January 14, 2017, 02:58 |
The Definition of T soft
Anna
Rep Power: 10 |
Dear Foamers
I am a new user and I am working on the interaction between waves and breakwatres. I have compiled waves2foam with interDyMFoam and as the result my solver is waveDyMFoam. I have a question about the inputs of irregular waves. I use JONSWAP Spectrum as the irregular waves. In the waveproperties file it needs T Soft, unfortunately I do not know the underlying concept of that. Does anyone know what is T Soft? I appreciate your kindness in advance Best Regards Anna |
January 15, 2017, 12:58 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Good evening.
@Anna: Tsoft is the time over which the waves are ramped from zero to the final value. This functionality is present to avoid shocks at t = 0. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. Last edited by wyldckat; August 25, 2018 at 07:11. Reason: removed answers to other posts that were on the main thread |
January 15, 2017, 14:31 |
Anna
Rep Power: 10 |
Dear Niels,
Thanks for your quick reply. Unfortunately, the under lying concept of T soft is still unclear for me. I have modeled a irregular waves with JONSWAP Spectrum with (Tf=Tp=1.2 sec) and (Hs=0.045 m) and (N=30). Not only does the maximum of the surface elevation not match with Hs, but also the surface elevation reduces in the length of the flume. I have attached the picture of the mentioned result at two different probes at the specific time(in the next post). Although the Tsoft and Tp are the same at this simulation, I can not solve this problem. It is vague for me this differences. I appreciate your kindness in advance Best Regards Anna |
January 15, 2017, 14:33 |
Anna
Rep Power: 10 |
Dear Niels,
Thanks for your quick reply. Unfortunately, the under lying concept of T soft is still unclear for me. I have modeled a irregular waves with JONSWAP Spectrum with (Tf=Tp=1.2 sec) and (Hs=0.045 m) and (N=30). Not only does the maximum of the surface elevation not match with Hs, but also the surface elevation reduces in the length of the flume. I have attached the picture of the mentioned result at two different probes at the specific time. Although the Tsoft and Tp are the same at this simulation, I can not solve this problem. It is vague for me this differences. I appreciate your kindness in advance Best Regards Anna |
January 17, 2017, 14:02 |
Rep Power: 37 |
Good evening,
@Anna: You most likely suffer from numerical diffusion due to too coarse mesh resolution or poorly chosen numerical schemes. Kind regards Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
It has to include complete definition of a type (not just fwd declaration), isn't it? | Zeppo | OpenFOAM Programming & Development | 12 | August 16, 2016 14:01 |
Problem with residual and their definition! | batta31 | OpenFOAM Running, Solving & CFD | 5 | July 18, 2016 10:39 |
(AutoGRID 5) Problem in Geometry definition of propeller | venkat_aero2007 | Fidelity CFD | 14 | July 31, 2012 14:05 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
OpenFOAM14 for Mac OSX Darwin 104 | gschaider | OpenFOAM Installation | 118 | July 20, 2008 05:19 |
