[waves2Foam] working on a improved version of the waveFlume
Old   July 17, 2014, 07:19
Default working on a improved version of the waveFlume
Olivier Giroux
daxt29 is on a distinguished road
Hello everyone,
I am working on a improved version of the waveFlume to study the free surface elevation of an oscillating water columns. I created the device with FreeCad and I generated the mesh with SnappyHexMesh.
I am running my model in parallel with a cluster. All the first step which initialise the model work well but when I start the first iteration, they stop after 5 sec because of a segmentation fault. I am still a new user of waves2Foam and I would like to know what what can be the origin of this problem.
Here is my error message:
[0] #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #1 Foam::sigSegv::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #2
[0] at sigaction.c:0
[0] #3 Foam::sampledSurfaceElevation::sampleIntegrateAndW rite(Foam::sampledSurfaceElevation::fieldGroup<dou ble>&) in "/home/ogiroux/OpenFOAM/ogiroux-2.1.1/platforms/linux64GccDPOpt/lib/libwaves2Foam.so"
[0] #4 Foam::OutputFilterFunctionObject<Foam::sampledSurf aceElevation>::execute(bool) in "/home/ogiroux/OpenFOAM/ogiroux-2.1.1/platforms/linux64GccDPOpt/lib/libwaves2Foam.so"
[0] #5 Foam::functionObjectList::execute(bool) in "/opt/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #6 Foam::Time::run() const in "/opt/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #7
[0] in "/home/ogiroux/OpenFOAM/ogiroux-2.1.1/platforms/linux64GccDPOpt/bin/waveFoam"
[0] #8 __libc_start_main in "/lib64/libc.so.6"
[0] #9
[compute-0-37:14938] *** Process received signal ***
[compute-0-37:14938] Signal: Segmentation fault (11)
[compute-0-37:14938] Signal code: (-6)
[compute-0-37:14938] Failing at address: 0x23e00003a5a
[compute-0-37:14938] [ 0] /lib64/libc.so.6() [0x3d70a329a0]
[compute-0-37:14938] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x3d70a32925]
[compute-0-37:14938] [ 2] /lib64/libc.so.6() [0x3d70a329a0]
[compute-0-37:14938] [ 3] /home/ogiroux/OpenFOAM/ogiroux-2.1.1/platforms/linux64GccDPOpt/lib/libwaves2Foam.so(_ZN4Foam23sampledSurfaceElevation 23sampleIntegrateAndWriteERNS0_10fieldGroupIdEE+0x 77b) [0x2b3cec78eb8b]
[compute-0-37:14938] [ 4] /home/ogiroux/OpenFOAM/ogiroux-2.1.1/platforms/linux64GccDPOpt/lib/libwaves2Foam.so(_ZN4Foam26OutputFilterFunctionObj ectINS_23sampledSurfaceElevationEE7executeEb+0x88) [0x2b3cec797dc8]
[compute-0-37:14938] [ 5] /opt/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam18functionObjectList7execut eEb+0xf9) [0x2b3cecbf4da9]
[compute-0-37:14938] [ 6] /opt/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam4Time3runEv+0xb0) [0x2b3cecbf86c0]
[compute-0-37:14938] [ 7] waveFoam() [0x429f6b]
[compute-0-37:14938] [ 8] /lib64/libc.so.6(__libc_start_main+0xfd) [0x3d70a1ed1d]
[compute-0-37:14938] [ 9] waveFoam() [0x4277a9]
[compute-0-37:14938] *** End of error message ***
[compute-0-40][[41936,1],8][btl_tcp_frag.c:215:mca_btl_tcp_frag_recv] mca_btl_tcp_frag_recv: readv failed: Connection reset by peer (104)
mpirun noticed that process rank 0 with PID 14938 on node compute-0-37 exited on signal 11 (Segmentation fault).
daxt29 is offline   Reply With Quote
Old   July 19, 2014, 06:01
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good morning
@Olivier: Something is wrong with your surface elevation extraction at run-time. At least that is where the code fails. Check the validity of the wave gauges.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
Last edited by wyldckat; October 8, 2018 at 11:13. Reason: removed answer to another post that was on the main thread
ngj is offline   Reply With Quote
[FLUENT] UDF NOT working in new version of Fluent Faggio11 Fluent UDF and Scheme Programming 6 February 10, 2017 15:13
3D FSI not working parallel in version 4.3.0 shivak SU2 0 September 19, 2016 08:21
How can i uninstall new version of OF shipman OpenFOAM Installation 5 August 12, 2013 05:01
compressible low speed channel flow -Ali OpenFOAM Running, Solving & CFD 11 May 9, 2013 08:40
wmake error zxj160 OpenFOAM 0 March 26, 2012 11:52
