[swak4Foam] swak expressionField having troubles on mixingPlanes |
September 5, 2018, 09:45 |
Marian
im using swak to calculate the velocity in cylindar coordinates in runtime for further calculations. Therefor I compared the swak-calculated values with the results using convertToCylindrical and realised, that on patches having an mixingplane as boundary condition these values are not the same . I'm running the simulation with foam-ext 3.1 using swak4Foam-0.3.1. Checking the values with ParaView 4.4 in the field showed, that the swak-values are everywhere conform to the ones calculated by convertToCylindrical except the ones on the mixingPlane patches. (faceSets e.g. are ok (check faceSet INLETZONE_OUTLET_face e.g.) Finally I wanted to check if the used cartesian velocity values cause the problem. Therefore I simply did no transformation (expression "U";) which produced swak-values identical to the common "U" values, even on the mixingPlane patches. To calculate cylindrical velocity, I used the following function: functions ( compute_VCyl { type expressionField; fieldName VCyl; dimension [0 1 -1 0 0 0 0]; variables ( "xVariable= pos().x;" "yVariable= pos().y;" "Polarwinkel= 0;" "Polarwinkel=(xVariable>0)?atan(yVariable/xVariable):Polarwinkel;" "Polarwinkel=(yVariable>=0&&xVariable<0)?pi+atan(y Variable/xVariable):Polarwinkel;" "Polarwinkel=(yVariable<0&&xVariable<0)?-pi+atan(yVariable/xVariable):Polarwinkel;" "Polarwinkel=(yVariable>0&&xVariable==0)?pi/2:Polarwinkel;" "Polarwinkel=(yVariable<0&&xVariable==0)?-pi/2:Polarwinkel;" "A= tensor(cos(Polarwinkel),sin(Polarwinkel),0,-sin(Polarwinkel),cos(Polarwinkel),0,0,0,1);" ); expression "A&U"; autowrite true; outputControl timeStep; outputInterval 1; } ); libs ( "libOpenFoamTurbo.so" "libswakFunctionObjects.so" ); This is part of the controlDict in the small testcase "cylindrical", which shows the Problem. You can download it from https://github.com/mjans/swak_mixingplane.git There is also the case "cylindrical_ggi" where all mixingPlanes are replaced by ggi and the case "cylindrical_notrafo" writing the velocity U to V using the mentioned swak-function. If anyone knows something about that or can help me with this, I'd be very happy. Thanks Marian |
cylindar coordinates, error, mixingplane, swak4foam |
[swak4Foam] Using fieldAverage together with swak4foam expressionField | tiam | OpenFOAM Community Contributions | 33 | December 18, 2016 08:49 |
[swak4Foam] swakFoam - expressionField | marluc | OpenFOAM Community Contributions | 1 | April 22, 2015 13:50 |
Problems creating a volScalarField with expressionField function-object | zfaraday | OpenFOAM Running, Solving & CFD | 2 | January 12, 2015 08:49 |
[swak4Foam] expressionField | aylalisa | OpenFOAM Community Contributions | 1 | October 28, 2014 18:42 |
Some troubles about TestCases | codezy | SU2 | 2 | March 26, 2014 05:10 |
