[waves2Foam] Tripping over several build issues with OpenFOAM 2.1.1 |
December 20, 2015, 04:29 |
Yage
Rep Power: 12 |
Dear Niels,
I am very interested in your work waves2foam and I am confused about the compilation at the moment. 1. I modified the interFoam according to waves2foam wiki, and then? where should I locate it? 2. I downloaded the wave2Foam ( Revision 2085) online from GitHub (my Ubuntu cannot get access to internet at the moment)and edited the bin/bashrc file to point to the path /home/yage/waes2Foam-master, where wave2Foam is located. My OpenFOAM version is 2.1.1 But when I run: bash Allwmake. I got the following error message: Code:
Allwmake: line 42: ./Allwmake: Permission denied problems with the compilation of the third party dependencies Code:
===================================== COMPILE SOLVERS ===================================== linux64GccDPOpt/options:21: *** missing separator. Stop. wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/yage/waves2Foam-master/applications/solvers/solvers211/interFoam Making dependency list for source file porousWaveFoam.C could not open file wavesPorosityModel.H for source file porousWaveFoam.C could not open file relaxationZone.H for source file porousWaveFoam.C could not open file externalWaveForcing.H for source file porousWaveFoam.C could not open file readWaveProperties.H for source file porousWaveFoam.C could not open file createExternalWaveForcing.H for source file porousWaveFoam.C could not open file createPorosityFields.H for source file porousWaveFoam.C could not open file calcPorosity.H for source file porousWaveFoam.C SOURCE=porousWaveFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/transportModels -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/transportModels/incompressible/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/transportModels/interfaceProperties/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/turbulenceModel -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/meshTools/lnInclude -DOFVERSION=211 -DEXTBRANCH=0 -I/home/yage/waves2Foam-master/src/waves2Foam/lnInclude -I/home/yage/waves2Foam-master/src/waves2FoamSampling/lnInclude -I/home/yage/waves2Foam-master/src/waves2FoamPorosity/lnInclude -I/usr/include -IlnInclude -I. -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/porousWaveFoam.o porousWaveFoam.C:53:32: fatal error: wavesPorosityModel.H: No such file or directory compilation terminated. make: *** [Make/linux64GccDPOpt/porousWaveFoam.o] Error 1 SOURCE=waveFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/transportModels -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/transportModels/incompressible/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/transportModels/interfaceProperties/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/turbulenceModel -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -DOFVERSION=211 -DEXTBRANCH=0 -I/home/yage/waves2Foam-master/src/waves2Foam/lnInclude -I/home/yage/waves2Foam-master/src/waves2FoamSampling/lnInclude -I/usr/include -IlnInclude -I. -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/waveFoam.o waveFoam.C:49:28: fatal error: relaxationZone.H: No such file or directory compilation terminated. make: *** [Make/linux64GccDPOpt/waveFoam.o] Error 1 ===================================== COMPILE PRE-PROCESSING ===================================== Making dependency list for source file faceSetToSTL.C could not open file foamTime.H for source file faceSetToSTL.C make[1]: Entering directory `/home/yage/waves2Foam-master/applications/utilities/preProcessing/faceSetToSTL' SOURCE=faceSetToSTL.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/triSurface/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -DOFVERSION=211 -DEXTBRANCH=0 -IlnInclude -I. -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/faceSetToSTL.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/triSurface/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -DOFVERSION=211 -DEXTBRANCH=0 -IlnInclude -I. -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/faceSetToSTL.o -L/home/yage/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib \ -lOpenFOAM -ltriSurface -lfiniteVolume -lOpenFOAM -ldl -lm -o /home/yage/OpenFOAM/yage-2.1.1/platforms/linux64GccDPOpt/bin/faceSetToSTL make[1]: Leaving directory `/home/yage/waves2Foam-master/applications/utilities/preProcessing/faceSetToSTL' Making dependency list for source file relaxationZoneLayout.C could not open file foamTime.H for source file relaxationZoneLayout.C could not open file relaxationShape.H for source file relaxationZoneLayout.C could not open file relaxationWeight.H for source file relaxationZoneLayout.C could not open file readWaveProperties.H for source file relaxationZoneLayout.C make[1]: Entering directory `/home/yage/waves2Foam-master/applications/utilities/preProcessing/relaxationZoneLayout' SOURCE=relaxationZoneLayout.