[waves2Foam] Wave damped totally in about 5 meters after wave maker, after making changes to case
Old   August 10, 2015, 06:40
Default Wave damped totally in about 5 meters after wave maker, after making changes to case
moh
mmbeik is on a distinguished road
Dear Niels
I ran wave flume tutorial and then in that case I changed wave period from 1.5s to 0.64s and changed wave height to 0.002m. In result wave damped totally in about 5 meters after wave maker! Considering that relaxation zone parameters have not been changed. In another case I lengthen the flume to 54m and again wave existed only about 18m and after that totally damped. Also in all cases the U(0) is decreasing continuously in flume length.
Would you please help me and give me some introduction about defining relaxation zone parameters more than openfoamwiki contents.
Thank you in advance,
sorry for my poor english
mmbeik is offline   Reply With Quote
Old   August 11, 2015, 05:52
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hallo Mmbeik,
You should clearly think of the number of cells per wave length. The original waveFlume tutorial has a wave period of 2 s, whereas you are using 0.64 s. Applying the dispersion relation you find a decrease of the wave length by a factor of ~6 (!) without a corresponding increase in the mesh resolution. This must lead to very rapid dissipation of the wave.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   August 15, 2015, 05:09
moh
Originally Posted by ngj View Post
Hallo Mmbeik,
Kind regards,
Niels
Hi Niels
Thank you for responding,Actually I increased mesh resolution as you said, but the result did not changed and the wave damped totally after a while.
Regards,
Moh
Old   August 18, 2015, 06:56
ngj
Good morning Moh,
I do not know, whether you expected a response based on your latest post, but there is not anything to work with. If you would like to have the attention of the community, please adhere to the guidelines given in this post:
http://www.cfd-online.com/Forums/ope...-get-help.html
Kind regards,
Niels
Ship Wave Making Resistance Yasser CFX 8 May 27, 2017 09:28
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
making a case all aver again Ossi Siemens 3 September 22, 2001 08:13
