[waves2Foam] waveGaugeNProbes with waveDyMFoam in OF 2.3 |
February 12, 2015, 00:07 |
Rep Power: 16 |
Hi All,
I am facing an issue and appreciate any comments. I just switched to OF 2.3 and compiled the latest waves2foam. I am using waveDyMFoam and all is fine but when I use waveGaugeNProbes with waveDyMFoam and set my probes locations, after running the simulation the moment it gets to write the wave probe data the simulations fails and I get the following error. However, when I use waveGaugeNProbes with waveFoam it run just fine. I would highly appreciate any comments. Code:
[0] #0 [1] Foam::error::printStack(Foam::Ostream&)[3] #0 Foam::error::printStack(Foam::Ostream&)#0 Foam::error::printStack(Foam::Ostream&)[2] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [1] #1 at ??:? [0] #1 Foam::sigSegv::sigHandler(int) at ??:? [2] #1 Foam::sigSegv::sigHandler(int) at ??:? [3] #1 Foam::sigSegv::sigHandler(int)Foam::sigSegv::sigHandler(int) at ??:? [2] #2 at ??:? [1] #2 at ??:? [0] #2 at ??:? [3] #2 in "/lib64/libc.so.6" [0] #3 Foam::HashTable<Foam::regIOobject*, Foam::word, Foam::string::hash>::find(Foam::word const&) const in "/lib64/libc.so.6" [2] #3 Foam::HashTable<Foam::regIOobject*, Foam::word, Foam::string::hash>::find(Foam::word const&) const in "/lib64/libc.so.6" [1] #3 Foam::HashTable<Foam::regIOobject*, Foam::word, Foam::string::hash>::find(Foam::word const&) const in "/lib64/libc.so.6" [3] #3 Foam::HashTable<Foam::regIOobject*, Foam::word, Foam::string::hash>::find(Foam::word const&) const at ??:? [3] #4 Foam::MeshObject<Foam::pointMesh, Foam::UpdateableMeshObject, Foam::pointConstraints>::New(Foam::pointMesh const&) at ??:? [2] #4 Foam::MeshObject<Foam::pointMesh, Foam::UpdateableMeshObject, Foam::pointConstraints>::New(Foam::pointMesh const&) at ??:? [0] #4 Foam::MeshObject<Foam::pointMesh, Foam::UpdateableMeshObject, Foam::pointConstraints>::New(Foam::pointMesh const&) at ??:? [1] #4 Foam::MeshObject<Foam::pointMesh, Foam::UpdateableMeshObject, Foam::pointConstraints>::New(Foam::pointMesh const&) at ??:? [0] #5 Foam::CETORigidBodyMotionSolver::solve() at ??:? [1] #5 Foam::CETORigidBodyMotionSolver::solve() at ??:? [3] #5 Foam::CETORigidBodyMotionSolver::solve() at ??:? [2] #5 Foam::CETORigidBodyMotionSolver::solve() at ??:? [3] #6 Foam::motionSolver::newPoints() at ??:? [0] #6 Foam::motionSolver::newPoints() at ??:? [1] #6 Foam::motionSolver::newPoints() at ??:? [2] #6 Foam::motionSolver::newPoints() at ??:? [1] #7 Foam::dynamicMotionSolverFvMesh::update() at at ??:? [3] #7 Foam::dynamicMotionSolverFvMesh::update()??:? [0] #7 Foam::dynamicMotionSolverFvMesh::update() at ??:? [2] #7 Foam::dynamicMotionSolverFvMesh::update() at ??:? [0] #8 at ??:? [1] #8 at ??:? [3] #8 at ??:? [2] #8 [2] [3] at ??:? [3] #9 [0] at ??:? [0] #9 __libc_start_main__libc_start_main at [1] at ??:? [1] #9??:? __libc_start_main [2] #9 __libc_start_main in "/lib64/libc.so.6" [2] #10 in "/lib64/libc.so.6" [3] #10 in "/lib64/libc.so.6" [0] #10 in "/lib64/libc.so.6" [1] #10 [3] at /home/abuild/rpmbuild/BUILD/glibc-2.19/csu/../sysdeps/x86_64/start.S:125 [2] at /home/abuild/rpmbuild/BUILD/glibc-2.19/csu/../sysdeps/x86_64/start.S:125 [linux-0tqr:09298] *** Process received signal *** [linux-0tqr:09299] *** Process received signal *** [linux-0tqr:09299] Signal: Segmentation fault (11) [linux-0tqr:09299] Signal