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/meshTools/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -DOFVERSION=211 -DEXTBRANCH=0 -I/home/yage/waves2Foam-master/src/waves2Foam/lnInclude -I/usr/include -IlnInclude -I. -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/relaxationZoneLayout.o relaxationZoneLayout.C:71:29: fatal error: relaxationShape.H: No such file or directory compilation terminated. make[1]: *** [Make/linux64GccDPOpt/relaxationZoneLayout.o] Error 1 make[1]: Target `/home/yage/OpenFOAM/yage-2.1.1/platforms/linux64GccDPOpt/bin/relaxationZoneLayout' not remade because of errors. make[1]: Leaving directory `/home/yage/waves2Foam-master/applications/utilities/preProcessing/relaxationZoneLayout' make: *** [relaxationZoneLayout] Error 2 Making dependency list for source file setWaveField.C could not open file foamTime.H for source file setWaveField.C could not open file setWaveField.H for source file setWaveField.C could not open file crossVersionCompatibility.H for source file setWaveField.C could not open file externalWaveForcing.H for source file setWaveField.C could not open file readWaveProperties.H for source file setWaveField.C could not open file createExternalWaveForcing.H for source file setWaveField.C make[1]: Entering directory `/home/yage/waves2Foam-master/applications/utilities/preProcessing/setWaveField' SOURCE=setWaveField.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/meshTools/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -DOFVERSION=211 -DEXTBRANCH=0 -I/home/yage/waves2Foam-master/src/waves2Foam/lnInclude -I/usr/include -IlnInclude -I. -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/setWaveField.o setWaveField.C:71:26: fatal error: setWaveField.H: No such file or directory compilation terminated. make[1]: *** [Make/linux64GccDPOpt/setWaveField.o] Error 1 make[1]: Target `/home/yage/OpenFOAM/yage-2.1.1/platforms/linux64GccDPOpt/bin/setWaveField' not remade because of errors. make[1]: Leaving directory `/home/yage/waves2Foam-master/applications/utilities/preProcessing/setWaveField' make: *** [setWaveField] Error 2 Making dependency list for source file setWaveParameters.C could not open file setWaveProperties.H for source file setWaveParameters.C make[1]: Entering directory `/home/yage/waves2Foam-master/applications/utilities/preProcessing/setWaveParameters' SOURCE=setWaveParameters.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -DOFVERSION=211 -DEXTBRANCH=0 -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/meshTools/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I/home/yage/waves2Foam-master/src/waves2Foam/lnInclude -I/home/yage/waves2Foam-master/src/waves2FoamProcessing/lnInclude -I/usr/include -IlnInclude -I. -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/setWaveParameters.o setWaveParameters.C:64:31: fatal error: setWaveProperties.H: No such file or directory compilation terminated. make[1]: *** [Make/linux64GccDPOpt/setWaveParameters.o] Error 1 make[1]: Target `/home/yage/OpenFOAM/yage-2.1.1/platforms/linux64GccDPOpt/bin/setWaveParameters' not remade because of errors. make[1]: Leaving directory `/home/yage/waves2Foam-master/applications/utilities/preProcessing/setWaveParameters' make: *** [setWaveParameters] Error 2 Making dependency list for source file waveGaugesNProbes.C could not open file foamTime.H for source file waveGaugesNProbes.C could not open file waveGauges.H for source file waveGaugesNProbes.C make[1]: Entering directory `/home/yage/waves2Foam-master/applications/utilities/preProcessing/waveGaugesNProbes' SOURCE=waveGaugesNProbes.