[waves2Foam] surfaceElevation sampling utilities
Old   November 17, 2016, 12:34
Default surfaceElevation sampling utilities
katakgoreng is on a distinguished road
Originally Posted by ngj View Post
Good morning Hao,
To me, it sounds as if there are problems with the sampling utilities on 2.3 (and perhaps even above?). Could you please perform the following couple of tests:
1. Test whether the problem persists on static meshes, e.g. make a dambreak onto your cylinder with and without the surfaceElevation utility.
2. Perform your test case with line sampling instead of surfaceElevation. surfaceElevation is derived from the sampling utility in version 1.6 (if I remember correctly), so there could be some discrepancies.
If the problem still persists for '2', it suggests that there is a problem with multiple sampling in 2.3+ and that it is not related to surfaceElevation itself.
Good luck,
Niels
P.S. Rafa, thank you for the feed-back.
Hi Niels,
In regards of the sampling utilities, I have issue when sampling the surface elevation for negative times in which the sampling (done as post processing step using surfaceElevationDict) only occur from t=0s and disregard the negative time value.
There is no issue if the sampling is done as run-time post-processing. I have attached the case file & hope you can have a look at them. I'm using Openfoam 2.2.2 on Xubuntu 14.04.
katakgoreng is offline   Reply With Quote
Old   November 17, 2016, 13:02
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hallo,
I do not have such an old version available, but have you tried the following?
surfaceElevation -time -1:
Perhaps, it is simply the time-selection routine that does not consider negative values by default. At least, I do not think that it originated from waves2Foam itself.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   November 18, 2016, 06:27
Hallo,
Kind regards,
Niels
Many thanks. I have tried specifying "surfaceElevation -time -1:" but still got the same problem. I've also tried using openfoam 2.3.0, but the problem is still there. I guess it is due to time-selection routine then.
sampling interval and sampling frequency beauty FLUENT 13 November 9, 2022 09:23
problem sampling a plane in parallel syavash OpenFOAM Post-Processing 0 May 7, 2018 11:15
Modeling sampling valve in CONVEARGE williamchina CONVERGE 2 September 13, 2016 02:16
Possible bug or limitation in stl-generated surface for sampling analysis Ali Blues OpenFOAM Post-Processing 3 April 27, 2016 10:30
sampling Data during calculation JimKnopf OpenFOAM Post-Processing 0 May 27, 2011 05:10
