[Other] sedFoam: two-phase flow sediment transport model |
#41 |
Sourav Hossain
Rep Power: 7 ![]() |
Dear Sir,
I have been trying to install sedfoam. I am using openfoam6 in ubuntu 16.04. While running ./Allwmake command, I get the following errors Foam::sedIncompressibleTurbulenceModel<TransportMo del>:Primef() const’: ../TurbulenceModels/turbulenceModels/lnInclude/sedIncompressibleTurbulenceModel.C:128:12: error: ‘New’ is not a member of ‘Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >’ return tmp<surfaceScalarField>::New ^ /home/sourav/OpenFOAM/OpenFOAM-6/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt64Opt/sedFoam_MULES.o' failed make: *** [Make/linux64GccDPInt64Opt/sedFoam_MULES.o] Error 1 Please help me out. Thanks in advance. |
#42 |
Sourav Hossain
Dear Sir,
#43 |
Cyrille Bonamy
Rep Power: 11 ![]() |
Sorry, we are now only supporting the versions of OpenFoam.com.
I have to update the readme and the doc to clarify this point Cyrille |
#44 |
Sourav Hossain
#45 |
Cyrille Bonamy
#46 | |
Dear Julien, Thanks for your updating. But I always met a problem when I was compiling the solver. Could you please give me some starting tutorials? |
#47 |
Cyrille Bonamy
Which version of Openfoam do you use?
As said before, we now support openfoam.com (and not openfoam.org)... |
#48 |
Hi Thanks for your reply. In the end, I compiled the solver successfully.
#49 |
Dear all,
Please help me see the issue of leading wrong fields set (refer to this threadthe inlet proile is not numbers while using funkySetFieldsDict). Thanks. |
#50 |
already solved.
#51 |
Dear all,
"After I finished the calculation, should I use another tool to plot the scour characteristics, instead of paraview? Now I can only plot the distribution of solid concentration to roughly see the scouring process. Do you have any idea? Thanks a lot." solved Last edited by qi.yang@polimi.it; July 8, 2021 at 05:10. |
#52 | |
Cyrille Bonamy
Yes You can use Python to postprocess and display your results. In the Tutorials/Py folder, there are some examples that are explained in the sedfoam documentation https://sedfoam.github.io. Note that Sedfoam has evolved a lot in recent months (thanks to the developers of OpenFoam.com for their help and advice) |
#53 | |
I have another question that always makes me confused that the flow velocity in the 3DScour tutorial case is not specified since cyclic BC was used in the inlet and outlet in the 1D case. Thus, if I require exploring the effect of different flow velocities, how can it be achieved? |
#54 | |
Cyrille Bonamy
The associated one-dimensional case can be found in 1D subdirectory and the fluidfoam python package is used in order to generate the 1d_profil files which are necessary for funkySetFields (see Allrun.pre and Allrun). So, if you want to explore the effect of different flow velocities you have to change the velocity in the 1D case. In this 1D case, the flow is driven by a pressure gradient, that you can change via the variable gradPMean of the constant/forceProperties file (of the 1D case) : https://github.com/SedFoam/sedfoam/b...Properties#L19 |
#55 | |
#56 | |
Antoine MATHIEU
Rep Power: 8 ![]() |
You can not directly target the mean velocity in a boundary layer by changing the pressure gradient gradPMEAN in constant/forceProperties. Wath you can do is to change gradPMEAN to match a given bottom friction velocity "utau" following: gradPMEAN = utau^2/h Regards, Antoine |
#57 | |
Thank you, Antoine. I must know the relationship regarding mean velocity. Where can I find the relevant literature or equations? |
#58 |
Masoumeh
Rep Power: 6 ![]() |
Dear friends
I can not resume my running with "mpirun -np 4 sedfoam -parallel" while I change my controldict for continuing based on the latest time of run. the error is: "mpirun was unable to find the specified executable file, and therefore did not launch the job. This error was first reported for process rank 0; it may have occurred for other processes as well." hope to guide me ![]() |
#59 | |
Cyrille Bonamy
So, just type : "mpirun -np 4 sedFoam_rbgh -parallel" ![]() |
#60 |
I am simulating a scouring problem in terms of my own structure. However, I always encountered some convergence issues and the results seem crazy. Due to the fact that I adopted ansys workbench to create geometry and mesh, also I specified symmetry BC on two sides of the domain, instead of cyclic used in the tutorial case. I am not sure that boundary condition will result in the wrong solution (see attachment, alpha.a at time 1 s). Alternatively, I tried to change cyclic to symmetry based on the original 3DScour case in the tutorial I also met the same problem but after I adjusted the cell number in the vertical direction, which improved the solution. I get stuck here. Do you have any ideas or comments? Appreciated. |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
use mixture model to simulate two-phase flow with phase change | dxm2008 | Fluent Multiphase | 5 | September 7, 2016 14:15 |
Free Surface Flow with Sediment Transport | M. Riffai | CFX | 3 | September 5, 2013 09:45 |
How do model two phase granular flow in Porous media? | bahman | FLUENT | 1 | December 6, 2012 04:39 |
Transitional Flow Shear Stress Transport (SST) k-omega Turbulence Model | josechen | FLUENT | 0 | July 20, 2011 16:06 |