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/meshTools/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I/home/yage/waves2Foam-master/src/waves2Foam/lnInclude -I/home/yage/waves2Foam-master/src/waves2FoamProcessing/lnInclude -I/usr/include -DOFVERSION=211 -DEXTBRANCH=0 -IlnInclude -I. -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/waveGaugesNProbes.o waveGaugesNProbes.C:61:24: fatal error: waveGauges.H: No such file or directory compilation terminated. make[1]: *** [Make/linux64GccDPOpt/waveGaugesNProbes.o] Error 1 make[1]: Target `/home/yage/OpenFOAM/yage-2.1.1/platforms/linux64GccDPOpt/bin/waveGaugesNProbes' not remade because of errors. make[1]: Leaving directory `/home/yage/waves2Foam-master/applications/utilities/preProcessing/waveGaugesNProbes' make: *** [waveGaugesNProbes] Error 2 make: Target `application' not remade because of errors. ===================================== COMPILE POST-PROCESSING ===================================== Making dependency list for source file postProcessWaves2Foam.C could not open file foamTime.H for source file postProcessWaves2Foam.C could not open file postProcessingWaves.H for source file postProcessWaves2Foam.C make[1]: Entering directory `/home/yage/waves2Foam-master/applications/utilities/postProcessing/postProcessWaves2Foam' SOURCE=postProcessWaves2Foam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/meshTools/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I/home/yage/waves2Foam-master/src/waves2Foam/src/lnInclude -I/home/yage/waves2Foam-master/src/waves2FoamProcessing/lnInclude -I/usr/include -DOFVERSION=211 -DEXTBRANCH=0 -IlnInclude -I. -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/postProcessWaves2Foam.o postProcessWaves2Foam.C:59:33: fatal error: postProcessingWaves.H: No such file or directory compilation terminated. make[1]: *** [Make/linux64GccDPOpt/postProcessWaves2Foam.o] Error 1 make[1]: Target `/home/yage/OpenFOAM/yage-2.1.1/platforms/linux64GccDPOpt/bin/postProcessWaves2Foam' not remade because of errors. make[1]: Leaving directory `/home/yage/waves2Foam-master/applications/utilities/postProcessing/postProcessWaves2Foam' make: *** [postProcessWaves2Foam] Error 2 Making dependency list for source file surfaceElevation.C could not open file IOsampledSurfaceElevation.H for source file surfaceElevation.C could not open file sampledSurfaceElevation.H for source file surfaceElevation.C could not open file readWaveProperties.H for source file surfaceElevation.C make[1]: Entering directory `/home/yage/waves2Foam-master/applications/utilities/postProcessing/surfaceElevation' SOURCE=surfaceElevation.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/meshTools/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/sampling/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/lagrangian/basic/lnInclude -DOFVERSION=211 -DEXTBRANCH=0 -I/home/yage/waves2Foam-master/src/waves2Foam/lnInclude -I/home/yage/waves2Foam-master/src/waves2FoamSampling/lnInclude -I/usr/include -IlnInclude -I. -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/yage/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/surfaceElevation.o surfaceElevation.C:89:39: fatal error: IOsampledSurfaceElevation.H: No such file or directory compilation terminated. make[1]: *** [Make/linux64GccDPOpt/surfaceElevation.o] Error 1 make[1]: Target `/home/yage/OpenFOAM/yage-2.1.1/platforms/linux64GccDPOpt/bin/surfaceElevation' not remade because of errors. make[1]: Leaving directory `/home/yage/waves2Foam-master/applications/utilities/postProcessing/surfaceElevation' make: *** [surfaceElevation] Error 2 make: Target `application' not remade because of errors. ===================================== COMPILATION DONE ===================================== Many thanks REgards, Y |
December 20, 2015, 05:40 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Good morning Yage,
I appears that you are having permission issues with the compilation. The first step is to install the ThirdParty dependencies. The entire compilation process will break, if you do not succeed with this step. Furthermore, since you are using version 2.1.1., there is no need for you to modify interFoam, because waveFoam is already provided with waves2Foam for this version of OpenFoam. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
December 20, 2015, 06:01 |
#3 | |
Yage
Rep Power: 12 |
THanks for your reply. I try to wmake each step (ThirdParty, Library, Solver..) separately and it works! Regards, Yage |
December 20, 2015, 07:53 |
#4 | |
Yage
Rep Power: 12 |
I finish the compilation and I got another problem: Code:
Reading g Reading waveProperties Reading waveProperties Reading field alpha Reading field U Reading field p Setting the wave field ... I use potentialcurrent only for the inlet. The following is the CheckMesh: Code:
