[waves2Foam] Problems with waveFoam/waveFlume in OpenFOAM 2.3.1 |
May 4, 2015, 05:15 |
moh
Rep Power: 11 |
Hi friends
I recently compiled waveFoam and want to run wave flume tutorial,but I received the following and it doesn't work properly Code:
beigi@Beigi-PC:~/OpenFOAM/beigi-2.3.1/run/tutorials/waveFoam/waveFlume$ interFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.1-bcfaaa7b8660 Exec : interFoam Date : May 04 2015 Time : 15:20:58 Host : "Beigi-PC" PID : 4566 Case : /home/beigi/OpenFOAM/beigi-2.3.1/run/tutorials/waveFoam/waveFlume nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 // using new solver syntax: pcorr { solver GAMG; tolerance 1e-07; relTol 0; smoother DIC; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } // using new solver syntax: p_rgh { solver GAMG; tolerance 1e-07; relTol 0; smoother DIC; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } // using new solver syntax: p_rghFinal { solver GAMG; tolerance 1e-08; relTol 0; smoother DIC; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } // using new solver syntax: U { solver PBiCG; preconditioner DILU; tolerance 1e-09; relTol 0; } // using new solver syntax: UFinal { solver PBiCG; preconditioner DILU; tolerance 1e-09; relTol 0; } // using new solver syntax: gamma { solver PBiCG; preconditioner DILU; tolerance 1e-07; relTol 0; } PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U --> FOAM FATAL IO ERROR: Unknown patchField type waveVelocity for patch type patch Valid patchField types are : 75 ( SRFFreestreamVelocity SRFVelocity activeBaffleVelocity activePressureForceBaffleVelocity advective atmBoundaryLayerInletVelocity calculated codedFixedValue codedMixed cyclic cyclicACMI cyclicAMI cyclicSlip cylindricalInletVelocity directionMixed empty externalCoupled fixedGradient fixedInternalValue fixedJump fixedJumpAMI fixedMean fixedNormalInletOutletVelocity fixedNormalSlip fixedValue flowRateInletVelocity fluxCorrectedVelocity freestream inletOutlet interstitialInletVelocity kqRWallFunction mapped mappedField mappedFixedInternalValue mappedFixedPushedInternalValue mappedFlowRate mappedVelocityFlux mixed movingWallVelocity nonuniformTransformCyclic oscillatingFixedValue outletInlet outletMappedUniformInlet outletPhaseMeanVelocity partialSlip pressureDirectedInletOutletVelocity pressureDirectedInletVelocity pressureInletOutletParSlipVelocity pressureInletOutletVelocity pressureInletUniformVelocity pressureInletVelocity pressureNormalInletOutletVelocity processor processorCyclic rotatingPressureInletOutletVelocity rotatingWallVelocity sliced slip supersonicFreestream surfaceNormalFixedValue swirlFlowRateInletVelocity symmetry symmetryPlane timeVaryingMappedFixedValue translatingWallVelocity turbulentInlet uniformFixedGradient uniformFixedValue uniformInletOutlet uniformJump uniformJumpAMI variableHeightFlowRateInletVelocity waveTransmissive wedge zeroGradient ) file: /home/beigi/OpenFOAM/beigi-2.3.1/run/waveFlume/0/U.boundaryField.inlet from line 26 to line 30. From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&) in file /home/openfoam/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 143. FOAM exiting thank u Last edited by wyldckat; October 7, 2018 at 14:28. Reason: [QUOTE]->[CODE] |
May 4, 2015, 11:05 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hallo,
You are executing 'interFoam', but that does not know, how to use the wave generation capabilities. Furthermore, note that OF2.3.1 is not supported, so you have to create the solver 'waveFoam' yourself. I have long decided to only support main version numbers of OF/foam-extend, thus versions with changes on the third digit does not fall under this subset of versions. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
May 5, 2015, 01:46 |
moh
Rep Power: 11 |
Hi Niels,
Thank you for responding and help me. I used interFom as application since when I used waveFom, I received "command not found" massage despite compiling waveFoam according to openFoam wiki. So you mean I should install OF 2.3.0 to execute waveFoam? Thank you in advance for help me, Kind Regards, Moh |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
