[waves2Foam] Installing waves2FOAM onto OpenFOAM 2.4.0 |
May 31, 2017, 22:01 |
Zhifang Hu
Rep Power: 11 |
Hi there
I tried to install waves2FOAM onto OpenFOAM 2.4.0, but It does not work, I am not sure why wave2FOAM checked out revision is 2107 Here is some of the outputs Code:
===================================== COMPILE SOLVERS ===================================== Making dependency list for source file waveFoam.C SOURCE=waveFoam.C ; g++-4.7 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/transportModels/twoPhaseMixture/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/transportModels -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/transportModels/incompressible/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/transportModels/interfaceProperties/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/turbulenceModels/incompressible/turbulenceModel -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/fvOptions/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/meshTools/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/sampling/lnInclude -DOFVERSION=240 -DEXTBRANCH=0 -DXVERSION=0 -DOFPLUSBRANCH=0 -I/home/zhifang/OpenFOAM/zhifang-2.4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude -I/home/zhifang/OpenFOAM/zhifang-2.4.0/applications/utilities/waves2Foam/src/waves2FoamSampling/lnInclude -I/usr/include -IlnInclude -I. -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc47DPOpt/waveFoam.o In file included from waveFoam.C:70:0: /home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/readTimeControls.H: In function ‘int main(int, char**)’: /home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/readTimeControls.H:38:8: warning: unused variable ‘maxDeltaT’ [-Wunused-variable] g++-4.7 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/transportModels/twoPhaseMixture/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/transportModels -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/transportModels/incompressible/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/transportModels/interfaceProperties/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/turbulenceModels/incompressible/turbulenceModel -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/fvOptions/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/meshTools/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/sampling/lnInclude -DOFVERSION=240 -DEXTBRANCH=0 -DXVERSION=0 -DOFPLUSBRANCH=0 -I/home/zhifang/OpenFOAM/zhifang-2.4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude -I/home/zhifang/OpenFOAM/zhifang-2.4.0/applications/utilities/waves2Foam/src/waves2FoamSampling/lnInclude -I/usr/include -IlnInclude -I. -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64Gcc47DPOpt/waveFoam.o -L/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64Gcc47DPOpt/lib \ -limmiscibleIncompressibleTwoPhaseMixture -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -lfvOptions -lmeshTools -lsampling -L/home/zhifang/OpenFOAM/zhifang-2.4.0/platforms/linux64Gcc47DPOpt/lib -lwaves2Foam -lwaves2FoamSampling -L/usr/lib64 -lgsl -lgslcblas -lOpenFOAM -ldl -lm -o /home/zhifang/OpenFOAM/zhifang-2.4.0/platforms/linux64Gcc47DPOpt/bin/waveFoam /usr/bin/ld: cannot find -lwaves2Foam /usr/bin/ld: cannot find -lwaves2FoamSampling collect2: error: ld returned 1 exit status /home/zhifang/OpenFOAM/OpenFOAM-2.4.0/wmake/Makefile:149: recipe for target '/home/zhifang/OpenFOAM/zhifang-2.4.0/platforms/linux64Gcc47DPOpt/bin/waveFoam' failed make: *** [/home/zhifang/OpenFOAM/zhifang-2.4.0/platforms/linux64Gcc47DPOpt/bin/waveFoam] Error 1 ===================================== COMPILE POST-PROCESSING ===================================== Making dependency list for source file surfaceElevation.C Making dependency list for source file postProcessWaves2Foam.C could not open file foamTime.H for source file postProcessWaves2Foam.C due to No such file or directory SOURCE=surfaceElevation.C ; g++-4.7 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/meshTools/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/sampling/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/lagrangian/basic/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/fileFormats/lnInclude -DOFVERSION=240 -DEXTBRANCH=0 -I/home/zhifang/OpenFOAM/zhifang-2.4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude -I/home/zhifang/OpenFOAM/zhifang-2.4.0/applications/utilities/waves2Foam/src/waves2FoamSampling/lnInclude -I/usr/include -IlnInclude -I. -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc47DPOpt/surfaceElevation.o SOURCE=postProcessWaves2Foam.C ; g++-4.7 