[waves2Foam] Problem Compiling WaveDyMFoam in OF 3.0.1 |
April 25, 2017, 19:54 |
Pablo Medina
Hi
First of all thanks for the development and support of this tool. I've already solved several problems with some of the post in here. My aim is to simulate a floating body figuring a Wave Energy Converter. For that I want to use waves2Foam with waveDyMFoam solver 1.- I'm running OpenFoam 3.0.1 in Ubuntu 16.04 LTS 2.- Compilation of waves2Foam seems to be OK (Except a final message saying "Nothing for compilation avalaible in the breeder" which I don't really understand) 3.- Tutorials seem to run Ok with waveFoam solver distributed with waves2Foam Trying to modify the interDyMFoam to waveDyMFoam i get the following error message executing wmake Making dependency list for source file waveDyMFoam.C g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I.. -I/home/pablo/OpenFOAM/OpenFOAM-3.0.1/src/transportModels/twoPhaseMixture/lnInclude -I/home/pablo/OpenFOAM/OpenFOAM-3.0.1/src/transportModels -I/home/pablo/OpenFOAM/OpenFOAM-3.0.1/src/transportModels/incompressible/lnInclude -I/home/pablo/OpenFOAM/OpenFOAM-3.0.1/src/transportModels/interfaceProperties/lnInclude -I/home/pablo/OpenFOAM/OpenFOAM-3.0.1/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/pablo/OpenFOAM/OpenFOAM-3.0.1/src/TurbulenceModels/incompressible/lnInclude -I/home/pablo/OpenFOAM/OpenFOAM-3.0.1/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/home/pablo/OpenFOAM/OpenFOAM-3.0.1/src/finiteVolume/lnInclude -I/home/pablo/OpenFOAM/OpenFOAM-3.0.1/src/dynamicMesh/lnInclude -I/home/pablo/OpenFOAM/OpenFOAM-3.0.1/src/dynamicFvMesh/lnInclude -I/home/pablo/OpenFOAM/pablo-3.0.1/applications/utilities/waves2Foam/src/waves2Foam/lnInclude -I/home/pablo/OpenFOAM/OpenFOAM-3.0.1/src/meshTools/lnInclude -I/home/pablo/OpenFOAM/OpenFOAM-3.0.1/src/fvOptions/lnInclude -IlnInclude -I. -I/home/pablo/OpenFOAM/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude -I/home/pablo/OpenFOAM/OpenFOAM-3.0.1/src/OSspecific/POSIX/lnInclude -fPIC -c waveDyMFoam.C -o Make/linux64GccDPInt64Opt/waveDyMFoam.o waveDyMFoam.C: In function ‘int main(int, char**)’: waveDyMFoam.C:134:28: error: ‘ghRef’ was not declared in this scope gh = (g & mesh.C()) - ghRef; ^ /home/pablo/OpenFOAM/OpenFOAM-3.0.1/wmake/rules/General/transform:8: fallo en las instrucciones para el objetivo 'Make/linux64GccDPInt64Opt/waveDyMFoam.o' make: *** [Make/linux64GccDPInt64Opt/waveDyMFoam.o] Error 1 I've found a couple of mentions regarding this issue in the treah but I am not sure of what to do to solve it properly. Any tip would be helpful. Pablo M. |
April 26, 2017, 13:01 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Good evening,
I will quickly answer on the breeder. There is an implementation available for mooring lines for version 1606+. It is placed in breeder, because it is not available on all OF versions. There is also a tool that allow for visualisation of the lines. Kind regards Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
problem during compiling UDF | ned.musab | Fluent UDF and Scheme Programming | 1 | October 11, 2017 11:48 |
problem about compiling meltFoam | wumin | OpenFOAM Programming & Development | 4 | June 23, 2017 17:16 |
C_T(c,t) problem while compiling (OK interpreted) | crevoise | Fluent UDF and Scheme Programming | 6 | February 4, 2014 08:16 |
Problem with compiling new solver | palazi88 | OpenFOAM Programming & Development | 2 | December 24, 2013 20:52 |
COMPILING PROBLEM | ammi | FLUENT | 1 | December 7, 2006 05:07 |