code: (-6) [linux-0tqr:09299] Failing at address: 0x3e800002453 [1] at /home/abuild/rpmbuild/BUILD/glibc-2.19/csu/../sysdeps/x86_64/start.S:125 [linux-0tqr:09297] *** Process received signal *** [0] at /home/abuild/rpmbuild/BUILD/glibc-2.19/csu/../sysdeps/x86_64/start.S:125 [linux-0tqr:09296] *** Process received signal *** [linux-0tqr:09298] Signal: Segmentation fault (11) [linux-0tqr:09298] Signal code: (-6) [linux-0tqr:09298] Failing at address: 0x3e800002452 [linux-0tqr:09297] Signal: Segmentation fault (11) [linux-0tqr:09297] Signal code: (-6) [linux-0tqr:09297] Failing at address: 0x3e800002451 [linux-0tqr:09299] [ 0] /lib64/libc.so.6(+0x35200) [0x7f15e146a200] [linux-0tqr:09299] [ 1] /lib64/libc.so.6(gsignal+0x37) [0x7f15e146a187] [linux-0tqr:09299] [ 2] /lib64/libc.so.6(+0x35200) [0x7f15e146a200] [linux-0tqr:09299] [ 3] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZNK4Foam9HashTableIPNS_11regIOobjectENS_4wordENS_6string4hashEE4findERKS3_+0x14) [0x7f15e536af94] [linux-0tqr:09299] [ 4] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam10MeshObjectINS_9pointMeshENS_20UpdateableMeshObjectENS_16pointConstraintsEE3NewERKS1_+0x26) [0x7f15e536dc96] [linux-0tqr:09299] [ 5] /home/ashkan/OpenFOAM/ashkan-2.3.0/platforms/linux64GccDPOpt/lib/libCETO_NumWEC.so(_ZN4Foam25CETORigidBodyMotionSolver5solveEv+0x9d8) [0x7f15d1b3e598] [linux-0tqr:09299] [ 6] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libdynamicMesh.so(_ZN4Foam12motionSolver9newPointsEv+0x15) [0x7f15e46c3495] [linux-0tqr:09299] [ 7] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so(_ZN4Foam25dynamicMotionSolverFvMesh6updateEv+0x2f) [0x7f15e417ccff] [linux-0tqr:09299] [ 8] waveDyMFoam() [0x430450] [linux-0tqr:09299] [ 9] /lib64/libc.so.6(__libc_start_main+0xf5) [0x7f15e1456b05] [linux-0tqr:09299] [10] waveDyMFoam() [0x4369c5] [linux-0tqr:09299] *** End of error message *** [linux-0tqr:09298] [ 0] /lib64/libc.so.6(+0x35200) [0x7f6517c5e200] [linux-0tqr:09298] [ 1] /lib64/libc.so.6(gsignal+0x37) [0x7f6517c5e187] [linux-0tqr:09298] [ 2] /lib64/libc.so.6(+0x35200) [0x7f6517c5e200] [linux-0tqr:09298] [ 3] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZNK4Foam9HashTableIPNS_11regIOobjectENS_4wordENS_6string4hashEE4findERKS3_+0x14) [0x7f651bb5ef94] [linux-0tqr:09298] [ 4] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam10MeshObjectINS_9pointMeshENS_20UpdateableMeshObjectENS_16pointConstraintsEE3NewERKS1_+0x26) [0x7f651bb61c96] [linux-0tqr:09298] [ 5] /home/ashkan/OpenFOAM/ashkan-2.3.0/platforms/linux64GccDPOpt/lib/libCETO_NumWEC.so(_ZN4Foam25CETORigidBodyMotionSolver5solveEv+0x9d8) [0x7f6508332598] [linux-0tqr:09298] [ 6] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libdynamicMesh.so(_ZN4Foam12motionSolver9newPointsEv+0x15) [0x7f651aeb7495] [linux-0tqr:09298] [ 7] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so(_ZN4Foam25dynamicMotionSolverFvMesh6updateEv+0x2f) [0x7f651a970cff] [linux-0tqr:09298] [ 8] waveDyMFoam() [0x430450] [linux-0tqr:09298] [ 9] /lib64/libc.so.6(__libc_start_main+0xf5) [0x7f6517c4ab05] [linux-0tqr:09298] [10] waveDyMFoam() [0x4369c5] [linux-0tqr:09298] *** End of error message *** [linux-0tqr:09296] Signal: Segmentation fault (11) [linux-0tqr:09296] Signal code: (-6) [linux-0tqr:09296] Failing at address: 0x3e800002450 [linux-0tqr:09297] [ 