[swak4Foam] "out of memory" error while running funkySetFields |
October 1, 2018, 06:43 |
Jeff
Rep Power: 10 |
Hi
When trying to run funlySet fields ( Ubuntu 16.04 fe 4.1 swak4foam 0.4.2),Atter the message telling what funky is going to do I get the following: Code:
new cannot satisfy memory request. This does not necessarily mean you have run out of virtual memory. It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library Aborted (core dumped) I think my config is "up to date" any suggestion on what I could do or check to fix this? Thanks JF |
ANSYS Licensing Problem, Processes Running but Showing as Not Running | penguinman | ANSYS | 3 | September 27, 2016 14:30 |
Something weird encountered when running OpenFOAM in parallel on multiple nodes | xpqiu | OpenFOAM Running, Solving & CFD | 2 | May 2, 2013 05:59 |
[swak4Foam] Running funkySetFields | sara | OpenFOAM Community Contributions | 10 | October 3, 2012 11:08 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 10:38 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 08:52 |
