[waves2Foam] Problems compiling with Ubuntu 14.04 and OpenFOAM 3.0.1
Old   November 29, 2016, 03:43
Default Problems compiling with Ubuntu 14.04 and OpenFOAM 3.0.1
Kenric
kenrichaiz is on a distinguished road
Hello, I've tried installing waves2foam on my other computer. I've successfully compiled the Allwmake file, I can run waveGaugesNProbes, setWaveParameters and setWaveField command.
However, when i try to run waveFoam command, an error stating that
"waveFoam: command not found"
I'm using Ubuntu 14.04 and OpenFOAM 3.0.1.
Appreciate if anyone can help me. Thank you.
kenrichaiz is offline   Reply With Quote
Old   November 29, 2016, 04:02
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good morning,
@Kenrich: waveFoam does not come natively with waves2Foam for OF3.0.1. For any 3-digit version number, you need to create your own version of waveFoam and porousWaveFoam.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
Last edited by wyldckat; August 25, 2018 at 08:19. Reason: removed answers to other posts that were on the main thread
ngj is offline   Reply With Quote
Old   November 30, 2016, 05:01
Default Downgraded OpenFOAM to 3.0
Kenric
Hello Niels, thank you for your time and patience. I've downgraded my openfoam to version 3.0, the openfoam works correctly but there are issues while compiling. I have attached the error log for reference. Really appreciate if you can advice. Thanks.
Old   November 30, 2016, 13:50
ngj
Good evening,
@Kenric: You are missing dependencies for GSL or provide the wrong path.
Kind regards,
Niels
Old   December 1, 2016, 04:05
Kenric
Thanks Niels,
Your solver comes with for of3.0.1 also. I edited the make files from EXE=$(FOAM_APPBIN)/waveFoam to EXE=$(FOAM_USER_APPBIN)/waveFoam and it works fine now. Thank you for your time and awesome toolbox.
[OpenFOAM.org] Building OpenFOAM 3.0.1 on Ubuntu 16.04 - failed erico OpenFOAM Installation 30 February 2, 2017 10:24
[OpenFOAM.org] Problems installing OpenFOAM 2.3.0 on Ubuntu 12.04 arieljeds OpenFOAM Installation 6 August 19, 2015 08:39
[OpenFOAM.org] Installation of OpenFOAM 2.3.1 on Ubuntu 14.04 stephie OpenFOAM Installation 5 February 14, 2015 12:05
[OpenFOAM.org] Installing OpenFOAM 2.3.x on Ubuntu 14.04 samiam1000 OpenFOAM Installation 4 January 26, 2015 03:44
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