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 2702654 faces: 7780606 internal faces: 7662569 cells: 2540385 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 2459510 prisms: 4467 wedges: 0 pyramids: 0 tet wedges: 14 tetrahedra: 0 polyhedra: 76394 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology frontAndBack 19176 19714 ok (non-closed singly connected) inlet 7520 7745 ok (non-closed singly connected) outlet 7520 7745 ok (non-closed singly connected) lowerWall 2040 2132 ok (non-closed singly connected) atmosphere 2040 2132 ok (non-closed singly connected) blade_bladecoarse 79741 82074 ok (closed singly connected) Checking geometry... Overall domain bounding box (-1 -1 -1.5) (1.55 0.6 0.5) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (4.53135e-16 7.49871e-15 1.4504e-16) OK. Max cell openness = 4.41973e-16 OK. Max aspect ratio = 7.81186 OK. Minumum face area = 3.77004e-07. Maximum face area = 0.0031875. Face area magnitudes OK. Min volume = 4.14209e-10. Max volume = 0.000125014. Total volume = 8.1593. Cell volumes OK. Mesh non-orthogonality Max: 50.7064 average: 5.85569 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.16831 OK. Coupled point location match (average 0) OK. Mesh OK. End Yage |
#5 | |
Yage
Rep Power: 12 |
December 21, 2015, 02:21 |
Rep Power: 37 |
Good morning Yage,
Without an error message, it is impossible to say what the problem could be. But, are you sure that it is not just taking some time, because you have 2.5M cells? Kind regards, Niels
Rep Power: 37 |
Good morning Yage,
December 21, 2015, 05:22 |
#8 | |
Yage
Rep Power: 12 |
This is no error messages coming out, it just "stuck" there. I waited 2 hours yesterday and will try to give it some more time today to see if it works. thanks for your suggestion Regards, Yage |
#9 | |
Yage
Rep Power: 12 |
December 23, 2015, 19:58 |
#10 |
Yage
Rep Power: 12 |
Dear Neils
I re-try the setWaveField untility and it works without any delay, I dont know why... Another thing is I would like to build up the waves2foam on my university cluster but it is not compiled correctly. The thirdparty and library are built up successfully but the solver and utilities failed. Code:
Making dependency list for source file porousWaveFoam.C could not open file incompressibleTwoPhaseMixture.H for source file porousWaveFoam.C SOURCE=porousWaveFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/transportModels -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/transportModels/incompressible/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/transportModels/interfaceProperties/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/incompressible/turbulenceModel -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/fvOptions/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/sampling/lnInclude -DOFVERSION=220 -DEXTBRANCH=0 -DXVERSION=0 -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamSampling/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamPorosity/lnInclude -I/local/software/gsl/1.15/include -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/porousWaveFoam.o /scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/readTimeControls.H: In function 'int main(int, char**)': /scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/readTimeControls.H:38:8: warning: unused variable 'maxDeltaT' [-Wunused-variable] g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/transportModels -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/transportModels/incompressible/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/transportModels/interfaceProperties/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/incompressible/turbulenceModel -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/fvOptions/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/sampling/lnInclude -DOFVERSION=220 -DEXTBRANCH=0 -DXVERSION=0 -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamSampling/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamPorosity/lnInclude -I/local/software/gsl/1.15/include -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/porousWaveFoam.o -L/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \ -linterfaceProperties -ltwoPhaseInterfaceProperties -lincompressibleTransportModels -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -lmeshTools -lfvOptions -lsampling -L/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/lib -lwaves2Foam -lwaves2FoamSampling -lwaves2FoamPorosity -L/local/software/gsl/1.15/lib -lgsl -lgslcblas -lOpenFOAM -ldl -lm -o /home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/porousWaveFoam /usr/bin/ld: cannot find -lwaves2Foam collect2: ld returned 1 exit status make: *** [/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/porousWaveFoam] Error 1 Making dependency list for source file waveFoam.C SOURCE=waveFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/transportModels -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/transportModels/incompressible/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/transportModels/interfaceProperties/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/incompressible/turbulenceModel -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/fvOptions/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/sampling/lnInclude -DOFVERSION=220 -DEXTBRANCH=0 -DXVERSION=0 -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamSampling/lnInclude -I/local/software/gsl/1.15/include -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/waveFoam.o /scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/readTimeControls.H: In function 'int main(int, char**)': /scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/readTimeControls.H:38:8: warning: unused variable 'maxDeltaT' [-Wunused-variable] g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/transportModels -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/transportModels/incompressible/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/transportModels/interfaceProperties/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/turbulenceModels/incompressible/turbulenceModel -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/fvOptions/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/sampling/lnInclude -DOFVERSION=220 -DEXTBRANCH=0 -DXVERSION=0 -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamSampling/lnInclude -I/local/software/gsl/1.15/include -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/waveFoam.o -L/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \ -linterfaceProperties -ltwoPhaseInterfaceProperties -lincompressibleTransportModels -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -lmeshTools -lfvOptions -lsampling -L/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/lib -lwaves2Foam -lwaves2FoamSampling -L/local/software/gsl/1.15/lib -lgsl -lgslcblas -lOpenFOAM -ldl -lm -o /home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/waveFoam /usr/bin/ld: cannot find -lwaves2Foam collect2: ld returned 1 exit status make: *** [/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/waveFoam] Error 1 ===================================== COMPILE PRE-PROCESSING ===================================== Making dependency list for source file faceSetToSTL.C could not open file foamTime.H for source file faceSetToSTL.C make[1]: Entering directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/preProcessing/faceSetToSTL' SOURCE=faceSetToSTL.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/triSurface/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -DOFVERSION=220 -DEXTBRANCH=0 -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/faceSetToSTL.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/triSurface/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -DOFVERSION=220 -DEXTBRANCH=0 -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/faceSetToSTL.o -L/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \ -lOpenFOAM -ltriSurface -lfiniteVolume -lOpenFOAM -ldl -lm -o /home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/faceSetToSTL /scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libtriSurface.so: undefined reference to `std::__throw_out_of_range_fmt(char const*, ...)@GLIBCXX_3.4.20' /scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `std::__throw_out_of_range_fmt(char const*, ...)' collect2: ld returned 1 exit status make[1]: *** [/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/faceSetToSTL] Error 1 make[1]: Leaving directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/preProcessing/faceSetToSTL' make: *** [faceSetToSTL] Error 2 Making dependency list for source file relaxationZoneLayout.C could not open file foamTime.H for source file relaxationZoneLayout.C make[1]: Entering directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/preProcessing/relaxationZoneLayout' SOURCE=relaxationZoneLayout.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -DOFVERSION=220 -DEXTBRANCH=0 -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/local/software/gsl/1.15/include -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/relaxationZoneLayout.