[openFuelCell] pemfcSinglePhaseModel-4.0 on OpenFOAM
Like Tree13Likes
Old   April 25, 2019, 04:10
Muhammad
muhammadlr95 is on a distinguished road
Thanks Hans, it worked!
muhammadlr95 is offline   Reply With Quote
Old   May 19, 2020, 09:31
swsyoon is on a distinguished road
Hello
It seems the last post about this model is almost a year ago. I recently tried to use this pemfc model in openfoam4 and was able to compile it according to the earlier post. However when I tried to run the main script by typing ' make run' in run directory, I got this error.
I ran blockMesh command to generate mesh file but I cannot see the 'cellRegionAddressing' file that the error message is referring to.
Can you help to fix this issue ?
Thanks,
( pemfcSinglephaseNonIsothermalSolver | tee log.run );
| \\ / O peration | Version: 4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 4.0
Exec : pemfcSinglephaseNonIsothermalSolver
Date : May 19 2020
Time : 08:22:14
Host : "ws-Satellite-L655"
PID : 6511
Case : /home/ws/OpenFOAM/ws-4.0/run/pemfcSinglePhaseModel-4.0/run
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading cell properties
galvanostatic run
V = V [1 2 -3 0 0 -1 0] 0.6
Ibar0 = Ibar0 [0 -2 0 0 0 1 0] 7000
Rhat = Rhat [1 4 -3 0 0 -2 0] 1e-05
Rhat0 = Rhat0 [1 4 -3 0 0 -2 0] 1e-05
CL electronic conductivity(kappaCl) = kappaCl [-1 -2 3 0 0 2 0] 1000
GDL electronic conductivity(kappaGdl) = kappaGdl [-1 -2 3 0 0 2 0] 5000
GDL - BP Contact resistance (rContact)= rContact [1 4 -3 0 0 -2 0] 2e-06
BP electronic conductivity(kappaBp) = kappaBp [-1 -2 3 0 0 2 0] 83000
CL thickness (tCl) = tCl [0 1 0 0 0 0 0] 3.7e-06
GDL thickness (tGdl) = tGdl [0 1 0 0 0 0 0] 0.00041
BP thickness (tBp) = tBp [0 1 0 0 0 0 0] 0.003
concentration overpotential constant = etaConCaConstant [0 0 0 0 0 0 0] 0.25
Tinit = Tinit [0 0 0 1 0 0 0] 353
anodeName = fuel_to_electrolyte
fuelInletName = fuelInlet
fuelOutletName = fuelOutlet
fuelAbpName = fuel_to_abp
cathodeName = air_to_electrolyte
airInletName = airInlet
airOutletName = airOutlet
airCbpName = air_to_cbp
electrolyteAnodeName = electrolyte_to_fuel
electrolyteCathodeName = electrolyte_to_air
abpFuelName = abp_to_fuel
cbpAirName = cbp_to_air
Reading cell field T
Reading cell field k
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/ws/OpenFOAM/ws-4.0/run/pemfcSinglePhaseModel-4.0/run/constant/abp/polyMesh/cellRegionAddressing at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 72.
FOAM exiting
ramakant likes this.
swsyoon is offline   Reply With Quote
Old   May 20, 2020, 02:58
Ramakant Gadhewal
Location: Chemical Engineering,National Institute of Technology,Warangal (T.S.),India
ramakant is on a distinguished road
Originally Posted by swsyoon View Post
Hello
Thanks,
Build : 4.0
Date : May 19 2020
Time : 08:22:14
PID : 6511
nProcs : 1
Create time
galvanostatic run
cannot find file
FOAM exiting
Yes...I can help you
please follow the steps to run the program and it is working fine for me.
My email id:ramakantgadhewal@gmail.com
mariduake likes this.
ramakant is offline   Reply With Quote
Old   November 10, 2020, 03:27
Maricarmen Duarte Ake
mariduake is on a distinguished road
I'm also checking this code. I'm new to OpenFoam, I used the Fluent module, but I wanted to check this open source software. My question is, do you upload a geometry? because I can't find it in the files. I am reading about meshing here https://www.cfd.at/downloads/FoamTut...ExampleTwo.pdf
So, if I want to run this code, d I have to make my own geometry? Sorry I was accustomed with Fluent. Thank you in advance with your response.
mariduake is offline   Reply With Quote
Old   November 10, 2020, 05:28
Ramakant Gadhewal
Please check it Geometry is already there.
Old   December 2, 2020, 05:11
Mattia
mat16 is on a distinguished road
Originally Posted by wyldckat View Post
Greetings to all,
I've split off from the OpenFuelCell thread, the posts that are referring to the package provided here: http://dx.doi.org/10.17632/3gz7pxznzn.1
Apparently that ZIP file was somehow corrupted by someone in the middle... what I mean is that the file "lib/myPatchToPatchInterpolation/mypatchToPatchInterpolation.H" was replaced by the content from "lib/myPatchToPatchInterpolation/myPatchToPatchInterpolation.H", which is why this problem is occurring. It's possible to recover the broken file, by using the original code "patchToPatchInterpolation.H" from OpenFOAM 4.0 as a basis.