0] /lib64/libc.so.6(+0x35200) [0x7f47b0d09200] [linux-0tqr:09297] [ 1] /lib64/libc.so.6(gsignal+0x37) [0x7f47b0d09187] [linux-0tqr:09297] [ 2] /lib64/libc.so.6(+0x35200) [0x7f47b0d09200] [linux-0tqr:09297] [ 3] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZNK4Foam9HashTableIPNS_11regIOobjectENS_4wordENS_6string4hashEE4findERKS3_+0x14) [0x7f47b4c09f94] [linux-0tqr:09297] [ 4] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam10MeshObjectINS_9pointMeshENS_20UpdateableMeshObjectENS_16pointConstraintsEE3NewERKS1_+0x26) [0x7f47b4c0cc96] [linux-0tqr:09297] [ 5] /home/ashkan/OpenFOAM/ashkan-2.3.0/platforms/linux64GccDPOpt/lib/libCETO_NumWEC.so(_ZN4Foam25CETORigidBodyMotionSolver5solveEv+0x9d8) [0x7f47a13dd598] [linux-0tqr:09297] [ 6] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libdynamicMesh.so(_ZN4Foam12motionSolver9newPointsEv+0x15) [0x7f47b3f62495] [linux-0tqr:09297] [ 7] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so(_ZN4Foam25dynamicMotionSolverFvMesh6updateEv+0x2f) [0x7f47b3a1bcff] [linux-0tqr:09297] [ 8] waveDyMFoam() [0x430450] [linux-0tqr:09297] [ 9] /lib64/libc.so.6(__libc_start_main+0xf5) [0x7f47b0cf5b05] [linux-0tqr:09297] [10] waveDyMFoam() [0x4369c5] [linux-0tqr:09297] *** End of error message *** [linux-0tqr:09296] [ 0] /lib64/libc.so.6(+0x35200) [0x7fcc0d45d200] [linux-0tqr:09296] [ 1] /lib64/libc.so.6(gsignal+0x37) [0x7fcc0d45d187] [linux-0tqr:09296] [ 2] /lib64/libc.so.6(+0x35200) [0x7fcc0d45d200] [linux-0tqr:09296] [ 3] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZNK4Foam9HashTableIPNS_11regIOobjectENS_4wordENS_6string4hashEE4findERKS3_+0x6d) [0x7fcc1135dfed] [linux-0tqr:09296] [ 4] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam10MeshObjectINS_9pointMeshENS_20UpdateableMeshObjectENS_16pointConstraintsEE3NewERKS1_+0x26) [0x7fcc11360c96] [linux-0tqr:09296] [ 5] /home/ashkan/OpenFOAM/ashkan-2.3.0/platforms/linux64GccDPOpt/lib/libCETO_NumWEC.so(_ZN4Foam25CETORigidBodyMotionSolver5solveEv+0x9d8) [0x7fcbfdb31598] [linux-0tqr:09296] [ 6] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libdynamicMesh.so(_ZN4Foam12motionSolver9newPointsEv+0x15) [0x7fcc106b6495] [linux-0tqr:09296] [ 7] /home/ashkan/OpenFOAM/OpenFOAM-2.3.0/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so(_ZN4Foam25dynamicMotionSolverFvMesh6updateEv+0x2f) [0x7fcc1016fcff] [linux-0tqr:09296] [ 8] waveDyMFoam() [0x430450] [linux-0tqr:09296] [ 9] /lib64/libc.so.6(__libc_start_main+0xf5) [0x7fcc0d449b05] [linux-0tqr:09296] [10] waveDyMFoam() [0x4369c5] [linux-0tqr:09296] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 0 with PID 9296 on node linux-0tqr exited on signal 11 (Segmentation fault). -------------------------------------------------------------------------- |
[waves2Foam] Compiling waveDyMFoam in OF410 | H3000 | OpenFOAM Community Contributions | 0 | June 5, 2017 13:24 |
[waves2Foam] Problems with waveDyMFoam and ghRef | Tasos | OpenFOAM Community Contributions | 1 | January 11, 2017 13:39 |
[waves2Foam] Problems in Operating waveDyMFoam in openfoam 2.3.1 | zhxter | OpenFOAM Community Contributions | 2 | May 18, 2015 21:57 |
Differences between OF2.2 and OF 2.3 in sprayFoam spraycloudproperties | FWST | OpenFOAM Running, Solving & CFD | 1 | February 13, 2015 07:53 |
compiling waveDyMFoam on Mac with OF 2.1.x | ashkan | OpenFOAM Installation | 3 | December 17, 2013 03:09 |