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -DOFVERSION=220 -DEXTBRANCH=0 -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/local/software/gsl/1.15/include -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/relaxationZoneLayout.o -L/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \ -lfiniteVolume -L/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/lib -lwaves2Foam -L/local/software/gsl/1.15/lib -lgsl -lgslcblas -lOpenFOAM -ldl -lm -o /home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/relaxationZoneLayout /usr/bin/ld: cannot find -lwaves2Foam collect2: ld returned 1 exit status make[1]: *** [/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/relaxationZoneLayout] Error 1 make[1]: Leaving directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/preProcessing/relaxationZoneLayout' make: *** [relaxationZoneLayout] Error 2 Making dependency list for source file setWaveField.C could not open file foamTime.H for source file setWaveField.C make[1]: Entering directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/preProcessing/setWaveField' SOURCE=setWaveField.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -DOFVERSION=220 -DEXTBRANCH=0 -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/local/software/gsl/1.15/include -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/setWaveField.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -DOFVERSION=220 -DEXTBRANCH=0 -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/local/software/gsl/1.15/include -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/setWaveField.o -L/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \ -lfiniteVolume -L/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/lib -lwaves2Foam -L/local/software/gsl/1.15/lib -lgsl -lgslcblas -lOpenFOAM -ldl -lm -o /home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/setWaveField /usr/bin/ld: cannot find -lwaves2Foam collect2: ld returned 1 exit status make[1]: *** [/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/setWaveField] Error 1 make[1]: Leaving directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/preProcessing/setWaveField' make: *** [setWaveField] Error 2 Making dependency list for source file setWaveParameters.C make[1]: Entering directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/preProcessing/setWaveParameters' SOURCE=setWaveParameters.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -DOFVERSION=220 -DEXTBRANCH=0 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamProcessing/lnInclude -I/local/software/gsl/1.15/include -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/setWaveParameters.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -DOFVERSION=220 -DEXTBRANCH=0 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamProcessing/lnInclude -I/local/software/gsl/1.15/include -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/setWaveParameters.o -L/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \ -lfiniteVolume -L/local/software/gsl/1.15/lib -lgsl -lgslcblas -L/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/lib -lwaves2Foam -lwaves2FoamProcessing -lOpenFOAM -ldl -lm -o /home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/setWaveParameters /usr/bin/ld: cannot find -lwaves2Foam collect2: ld returned 1 exit status make[1]: *** [/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/setWaveParameters] Error 1 make[1]: Leaving directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/preProcessing/setWaveParameters' make: *** [setWaveParameters] Error 2 Making dependency list for source file waveGaugesNProbes.C could not open file foamTime.H for source file waveGaugesNProbes.C make[1]: Entering directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/preProcessing/waveGaugesNProbes' SOURCE=waveGaugesNProbes.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamProcessing/lnInclude -I/local/software/gsl/1.15/include -DOFVERSION=220 -DEXTBRANCH=0 -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/waveGaugesNProbes.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamProcessing/lnInclude -I/local/software/gsl/1.15/include -DOFVERSION=220 -DEXTBRANCH=0 -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/waveGaugesNProbes.o -L/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \ -lOpenFOAM -lfiniteVolume -L/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/lib -lwaves2Foam -lwaves2FoamProcessing -L/local/software/gsl/1.15/lib -lgsl -lgslcblas -lOpenFOAM -ldl -lm -o /home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/waveGaugesNProbes /usr/bin/ld: cannot find -lwaves2Foam collect2: ld returned 1 exit status make[1]: *** [/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/waveGaugesNProbes] Error 1 make[1]: Leaving directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/preProcessing/waveGaugesNProbes' make: *** [waveGaugesNProbes] Error 2 make: Target `application' not remade because of errors. Regards, Yage |
#11 |
