[waves2Foam] regular wave generation attenuation |
Yang Zhou
Rep Power: 9 ![]() |
Hi Foamers,
I am a newcomer of waves2Foam. I have confronted some problems in generating waves(OpenFoam 4.0, Ubuntu 17.04). I am getting approximately 5%-6% reduction on the peak and valley of the wave, the error is little bit more than I expected. 1.JPG 2.JPG Wave properties input Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object environmentalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // seaLevel 0.00; // A list of the relaxation zones in the simulation. The parameters are given // in <name>Coeffs below. relaxationNames (inlet outlet); initializationName outlet; inletCoeffs { // Wave type to be used at boundary "inlet" and in relaxation zone "inlet" waveType stokesFirst; // Ramp time of 2 s Tsoft 2; // Water depth at the boundary and in the relaxation zone depth 2; // Wave period period 2.0; // Phase shift in the wave phi 0.000000; // Wave number vector, k. direction (1.0 0.0 0.0); // Wave height height 0.04; // Specifications on the relaxation zone shape and relaxation scheme relaxationZone { relaxationScheme Spatial; relaxationShape Rectangular; beachType Empty; relaxType INLET; startX (0 0.0 -1); endX (5 0.0 1); orientation (1.0 0.0 0.0); } }; outletCoeffs { waveType potentialCurrent; U (0 0 0); Tsoft 2; relaxationZone { relaxationScheme Spatial; relaxationShape Rectangular; beachType Empty; relaxType OUTLET; startX (13 0.0 -1); endX (18 0.0 1); orientation (1.0 0.0 0.0); } }; // ************************************************************************* // Blockmesh Dictionary /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Code:
convertToMeters 1; vertices ( ( 0 -2 0 ) ( 18 -2 0 ) ( 0 1 0 ) ( 18 1 0 ) ( 0 -2 0.1 ) ( 18 -2 0.1 ) ( 0 1 0.1 ) ( 18 1 0.1 ) ); blocks ( hex (0 1 3 2 4 5 7 6) ( 150 450 1 ) simpleGrading (1 1 1) ); edges ( ); patches ( patch inlet ( (0 4 6 2) ) wall bottom ( (0 1 5 4) ) patch outlet ( (1 5 7 3) ) patch atmosphere ( (2 3 7 6) ) empty frontBack ( (0 1 3 2) (4 5 7 6) ) ); mergePatchPairs ( ); // ************************************************************************* // Last edited by wyldckat; August 23, 2018 at 14:50. Reason: PHP->CODE |
Mehdi
Rep Power: 10 ![]() |
me too i obtained the same range of error with Airy (stokesFirst) about 6%, but you have to refine your mesh bellow sea surface and verify tha you don't make a brutal grading and let a large distance between the end of the refined mesh and the max amplitude size.
me i'm using AR=9 delta z=0.0033m delta x,y=0.03m near the surface (H=0.1 m i use 0.35 m refined mesh bellow surface). i hope that will be usefull for you and good luck. Best regards, Mehdi ![]() Last edited by wyldckat; August 23, 2018 at 14:51. Reason: removed long quote, after moving to independent thread |
#3 | |
Yang Zhou
Dear Mehdi,
I have tried different mesh method by divide the wavelength(λ/20 for example)and the amplitude of the wave (H/6). By the results is not satisfying. It seems different mesh method do not affect the results of wave generation. Capture.JPG Any tips would be helpful to me. Best regards, Yang Quote:
Mehdi
Dear Yangzhou,
so it's not a mesh problem, may be you have to use turbulence modelling if your Reynolds number is high then 10^5 then you should use it to modelise the production of turbulent energy may be it will be decreasing your relative error, i suggeste you to use K-w SST turbulence model if it that doen't resolve your problem you have to look into your fvSchemes div Schemes, the Gauss linearUpwind Schemes of div(phi.U) is more efficient and less dessipative then limitedLinear schemes, you have to read different paper that use waves2Foam solver. Best regards, Mehdi |
IHFOAM - Wave generation with moving boundaries | Phicau | OpenFOAM Verification & Validation | 0 | May 18, 2015 04:53 |
Wave generation, wave height reduces as it progresses | haku88 | STAR-CCM+ | 1 | August 6, 2013 19:32 |
Deep Water Wave Generation Problems | zx9cp | CFX | 4 | June 16, 2013 06:23 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
Help regarding regular wave generation !!!!! | Jenifer | FLUENT | 0 | September 27, 2006 06:57 |
