[waves2Foam] New wave theory - waves + current |
#1 | |
Dominic Piro
Rep Power: 16 ![]() |
All,
I had the same problem as Björn when doing waves+current. I noticed larger amplitudes for the waves that were slightly delayed from theory. Therefore I created a new waveTheory (stokesFirstwCurrent) that includes a current velocity. If anyone wants to use this theory, I have attached the source. One additional entry is needed to stokesFirst called "current", which is the current velocity vector. Also, you should use the wave frequency for omega and not the encounter frequency. The current velocity is not affected by "Tsoft", though there is no reason you could not change that. As a result, when I've used this waveTheory, I set the wave field with a potentialCurrent with "Tsoft" of zero and outlet the same. My initial tests indicate that this works pretty well, but let me know if you find a problem. Thanks, Dominic Quote:
Sabra
Rep Power: 0 ![]() |
Hi Foamers,
It is about some months that I started to use waves2Foam package. Thanks Niels for this useful package. I'm planning to model ship with forward speed in waves. My waves are in the region stokesSecond and recently I started to combine waves with the current. I was digging the forum and find post #82 on page 5 which points that waves combined with current amplifies when leaving the relaxation zones and also slightly delayed. I read all related discussion about it but still wondering if this is fixed in the recent versions? Thanks, Sabra [Moderator note: said post #82 is now the post #1 on this thread, after they were moved to a new thread on the 23rd of August 2018.] Last edited by wyldckat; August 23, 2018 at 14:28. Reason: see "Moderator note:" |
Lengshuangjin
I want to add flow to the interFoam wave-making file, which may have a similar function to wave2Foam, but I don't know whether the solver needs to be modified. Does the wave-current coupling need to be modified in the solving process? Will the quality of huaq be conserved if it is not modified
[waves2Foam] combined set of waves with waves2Foam | blaise | OpenFOAM Community Contributions | 7 | December 16, 2023 08:33 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
water waves by potential theory | Omran | CFX | 1 | April 6, 2015 19:29 |
How to set current | Jendge | FLOW-3D | 3 | November 25, 2014 18:48 |
Modelling free surface waves with wave parameters | utku | FLUENT | 0 | December 6, 2004 08:30 |
