationShape Rectangular;
beachType Empty;
relaxType INLET;
startX (0 0.0 -1);
endX (3 0.0 1);
orientation (1.0 0.0 0.0);
outletCoeffs
waveType potentialCurrent;
U (0 0 0);
Tsoft 2;
relaxationZone
beachType Empty;
relaxType OUTLET;
startX (14.408 0.0 -1);
endX (17.965 0.0 1);
I do not know whether there is something wrong with the relaxation zones (the dimensions of them) or the value of wave height and period are too small for this domain, so I thought someone could help me to understand what is wrong.
Thank you in advance!
Dmitrjs is offline   Reply With Quote
Old   July 9, 2014, 17:53
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good evening,
@Dimitrijs: Please read this thread carefully: http://www.cfd-online.com/Forums/ope...-get-help.html (Hint: You have by far given enough information for anyone to help you).
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
Last edited by wyldckat; October 8, 2018 at 11:16. Reason: removed answer to another post that was on the main thread
ngj is offline   Reply With Quote
Single inlet geometry Gearb0x OpenFOAM Running, Solving & CFD 6 January 13, 2020 17:18
Interfoam - Real world Geometry with constant inlet flow bdh1103 OpenFOAM Running, Solving & CFD 0 February 10, 2016 15:54
Tutorial about pressure inlet, pressure outletReverse flow in pressure inlet Tanjina FLUENT 0 February 26, 2014 01:13
Inlet profile independent of geometry orientation ? arapha FLUENT 0 February 18, 2011 17:28
