[waves2Foam] calculate drag coefficient in postProcessing |
February 10, 2017, 06:06 |
Mona
Rep Power: 10 |
Dear all,
I am trying to calculate the drag coefficient for a body, that is doing a pitch motion in regular waves. (I attached a sketch to give you an idea of the setup.) Drag coefficient: cd=2*Fd/(rho*U*|U|*A) Fd: Drag force, calculated with forces function A: reference area rho: density I figured that I can't use the forceCoeffs function, because U is not the free stream velocity in this case, but the relative velocity between the body and the fluid particles. So the velocity I need here is U=u(t)-v(t), where u(t) is the flow velocity in drag direction (x) and v(t) the velocity of the body, also in x-direction. (Please correct me if I am wrong here) Now I am wondering if any of you have some advice how to obtain those two values. 1)u(t) This value varies throughout the flow filed around the body, so should I set several probes and then take an average value or try to pick a characteristic point? 2)v(t) I am already outputting the angular velocity omega of the body. With v=omega*radius I will obtain the tangential velocity. But how can I obtain the x-component from that? My plan is to calculate cd(t) in postprocessing with all these above values. Any suggestions on how to do this are very appreciated! Cheers, Mona |
Unrealistic value for drag coefficient | tw463 | Main CFD Forum | 13 | May 10, 2020 15:59 |
drag coefficient in ansys fluent 12.0 | krishna | FLUENT | 19 | April 12, 2018 00:49 |
how to calculate coefficient of drag | emregungor | FLUENT | 0 | July 22, 2015 05:48 |
How can I calculate force for lift coefficient and drag coefficient ? | gemxx | CFX | 3 | July 4, 2015 08:37 |
is it possible to calculate drag coefficient of sphere anlaytically? | S.Rhee | Main CFD Forum | 0 | December 8, 2014 00:32 |
