[swak4Foam] Using funkySetFields gives error when initialising pressure field |
September 21, 2018, 10:12 |
Rep Power: 8 |
I am trying to use funkySetFields to initialise a zero pressure field everywhere throughout the domain with the command funkySetFields -field p -expression '0' -time 0 And I get the error: --> FOAM FATAL ERROR: Inconsistent expression and condition. Expression "0" is defined on the faces while condition "true" is defined on faces From funciton doAnExpression() in file funkySetFields.C at line 381 FOAM exiting I have not come across this error in other forum questions. Any ideas? |
funkysetfields |
Another discussion on velocity-pressure coupling | toodles | Main CFD Forum | 16 | January 6, 2018 15:45 |
Varying Pressure Outlet with Field Function | t8fanning | STAR-CCM+ | 14 | November 1, 2017 11:39 |
Ocean pressure field problem | luisao | FLUENT | 1 | May 11, 2017 11:20 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 12:26 |