After downloading the ZIP file, I've ran the following commands, in order to be able to compile the code with OpenFOAM 4.0, along with the necessary corrections:
unzip pemfcSinglePhaseModel-4.0.zip
cd pemfcSinglePhaseModel-4.0
cd pemfcSinglePhaseNonIsothermalSolver
find -name "All*" | xargs chmod +x
cp $FOAM_SRC/OpenFOAM/interpolations/patchToPatchInterpolation/patchToPatchInterpolation.H lib/myPatchToPatchInterpolation/mypatchToPatchInterpolation.H
sed -i -e 's=patchToPatchInterpolation=mypatchToPatchInterpolation=g'  -e 's=PatchToPatchInterpolation=myPatchToPatchInterpolation=g' lib/myPatchToPatchInterpolation/mypatchToPatchInterpolation.H
./Allwmake > log.make 2>&1
./Allwmake > log.make2 2>&1
The last 2 commands will create 2 log files: "log.make" and "log.make2", where the second file should have something like this inside:
..../libSinglephasePEMFC.so' is up to date.
.../pemfcSinglephaseNonIsothermalSolver' is up to date.
Best regards,
Bruno
Hey everyone,
I downloaded the version of OpenFoam 4.0 on ubuntu 16.04.
https://openfoamwiki.net/index.php/I...OAM-4.0/Ubuntu
I have followed this procedure but it gives me the same error.
Also during the unzip of the file it asks me:
I do yes and it opens correctly.
Someone help me?
Thanks in advance
mat16 is offline   Reply With Quote
Old   December 2, 2020, 07:20
I installed the same and i didn't have any problem compiling. I copied wyldckat instructions line by line and it worked out fine. I got the logs correctly. This is what I did:
1. After instalation I ran mkdir -p $FOAM_RUN
2. I copied the zip to the user4.0/run folder
3. I ran the commands line by line and it compiled just fine.
Old   December 2, 2020, 07:23
Question Error after compiling on the abp
  #28
Do you have any idea why i have this error. I followed instructions, I even installed OF4.0 instead of 4.1 but I got the same error.
Build : 4.0
Date : Dec 02 2020
Time : 05:01:29
Host : "fat-HP-625"
PID : 23372
Case : /home/fat/OpenFOAM/fat-4.0/run/pemfcSinglePhaseModel-4.0/run
nProcs : 1
Create time
galvanostatic run
--> FOAM FATAL ERROR:
Cannot find file "points" in directory "abp/polyMesh" in times 0 down to constant
From function Foam::word Foam::Time::findInstance(const Foam::fileName&, const Foam::word&, Foam::IOobject::readOption, const Foam::word&) const
in file db/Time/findInstance.C at line 182.
FOAM exiting
Old   December 2, 2020, 11:34
Mattia
Hi Maricarmen,
It worked!
Many thanks for your support!
Best regards
Old   December 16, 2020, 19:14
Post Modification
  #30
Has anyone tried to modify the fuel? What happens if I change H2 for CH3OH? I think for Methanol model the cathode remains the same, but the anode equations are modified. Has anyone tried to do so?
Old   December 17, 2020, 06:23
Ramakant Gadhewal
Are you writing code for DMFC in OpenFOAM? or trying to modify the PEM fuel cell code?
Old   December 17, 2020, 14:18
I'm trying to modify it. I know there are other phenomena but I just want to check how this can be done. I saw someone modified the Fluent pem fuel cell module but it didn't say how they did it.
Old   December 17, 2020, 14:36
Ramakant Gadhewal
Could you please share the Fluent file?
Old   December 19, 2020, 12:35
Mattia
I changed the geometry and I have the same error as you.
Can someone help me?
Thank you.
Old   December 20, 2020, 17:36
Default Compiling error pemfcSinglePhaseModel-4.0
  #35
Jose
jose.ceballos is on a distinguished road
Greetings to all,
Best regards,
Bruno
I've followed the instructions, and it seems the previous errror is fixed. But I can't obtaint the up date message, instead I got this message:
+ cd lib
+ ./Allwmake
+ wmake libso
'/home/cicy/OpenFOAM/cicy-4.x/platforms/linux64GccDPInt32Opt/lib/libSinglephasePEMFC.so' is up to date.