Yage
Rep Power: 12 |
Dear Neils
December 23, 2015, 19:59 |
#12 |
Yage
Rep Power: 12 |
and this is for post-processing
===================================== COMPILE POST-PROCESSING ===================================== Making dependency list for source file postProcessWaves2Foam.C could not open file foamTime.H for source file postProcessWaves2Foam.C make[1]: Entering directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/postProcessing/postProcessWaves2Foam' SOURCE=postProcessWaves2Foam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/src/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamProcessing/lnInclude -I/local/software/gsl/1.15/include -DOFVERSION=220 -DEXTBRANCH=0 -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/postProcessWaves2Foam.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/src/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamProcessing/lnInclude -I/local/software/gsl/1.15/include -DOFVERSION=220 -DEXTBRANCH=0 -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/postProcessWaves2Foam.o -L/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \ -lOpenFOAM -lfiniteVolume -L/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/lib -lwaves2Foam -lwaves2FoamProcessing -L/local/software/gsl/1.15/lib -lgsl -lgslcblas -lOpenFOAM -ldl -lm -o /home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/postProcessWaves2Foam /usr/bin/ld: cannot find -lwaves2Foam collect2: ld returned 1 exit status make[1]: *** [/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/postProcessWaves2Foam] Error 1 make[1]: Leaving directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/postProcessing/postProcessWaves2Foam' make: *** [postProcessWaves2Foam] Error 2 Making dependency list for source file surfaceElevation.C make[1]: Entering directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/postProcessing/surfaceElevation' SOURCE=surfaceElevation.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/sampling/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/fileFormats/lnInclude -DOFVERSION=220 -DEXTBRANCH=0 -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamSampling/lnInclude -I/local/software/gsl/1.15/include -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/surfaceElevation.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/sampling/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/fileFormats/lnInclude -DOFVERSION=220 -DEXTBRANCH=0 -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamSampling/lnInclude -I/local/software/gsl/1.15/include -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/surfaceElevation.o -L/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \ -lfiniteVolume -lmeshTools -lsampling -lsurfMesh -llagrangian -lfileFormats -L/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/lib -lwaves2Foam -lwaves2FoamSampling -L/local/software/gsl/1.15/lib -lgsl -lgslcblas -lOpenFOAM -ldl -lm -o /home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/surfaceElevation /usr/bin/ld: cannot find -lwaves2Foam collect2: ld returned 1 exit status make[1]: *** [/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/surfaceElevation] Error 1 make[1]: Leaving directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/postProcessing/surfaceElevation' make: *** [surfaceElevation] Error 2 make: Target `application' not remade because of errors. Last edited by wyldckat; August 25, 2018 at 11:46. Reason: repaired the [CODE] block |
#13 |
Yage
Rep Power: 12 |
===================================== COMPILE POST-PROCESSING ===================================== Making dependency list for source file postProcessWaves2Foam.C could not open file foamTime.H for source file postProcessWaves2Foam.C make[1]: Entering directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/postProcessing/postProcessWaves2Foam' SOURCE=postProcessWaves2Foam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/src/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamProcessing/lnInclude -I/local/software/gsl/1.15/include -DOFVERSION=220 -DEXTBRANCH=0 -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/postProcessWaves2Foam.