[waves2Foam] Got a sigSegv with postProcessWaves2Foam |
July 19, 2017, 10:04 |
#1 | |
Xiaochao Li
Hello everyone,
I compiled waves2Foam successfully and the commond waveFoam run successfuly for waveflume case.But when I use the utility postProcessWaves2Foamthe to get the surface elevation, error below is shown. How can I fix it? Thanks in advanced. Quote:
October 2, 2018, 02:22 |
Hillary Kiptoo
Rep Power: 8 |
Hi, did you solve this problem?
October 26, 2018, 02:41 |
Ian
Rep Power: 8 |
I have met that problem just as you, have you find the solution ?
October 27, 2018, 01:18 |
Hillary Kiptoo
Rep Power: 8 |
quick answer: There was an announcement made by Ngl that postProcessWaves2Foam is likely to break, search through his threads.
Node 0: Process 15088: Received signal SIGSEGV. | hasib61 | FLUENT | 7 | September 4, 2022 01:25 |
define_wall_functions density and dynamic viscosity | Ionut G | Fluent UDF and Scheme Programming | 3 | March 15, 2017 10:10 |
"Tgrid received signal SIGSEGV (Segmenetation Violation)" | hasanifte | Mesh Generation & Pre-Processing | 0 | April 1, 2015 20:14 |
SIGSEGV when Volume meshing | the_end90 | STAR-CCM+ | 0 | September 9, 2014 06:33 |
forrtl: severe (174): SIGSEGV, segmentation fault occurred | therockyy | FLOW-3D | 7 | January 19, 2011 22:52 |