+ pwd
/home/cicy/OpenFOAM/cicy-4.x/run/pemfcSinglePhaseModel-4.0/pemfcSinglePhaseNonIsothermalSolver
+ cd applications
+ wmake
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -g -I../src/constants -I../src/createFields -I../src/createMesh -I../src/createSpecies -I../src/diffusivity -I../src/electrochemistry -I../src/energyTransport -I../src/mapping -I../src/momentumTransport -I../src/multiSpeciesTransport -I../src/patch -I../src/physicalProperties -I../src/readParameters -I../src/readProperties -I../src/tools/functions -I../src/tools/functionIntegration -I../src/tools/ReynoldsNumber -I../src/tools/RiddersRoot -I../src/tools/varInit -I../lib/lnInclude -I/home/cicy/OpenFOAM/OpenFOAM-4.x/src/finiteVolume/lnInclude -I/home/cicy/OpenFOAM/OpenFOAM-4.x/src/meshTools/lnInclude -I/home/cicy/OpenFOAM/OpenFOAM-4.x/src/thermophysicalModels/specie/lnInclude  -IlnInclude -I. -I/home/cicy/OpenFOAM/OpenFOAM-4.x/src/OpenFOAM/lnInclude -I/home/cicy/OpenFOAM/OpenFOAM-4.x/src/OSspecific/POSIX/lnInclude   -fPIC -c pemfcSinglephaseNonIsothermalSolver.C -o Make/linux64GccDPInt32Opt/pemfcSinglephaseNonIsothermalSolver.o
In file included from pemfcSinglephaseNonIsothermalSolver.C:104:0:
../src/patch/createPatchToPatchInterpolation.H: In function ‘int main(int, char**)’:
../src/patch/createPatchToPatchInterpolation.H:10:33: error: missing template arguments before ‘anodeToCathode’
     myPatchToPatchInterpolation anodeToCathode
../src/patch/createPatchToPatchInterpolation.H:16:33: error: missing template arguments before ‘cathodeToAnode’
     myPatchToPatchInterpolation cathodeToAnode
../src/patch/createPatchToPatchInterpolation.H:58:33: error: missing template arguments before ‘fuelAnodeToElectrolyteAnode’
     myPatchToPatchInterpolation fuelAnodeToElectrolyteAnode
../src/patch/createPatchToPatchInterpolation.H:64:33: error: missing template arguments before ‘airCathodeToElectrolyteCathode’
     myPatchToPatchInterpolation airCathodeToElectrolyteCathode
In file included from pemfcSinglephaseNonIsothermalSolver.C:141:0:
../src/electrochemistry/solveElectrochemistry.H:75:18: error: ‘anodeToCathode’ was not declared in this scope
                  anodeToCathode.faceInterpolate
../src/electrochemistry/solveElectrochemistry.H:75:18: note: suggested alternative: ‘anodePatch’
                  anodePatch
In file included from ../src/electrochemistry/ASRfunction.H:8:0,
                 from ../src/electrochemistry/solveElectrochemistry.H:158,
../src/electrochemistry/sigmaElectrolyte.H:78:17: error: ‘anodeToCathode’ was not declared in this scope
     wActivity = anodeToCathode.faceInterpolate(wActivityAnode) + wActivityCathode;
../src/electrochemistry/sigmaElectrolyte.H:78:17: note: suggested alternative: ‘pSatCathode’
                 pSatCathode
../src/electrochemistry/solveElectrochemistry.H:251:18: error: ‘cathodeToAnode’ was not declared in this scope
                  cathodeToAnode.faceInterpolate(mflux[s])*(1.0 - YsBC);
../src/electrochemistry/solveElectrochemistry.H:251:18: note: suggested alternative: ‘cathodeZones’
                  cathodeZones
../src/electrochemistry/solveElectrochemistry.H:274:11: error: ‘cathodeToAnode’ was not declared in this scope
          -cathodeToAnode.faceInterpolate(mfluxSum)
../src/electrochemistry/solveElectrochemistry.H:274:11: note: suggested alternative: ‘cathodeZones’
           cathodeZones
/home/cicy/OpenFOAM/OpenFOAM-4.x/wmake/rules/General/transform:8: recipe for target 'Make/linux64GccDPInt32Opt/pemfcSinglephaseNonIsothermalSolver.o' failed
make: *** [Make/linux64GccDPInt32Opt/pemfcSinglephaseNonIsothermalSolver.o] Error 1
I've now installed OF4.X in Ubuntu 18.04 Windows Bash....
jose.ceballos is offline   Reply With Quote
Old   December 20, 2020, 19:20
Default Request pemfcSinglePhaseModel-4.0.zip
  #36
Jose
Someone could upload the pemfcSinglePhaseModel-4.0 fixed to downloand it?
Old   December 14, 2022, 04:17
Default parallel running
  #37
Pratik
Pratik_21 is on a distinguished road
Did anyone try running this code in parallel ?
Pratik_21 is offline   Reply With Quote
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
[OpenFOAM.org] OpenFOAM 4.0, bad option -t in zsh rdbisme OpenFOAM Installation 3 December 30, 2016 13:10
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days joegi.geo OpenFOAM Announcements from Other Sources 0 October 1, 2016 20:20
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 14, 2016 11:19
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