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/src/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamProcessing/lnInclude -I/local/software/gsl/1.15/include -DOFVERSION=220 -DEXTBRANCH=0 -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/postProcessWaves2Foam.o -L/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \ -lOpenFOAM -lfiniteVolume -L/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/lib -lwaves2Foam -lwaves2FoamProcessing -L/local/software/gsl/1.15/lib -lgsl -lgslcblas -lOpenFOAM -ldl -lm -o /home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/postProcessWaves2Foam /usr/bin/ld: cannot find -lwaves2Foam collect2: ld returned 1 exit status make[1]: *** [/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/postProcessWaves2Foam] Error 1 make[1]: Leaving directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/postProcessing/postProcessWaves2Foam' make: *** [postProcessWaves2Foam] Error 2 Making dependency list for source file surfaceElevation.C make[1]: Entering directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/postProcessing/surfaceElevation' SOURCE=surfaceElevation.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/sampling/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/fileFormats/lnInclude -DOFVERSION=220 -DEXTBRANCH=0 -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamSampling/lnInclude -I/local/software/gsl/1.15/include -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/surfaceElevation.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/sampling/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/fileFormats/lnInclude -DOFVERSION=220 -DEXTBRANCH=0 -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2Foam/lnInclude -I/scratch/pl1g11/OpenFOAM/waves2Foam-master/src/waves2FoamSampling/lnInclude -I/local/software/gsl/1.15/include -IlnInclude -I. -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/surfaceElevation.o -L/scratch/pl1g11/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \ -lfiniteVolume -lmeshTools -lsampling -lsurfMesh -llagrangian -lfileFormats -L/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/lib -lwaves2Foam -lwaves2FoamSampling -L/local/software/gsl/1.15/lib -lgsl -lgslcblas -lOpenFOAM -ldl -lm -o /home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/surfaceElevation /usr/bin/ld: cannot find -lwaves2Foam collect2: ld returned 1 exit status make[1]: *** [/home/pl1g11/OpenFOAM/pl1g11-2.2.0/platforms/linux64GccDPOpt/bin/surfaceElevation] Error 1 make[1]: Leaving directory `/scratch/pl1g11/OpenFOAM/waves2Foam-master/applications/utilities/postProcessing/surfaceElevation' make: *** [surfaceElevation] Error 2 make: Target `application' not remade because of errors. |
December 24, 2015, 03:23 |
#14 |
Rep Power: 37 |
Hi Yage,
The missing waves2Foam library suggests that libraries and/or Thirdparty bits were not correctly compiled. Kind regards, Niels
#15 |
Rep Power: 37 |
Hi Yage,
January 19, 2016, 10:51 |
#16 | |
Jorge Gadelho
Rep Power: 13 |
Any solution? Thanks. |
#17 | |
Jorge Gadelho
Rep Power: 13 |
January 19, 2016, 12:16 |
#18 |
Rep Power: 37 |
Good afternoon all,
@Jorge #1143: For some reason your compilation of libwaves2Foam.so failed. This is most likely related to a missing fortran compiler, so the coupling with OceanWave3D is not possible. It is on the TO-DO list to provide a compilation procedure that is successful without a fortran-compiler, but I am not sure, when this will happen. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. Last edited by wyldckat; August 25, 2018 at 11:49. Reason: removed answers to other posts that were on the main thread |
February 15, 2016, 02:02 |
#19 | |
Lee Jung Hoo
Rep Power: 10 |
Hello Yage! I have problem that you went through before. I got error messages just like you. (such that; make[1]: *** [Make/linux64GccDPOpt/surfaceElevation.o] Error 1 make[1]: Target `/home/yage/OpenFOAM/yage-2.1.1/platforms/linux64GccDPOpt/bin/surfaceElevation' not remade because of errors. make[1]: Leaving directory `/home/yage/waves2Foam-master/applications/utilities/postProcessing/surfaceElevation' make: *** [surfaceElevation] Error 2 make: Target `application' not remade because of errors. ===================================== COMPILATION DONE ===================================== ) And I can't understand "tring to wmake each step (Third Party, Library, Solver..)" Can you explain more specifically?? Thank you!! I appologize for my pool english in advance.. Last edited by wyldckat; August 25, 2018 at 11:11. Reason: merged posts a few minutes apart |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 26 | June 21, 2024 06:54 |
[OpenFOAM.org] OpenFOAM build on Intel Xeon Phi | asaijo | OpenFOAM Installation | 31 | July 26, 2017 10:35 |
conjugateHeatFoam with OpenFOAM 2.1.1 | rou | OpenFOAM Programming & Development | 4 | April 24, 2015 05:23 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
OpenFOAM 15 and CentOS 52 installation issues | remrich | OpenFOAM Bugs | 9 | March 20, 2009 01:48 |
