[waves2Foam] surfaceElevation probes with dynamic mesh (meshMotion) |
February 25, 2014, 09:23 |
Ed Ransley
Rep Power: 14 |
Hi Niels and other waves2Foamers,
I'm struggling to get the surfaceElevation function objects to work when using the dynamic mesh solver waveDyMFoam. the solver works fine and I get good results for the CoM of a floating buoy but I cannot record the surface elevation during run time by the waveGauges and probes or the function objects methods which work fine with waveFoam. Here is the error message I get, I wonder if this make any more sense to you than me. Thanks a lot, Ed Interface Courant Number mean: 2.65114e-09 max: 0.000190931 Courant Number mean: 6.8222e-07 max: 0.0226919 deltaT = 0.00143023 Time = 0.00262784 [1] #0 Foam::error:rintStack(Foam::Ostream&)[0] #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [0] #1 Foam::sigSegv::sigHandler(int) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #1 Foam::sigSegv::sigHandler(int) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [0] #2 in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #2 in "/lib/x86_64-linux-gnu/libc.so.6" [0] #3 Foam::valuePointPatchField<Foam::Vector<double> >::updateCoeffs() in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [0] #4 Foam::displacementLaplacianFvMotionSolver::solve() in "/lib/x86_64-linux-gnu/libc.so.6" [1] #3 Foam::valuePointPatchField<Foam::Vector<double> >::updateCoeffs() in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #4 Foam::displacementLaplacianFvMotionSolver::solve() in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfvMotionSolvers.so" [0] #5 Foam::motionSolver::newPoints() in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" [0] #6 Foam::dynamicMotionSolverFvMesh::update() in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfvMotionSolvers.so" [1] #5 Foam::motionSolver::newPoints() in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so" [0] #7 in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" [1] #6 Foam::dynamicMotionSolverFvMesh::update()[0] in "/home/coast/OpenFOAM/coast-2.2.1/platforms/linux64GccDPOpt/bin/waveDyMFoam" [0] #8 __libc_start_main in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so" [1] #7 in "/lib/x86_64-linux-gnu/libc.so.6" [0] #9 [0] in "/home/coast/OpenFOAM/coast-2.2.1/platforms/linux64GccDPOpt/bin/waveDyMFoam" [COAST:26895] *** Process received signal *** [COAST:26895] Signal: Segmentation fault (11) [COAST:26895] Signal code: (-6) [COAST:26895] Failing at address: 0x3e80000690f [COAST:26895] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7ff7a2de64a0] [COAST:26895] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7ff7a2de6425] [COAST:26895] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7ff7a2de64a0] [COAST:26895] [ 3] /opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam20valuePointPatchFieldINS_6 VectorIdEEE12updateCoeffsEv+0x26) [0x7ff7a40506d6] [COAST:26895] [ 4] /opt/openfoam221/platforms/linux64GccDPOpt/lib/libfvMotionSolvers.so(_ZN4Foam35displacementLaplac ianFvMotionSolver5solveEv+0x9d) [0x7ff79a59d2cd] [COAST:26895] [ 5] /opt/openfoam221/platforms/linux64GccDPOpt/lib/libdynamicMesh.so(_ZN4Foam12motionSolver9newPoints Ev+0x1d) [0x7ff7a5ea794d] [COAST:26895] [ 6] /opt/openfoam221/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so(_ZN4Foam25dynamicMotionSolverF vMesh6updateEv+0x2a) [0x7ff7a597c56a] [COAST:26895] [ 7] waveDyMFoam() [0x4254a1] [COAST:26895] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7ff7a2dd176d] [COAST:26895] [ 9] waveDyMFoam() [0x42e1cd] [COAST:26895] *** End of error message *** [1] in "/home/coast/OpenFOAM/coast-2.2.1/platforms/linux64GccDPOpt/bin/waveDyMFoam" [1] #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [1] #9 -------------------------------------------------------------------------- mpirun noticed that process rank 0 with PID 26895 on node COAST exited on signal 11 (Segmentation fault). -------------------------------------------------------------------------- |
January 16, 2017, 07:30 |
Maoyanjun
Rep Power: 10 |
Hi Ed Ransley
Have you solved this problem, I face the problem now that the surfaceElevation function can not be used in waveDyMFoam or interDyMFoam. Can you give me some suggestions to use it with the waveDyMFoam. Last edited by wyldckat; August 25, 2018 at 07:12. Reason: removed large quote, since the post is now right above it on the new thread |
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent | Qingsong | FLUENT | 2 | March 21, 2022 15:08 |
Dynamic Mesh on Pintle type injector. | herntan | FLUENT | 16 | September 4, 2020 08:27 |
[ICEM] Dynamic mesh setup with ICEM | David121284 | ANSYS Meshing & Geometry | 0 | April 11, 2014 04:19 |
Dynamic Mesh "Shadow Wall" | thezack | FLUENT | 0 | June 4, 2013 22:09 |
dynamic mesh for drop interface | IndrajitW | FLUENT | 0 | March 30, 2013 08:03 |
