[swak4Foam] How to compute total power released by chemical reaction
Old   October 1, 2018, 19:09
Default How to compute total power released by chemical reaction
Jeff
jf_vt is on a distinguished road
Hi
With reactingFoam, I need to know at each time step the total power released by chemical reactions.
The field dQ provides the power released in each cell so I need to sum dQ on all cells.
I try with swak4Foam field expression:
{type swakExpression;
   valueType internalField;
   verbose true;
   expression "dQ";
   writeStartTime no;
   accumulations (sum); }
and get the error:
--> FOAM FATAL ERROR:
 Parser Error for driver FieldValueExpressionDriver at "1.1-2" :"field dQ not existing or of wrong type"
"dQ"
There is a discussion on this forum about this error message but this was related to a custom code.
This happens with 2DcounterFlame tutorial
I understand that this might be related to the fact that dQ has not be created when the function Object calls it ( I am not sure of this) but on the other hand I dont see any options to wait for it.
I tested other fields and they all worked fine with the function object above.
What do I miss?
What are the options to calculate sum(dQ) at runtime for each time step?
Thanks
JF
jf_vt is offline   Reply With Quote
Compute the power of small wind turbine. Luolin FLUENT 9 May 27, 2013 15:52
Setting Chemical Reaction usker Siemens 2 April 29, 2009 10:21
Specifying a chemical reaction hagupta CFX 3 March 22, 2006 02:46
Simpler Chemical Reaction Problem Sam Siemens 7 February 7, 2006 10:28
as to chemical reaction simulation Jun von Wang FLUENT 0 July 7, 2005 06:47
