[swak4Foam] multiple expressions in one swakExpression
Old   September 7, 2018, 10:48
Default multiple expressions in one swakExpression
Fynn
PanPeter is on a distinguished road
Hi Foamers,
I'm measuring flow in both directions through a surface using swak.
Here I'm interested in (1) the gross flow rate, (2,3) the flow rate in either direction.
That works fine if I'm defining three different swakExressions, which create three different postProcessing files. I would rather have just one file, in which all three flow rates are saved, so that foamMonitor plots these three flow rates simultaneously.
Is there a way to set up my swakExpression to write out my three swakExpressions?
Thanks for your help!
cheers
Fynn
PanPeter is offline   Reply With Quote
foammonitor, swakexpression
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs Pier84 OpenFOAM Installation 4 June 18, 2016 17:22
[cfMesh] Regular expressions in cfMesh rama13 OpenFOAM Community Contributions 6 June 7, 2015 18:01
[ICEM] Multiple edges asal ANSYS Meshing & Geometry 2 March 22, 2013 11:10
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
