[waves2Foam] Compilation problem on OF 2.4.0
Old   December 6, 2015, 08:39
Default Compilation problem on OF 2.4.0
Nick Krgs
Nick_civ is on a distinguished road
Hi Niels,
I 'm trying to compile waves2foam on OF2.4.0 but i encounter some errors with respect to libraries i suppose. I followed the process according to wiki (downloading GSL first -its directory is in usr/include-etc). I attach the wmake file. Have you any idea what's going wrong because i encounter the same problem even i try to compile it on OF2.2.2 on another desktop.
Kind Regards
Nick
Nick_civ is offline   Reply With Quote
Old   December 6, 2015, 16:20
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good evening,
@Nick: Note that you also need to have gfortran available. The errors relate to a missing gfortran library.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
Last edited by wyldckat; August 25, 2018 at 13:15. Reason: removed answers to other posts that were on the main thread
ngj is offline   Reply With Quote
Old   November 28, 2016, 10:31
Nick Krgs
Hi Niels,
i am trying to run waves2foam on OF 2.4.0 on a desktop (just compiled) and I suspect there is a problem with compilation and it doesn't work. Actually I saw the errors below :
ls: cannot access *.mod: No such file or directory
mv: cannot stat ‘*.mod’: No such file or directory
and also : could not open file foamTime.H for source file postProcessWaves2Foam.C due to No such file or directory,
could not open file foamTime.H for source file faceSetToSTL.C due to No such file or directory etc
But I attach the log from compilation for you to check.
Can you advise me please?
Best Regards
Nick
Old   November 29, 2016, 04:02
ngj
Good morning,
@Nick: Looking at your log-file, it seems that everything are compiling correctly.
Kind regards,
Niels
Last edited by wyldckat; August 25, 2018 at 08:33. Reason: removed answers to other posts that were on the main thread
UDF compilation problem on Linux System Nitin Pathak Fluent UDF and Scheme Programming 6 September 29, 2018 21:26
compilation problem of gamma-ReThetatSST transition model giammy92 OpenFOAM 1 November 3, 2017 06:45
OpenFoam Extend-3.0 - libscotch 6.0 compilation Problem rkc.cfd OpenFOAM Installation 4 January 31, 2014 15:21
solver compilation problem, /bin/linux64GccDPOpt directory empty arnaud6 OpenFOAM Running, Solving & CFD 0 July 25, 2013 11:48
[swak4Foam] compilation problem ganeshv OpenFOAM Community Contributions 5 November 11, 2011 17:39
