[waves2Foam] Difficulties installing with OpenFOAM 4.1 on Ubuntu 16.04
Old   April 27, 2018, 06:20
Default Difficulties installing with OpenFOAM 4.1 on Ubuntu 16.04
Ben 017
Ben UWIHANGANYE is on a distinguished road
Hello
Can you help to fix this problem?
Indeed I am using OPenFOAM4.1 and compiled Wave2Foam . The tutorial works well but when i run wmake in /OpenFOAM/ben-4.1/applications/utilities/waves2Foam/applications/solvers/solvers410/waveFoam$
The feedback given is:
mkdir: cannot create directory ‘’: No such file or directory
/opt/openfoam4/wmake/makefiles/general:132: recipe for target '/waveFoam' failed
make: *** [/waveFoam] Error 1
I would appreciate your support!
regard!
Ben UWIHANGANYE is offline   Reply With Quote
Old   May 3, 2018, 15:23
Ben 017
Originally Posted by Jost K View Post
Dear All,
I am all new to this Forum so please let me know I'm posting this in the wrong Thread.
I am using the waves2foam-OceanWave3D coupling (which by the way is a great feature. Thanks for implementing it!!) for my master Thesis.
In order to do so I am trying tho learn OceanWave3D.
Since there is no user manual to OceanWave3D I am having some issues, specially when trying to set up 3D-Cases.
I am wondering whether any of you have any suggestions for Literature on OceanWave3D or maybe course material that he or she would be willing to share.
Thanks a lot for your help,
Jost
Dear Jo,
I first apologize bcz i don't have any direction to give regarding ur question.
But you can help if you can. Indeed, I need wave2Foam for my masters thesis but i have failed to compile it correctly in OpenFoam-4.1. May you help? Which version are you using?
The error encountered is posted above yours!
I would appreciate!
Thx.
Last edited by wyldckat; August 17, 2018 at 21:56. Reason: Added quote to the mentioned post, given that these posts have been moved out of the old main thread
Old   May 3, 2018, 15:54
Jost Kemper
Jost K is on a distinguished road
Dear Ben,
I am using OpenFoam-4.1.
This little workaround might help, even though there are probably more sophisticated ways of solving your problem:
when you go to the waves2Foam/applications/solvers directory you will see that there is no folder for OpenFOAM-4.1.
So what worked for me (and again this is probably not "best practice") was copying the solvers400 folder and naming it solvers410.
To be honest it might be possible that this has absolutely nothing to do with your problem but I am sure you are happy for every hint
regards,
Jost
P.S.
you should be aware though that there are features of w2f that do not work on of41
(namely the wavegaugesAndProbes as far as I know)
Jost K is offline   Reply With Quote
Old   May 3, 2018, 16:27
Ben 017
Dear Ben,
regards,
Jost
P.S.
Is every thing of w2f working for you? if yes share me where you got the sources codes
Which version do you command i can go for so that w2f works correctly?
Thank you for quick feedback!
Old   May 4, 2018, 06:14
Jost Kemper
Hi Ben,
I downloaded w2f from
http://svn.code.sf.net/p/openfoam-ex...her/waves2Foam
as in the user manual ( https://www.researchgate.net/profile...oam-Manual.pdf ).
As stated in the manual (Warning 1.1) the wave Gauges are not working on of41 apart from that I did not have any problems so far.
Jost
[OpenFOAM.org] Problems installing OpenFOAM 2.3.1 in Ubuntu 12.04 masoudshao OpenFOAM Installation 10 August 9, 2018 07:13
[OpenFOAM.org] Installing OpenFOAM 4.1 on Mac OS Sierra spitchers OpenFOAM Installation 18 August 11, 2017 11:01
[OpenFOAM.org] Building OpenFOAM 3.0.1 on Ubuntu 16.04 - failed erico OpenFOAM Installation 30 February 2, 2017 10:24
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
[OpenFOAM.org] OpenFOAM missing after upgrade to Ubuntu 16.04 Storyteller OpenFOAM Installation 2 May 1, 2016 19:14
