[waves2Foam] Problems in Operating waveDyMFoam in openfoam 2.3.1 |
May 18, 2015, 01:26 |
Xiantao Zhang
Rep Power: 11 |
Dear all,
I am now calculating the dynamic response of a rectangular box in waves. But I get some problems when using the waveDyMFoam application. Code:
zhxt@ubuntu:~/waves2Foam/tutorials/waveFoam/2Dgreenwatermove$ waveDyMFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.1-bcfaaa7b8660 Exec : waveDyMFoam Date : May 17 2015 Time : 21:51:35 Host : "ubuntu" PID : 49867 Case : /home/zhxt/waves2Foam/tutorials/waveFoam/2Dgreenwatermove nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh // using new solver syntax: U { solver PBiCG; preconditioner DILU; tolerance 1e-09; relTol 0; } // using new solver syntax: UFinal { solver PBiCG; preconditioner DILU; tolerance 1e-09; relTol 0; } // using new solver syntax: gamma { solver PBiCG; preconditioner DILU; tolerance 1e-07; relTol 0; } Selecting motion solver: sixDoFRigidBodyMotion Translational constraint tensor (0 0 0 0 1 0 0 0 0) Rotational constraint tensor (0 0 0 0 0 0 0 0 1) Reading g Reading waveProperties PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Calculating field g.h No finite volume options present GAMG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 GAMG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 Reading/calculating face velocity Uf Courant Number mean: 0 max: 0 Starting time loop Interface Courant Number mean: 0 max: 0 Courant Number mean: 0 max: 0 deltaT = 0.00119048 Time = 0.00119048 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::sixDoFRigidBodyMotion::updatePosition(double, double) at ??:? #4 Foam::sixDoFRigidBodyMotionSolver::solve() at ??:? #5 Foam::motionSolver::newPoints() at ??:? #6 Foam::dynamicMotionSolverFvMesh::update() at ??:? #7 at ??:? #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 at ??:? Floating point exception (core dumped)\ 1, alpha.water: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5-dev | | \\ / A nd | Revision: 1740 | | \\/ M anipulation | Web: http://www.OpenFOAM.org | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object alpha.org; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type waveAlpha; refValue uniform 0; refGrad uniform 0; valueFraction uniform 1; value uniform 0; } bottom { type zeroGradient; } outlet { type zeroGradient; } atmosphere { type inletOutlet; inletValue uniform 0; value uniform 0; } vessel { type zeroGradient; } frontBack { type empty; } } Code:
FoamFile { version 2.0; format ascii; class pointVectorField; location "0"; object pointDisplacement; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 0 0 0 0 0]; internalField uniform (0 0 0); boundaryField { //- Set patchGroups for constraint patches #include "${WM_PROJECT_DIR}/etc/caseDicts/setConstraintTypes" inlet { type fixedValue; value uniform (0 0 0); } outlet { type fixedValue; value uniform (0 0 0); } atmosphere { type fixedValue; value uniform (0 0 0); } bottom { type fixedValue; value uniform (0 0 0); } vessel { type calculated; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5-dev | | \\ / A nd | Revision: 1740 | | \\/ M anipulation | Web: http://www.OpenFOAM.org | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object pd; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } bottom { type zeroGradient; } outlet { type zeroGradient; } atmosphere { type totalPressure; U U; phi phi; rho none; psi none; gamma 1; p0 uniform 0; value uniform 0; } /* vessel { type fixedFluxPressure; gradient uniform 0; value uniform 0; } */ vessel { type zeroGradient; } frontBack { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U.org; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform ( 0.0 0.0 0.0); boundaryField { inlet { type waveVelocity; refValue uniform ( 0 0 0 ); refGradient uniform ( 0 0 0 ); valueFraction uniform 1; value uniform ( 0 0 0 ); } bottom { type fixedValue; value uniform ( 0 0 0 ); } outlet { type fixedValue; value uniform ( 0 0 0 ); } atmosphere { type pressureInletOutletVelocity; value uniform ( 0 0 0 ); } vessel { type movingWallVelocity; value uniform (0 0 0); } frontBack { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object motionProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ("libsixDoFRigidBodyMotion.so"); solver sixDoFRigidBodyMotion; sixDoFRigidBodyMotionCoeffs { patches (vessel); innerDistance 0.05; outerDistance 0.11; centreOfMass (6.29 0.9 0); mass 150; momentOfInertia (0 0 1.5); rhoInf 1; report on; accelerationRelaxation 0.3; value uniform (0 0 0); constraints { Heave { sixDoFRigidBodyMotionConstraint line; direction (0 1 0); } Pitch { sixDoFRigidBodyMotionConstraint axis; axis (0 0 1); } } } // ************************************************************************* // Last edited by wyldckat; October 7, 2018 at 13:47. Reason: Added [CODE][/CODE] markers |
May 18, 2015, 04:04 |
Hao Chen
Hi Xintao,
Just a question, waves2Foam now can be used in OpenFOAM 2.3.1? and also one more question, do you meet any problem when you use dynamicMotionSolverFvmesh in parallel? Best, Hao Last edited by wyldckat; October 7, 2018 at 13:47. Reason: removed large quote, since the post is now right above it on the new thread |
May 18, 2015, 20:57 |
Xiantao Zhang
Rep Power: 11 |
Hi, hao
Yeah, I successfully compiled waves2foam on OF 2.3.1. And waveFoam solver works well. The only problem is about the solver waveDyMFoam, which still cannot work now. |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
[OpenFOAM.org] Problem of openFOAM 2.3.1 installation in Ubuntu 14.04LTS | mukut | OpenFOAM Installation | 9 | January 19, 2015 00:48 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