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/meshTools/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude -I/home/zhifang/OpenFOAM/zhifang-2.4.0/applications/utilities/waves2Foam/src/waves2Foam/src/lnInclude -I/home/zhifang/OpenFOAM/zhifang-2.4.0/applications/utilities/waves2Foam/src/waves2FoamProcessing/lnInclude -I/usr/include -DOFVERSION=240 -DEXTBRANCH=0 -IlnInclude -I. -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc47DPOpt/postProcessWaves2Foam.o g++-4.7 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/meshTools/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/sampling/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/lagrangian/basic/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/fileFormats/lnInclude -DOFVERSION=240 -DEXTBRANCH=0 -I/home/zhifang/OpenFOAM/zhifang-2.4.0/applications/utilities/waves2Foam/src/waves2Foam/lnInclude -I/home/zhifang/OpenFOAM/zhifang-2.4.0/applications/utilities/waves2Foam/src/waves2FoamSampling/lnInclude -I/usr/include -IlnInclude -I. -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64Gcc47DPOpt/surfaceElevation.o -L/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64Gcc47DPOpt/lib \ -lfiniteVolume -lmeshTools -lsampling -lsurfMesh -llagrangian -lfileFormats -L/home/zhifang/OpenFOAM/zhifang-2.4.0/platforms/linux64Gcc47DPOpt/lib -lwaves2Foam -lwaves2FoamSampling -L/usr/lib64 -lgsl -lgslcblas -lOpenFOAM -ldl -lm -o /home/zhifang/OpenFOAM/zhifang-2.4.0/platforms/linux64Gcc47DPOpt/bin/surfaceElevation /usr/bin/ld: cannot find -lwaves2Foam /usr/bin/ld: cannot find -lwaves2FoamSampling collect2: error: ld returned 1 exit status /home/zhifang/OpenFOAM/OpenFOAM-2.4.0/wmake/Makefile:149: recipe for target '/home/zhifang/OpenFOAM/zhifang-2.4.0/platforms/linux64Gcc47DPOpt/bin/surfaceElevation' failed make[1]: *** [/home/zhifang/OpenFOAM/zhifang-2.4.0/platforms/linux64Gcc47DPOpt/bin/surfaceElevation] Error 1 /home/zhifang/OpenFOAM/OpenFOAM-2.4.0/wmake/MakefileApps:39: recipe for target 'surfaceElevation' failed make: *** [surfaceElevation] Error 2 g++-4.7 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/meshTools/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude -I/home/zhifang/OpenFOAM/zhifang-2.4.0/applications/utilities/waves2Foam/src/waves2Foam/src/lnInclude -I/home/zhifang/OpenFOAM/zhifang-2.4.0/applications/utilities/waves2Foam/src/waves2FoamProcessing/lnInclude -I/usr/include -DOFVERSION=240 -DEXTBRANCH=0 -IlnInclude -I. -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64Gcc47DPOpt/postProcessWaves2Foam.o -L/home/zhifang/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64Gcc47DPOpt/lib \ -lOpenFOAM -lfiniteVolume -L/home/zhifang/OpenFOAM/zhifang-2.4.0/platforms/linux64Gcc47DPOpt/lib -lwaves2Foam -lwaves2FoamProcessing -L/usr/lib64 -lgsl -lgslcblas -lOpenFOAM -ldl -lm -o /home/zhifang/OpenFOAM/zhifang-2.4.0/platforms/linux64Gcc47DPOpt/bin/postProcessWaves2Foam /usr/bin/ld: cannot find -lwaves2Foam /usr/bin/ld: cannot find -lwaves2FoamProcessing collect2: error: ld returned 1 exit status /home/zhifang/OpenFOAM/OpenFOAM-2.4.0/wmake/Makefile:149: recipe for target '/home/zhifang/OpenFOAM/zhifang-2.4.0/platforms/linux64Gcc47DPOpt/bin/postProcessWaves2Foam' failed make[1]: *** [/home/zhifang/OpenFOAM/zhifang-2.4.0/platforms/linux64Gcc47DPOpt/bin/postProcessWaves2Foam] Error 1 /home/zhifang/OpenFOAM/OpenFOAM-2.4.0/wmake/MakefileApps:39: recipe for target 'postProcessWaves2Foam' failed make: *** [postProcessWaves2Foam] Error 2 make: Target 'application' not remade because of errors. ===================================== COMPILE BREEDER ===================================== Nothing available for compilation in the breeder directory. ===================================== COMPILATION DONE ===================================== Thanks in Advance |
June 3, 2017, 05:16 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Zhifang,
The most likely explanation is that you are missing one or more dependencies, e.g. gfortran. In any case, compilation of solvers fail due to failure to compile libraries. The latter part is not shown in your message. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
[Other] How to install OpenFOAM under Windows? | lzgwhy | OpenFOAM Installation | 19 | October 7, 2023 04:27 |
[Other] Basic questions about OpenFOAM cluster running and installing | Fauster | OpenFOAM Installation | 0 | May 25, 2018 15:00 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
[OpenFOAM.org] Problem in installing OpenFOAM 2.3.0 !!! | omid20110 | OpenFOAM Installation | 6 | August 1, 2016 11:20 |
[OpenFOAM.org] Problems installing OpenFOAM 2.3.0 on Ubuntu 12.04 | arieljeds | OpenFOAM Installation | 6 | August 19, 2015 07:39 |
