[waves2Foam] waves2foam on cluster using module environment |
February 7, 2017, 07:53 |
Gautami Erukulla
Rep Power: 17 |
Dear Dr. Jacobsen,
Our System Adminsitrator is not able to install waves2foam on a cluster. The OpenFOAM version on cluster (based on RedHat Enterprise Linux Server 6) is OpenFOAM 2.3.0. Kindly can you please let us know how to compile waves2foam on a cluster that is using modules environment . Please let me know if I need to provide any additional data which will help you guide us. Thank you for your time and consideration. Most&More, Gautami Erukulla. |
February 11, 2017, 11:33 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Good afternoon,
@Gautami: Good luck, I cannot help on this. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. Last edited by wyldckat; August 24, 2018 at 19:54. Reason: Copied post and removed answers to other posts |
February 15, 2017, 12:51 |
Gautami Erukulla
Rep Power: 17 |
Dear Dr. Jacobsen,
My apologies, was not able to give a prompt reply. Good news is, our system administrator was able to compile waves2foam on cluster successfully. Currently I am working on simulating cases using waves2foam on a cluster. Thank you. Most&More, Gautami Erukulla. |
[foam-extend.org] Module file foam-extend 3.2 CentOS cluster | KarthickRajkumar | OpenFOAM Installation | 2 | March 26, 2017 13:52 |
Fluent AAS while running in a cluster environment | FreeFall79 | FLUENT | 0 | February 16, 2015 18:31 |
how to add OpenFoam in module environment | smpark | OpenFOAM | 4 | May 12, 2011 14:00 |
Installing Open Foam and needed packages on shared disk for cluster environment | k3di | OpenFOAM Installation | 1 | July 8, 2009 07:06 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 21:51 |
