September 21, 2018, 09:38 |
Running test case of PATO
Anshul
Rep Power: 8 |
PATO is porous ablative material toolbox for OpenFOAM made Open source by NASA .
I am encountering some trouble while running the tutorial cases provided with it . The solver crashes when it reaches the chemkinReader . It isn't able to read the chemkin files . I even tried to first convert the chemkin files to openfoam format using chemkinToFoam , but it didn't work either. I am not able to get what is causing the error. I fanyone has used it please help! Thanks |
ablation, chemkinreader, chemkintofoam, pato, porous domain |
Large test case for running OpenFoam in parallel | fhy | OpenFOAM Running, Solving & CFD | 23 | April 6, 2019 10:55 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
XiFoam Non reactive test case | Stefano Puggelli | OpenFOAM Running, Solving & CFD | 1 | July 9, 2015 03:24 |
Wrong adjoint solution ONERA M6 euler test case | JanH | SU2 | 6 | March 6, 2015 12:58 |
The turbulent swirling flow test case - Dellenback | dogan | Main CFD Forum | 0 | February 27, 2013 09:10 |
