[waves2Foam] Modified the waveFlume tutorial and getting strange wave height |
December 14, 2016, 02:27 |
Kenric
Rep Power: 10 |
Hello Niels, sorry to bother again. I have modified the waveFlume tutorial and input the wave parameters as attached. I've set the wave height to 0.04m. However, when i plot the surface elevation vs time of my probe (at the middle of the wave tank), i only get less than 0.02m wave height. the probe is also not within the relaxation zone area. Can i have your advice on this please?
December 14, 2016, 03:27 |
Niels Gjoel Jacobsen
Rep Power: 37 |
The problem is your vertical resolution of 0.10 m, which is way bigger than the wave height.
Kind regards Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
December 14, 2016, 04:57 |
Kenric
Rep Power: 10 |
yeap, you were right about my vertical mesh size. I've corrected and increased the vertical mesh resolution by 10x and change the wave height to 0.3m. However, the graphs obtained are not very reasonable. this does not happen when i set my period at 2s. I have no idea why. Please kindly advise me on this.
