[waves2Foam] waves2Foam on an Ubuntu 18.04 with OpenFOAM 1712 |
#21 |
Luiz Ferreira
Rep Power: 5 ![]() |
Good evening.
I have compiled OP2006 and waves2FOAm but when I try to run the tutorial wave/Foam/waveFlume appers this error. Can anyone help me? root@25dde8998396:/opt/OpenFOAM/ThirdParty-v2006/waves2Foam/tutorials/waveFoam/waveFlume# ./Allrun v2006 Running blockMesh on /opt/OpenFOAM/ThirdParty-v2006/waves2Foam/tutorials/waveFoam/waveFlume Running waveGaugesNProbes on /opt/OpenFOAM/ThirdParty-v2006/waves2Foam/tutorials/waveFoam/waveFlume Running setWaveParameters on /opt/OpenFOAM/ThirdParty-v2006/waves2Foam/tutorials/waveFoam/waveFlume /opt/OpenFOAM/OpenFOAM-v2006/bin/tools/RunFunctions: line 208: 5241 Aborted $appRun $appArgs "$@" > $logFile 2>&1 Running setWaveField on /opt/OpenFOAM/ThirdParty-v2006/waves2Foam/tutorials/waveFoam/waveFlume Running waveFoam on /opt/OpenFOAM/ThirdParty-v2006/waves2Foam/tutorials/waveFoam/waveFlume Running postProcessWaves2Foam on /opt/OpenFOAM/ThirdParty-v2006/waves2Foam/tutorials/waveFoam/waveFlume /opt/OpenFOAM/OpenFOAM-v2006/bin/tools/RunFunctions: line 208: 5269 Segmentation fault $appRun $appArgs "$@" > $logFile 2>&1 |
#22 |
Benjamin Norris
Hello everyone,
Has anyone had luck compiling waves2Foam on Windows Subsystem for Linux? I have attempted to compile waves2Foam using different versions of OpenFOAM (v2006, v1912, v1812, and v1712) without much luck so far. After reading through many forum posts, I realize that waves2Foam is not fully compliable for newer versions of OF, so I intend to use a stable version with v1812 or v1712, whichever works. I have made sure that all the third-party dependencies are installed and are working (git, gfortran, svn, and gsl), which I installed using apt-get install, e.g., sudo apt-get install git ; sudo apt-get install gfortran ; sudo apt-get install subversion ; and sudo apt-get install libgsl-dev My waves2Foam install folder is located at ~/OpenFOAM/<user>-v<version>/OpenFoam/applications/utilities/waves2Foam as indicated in the instruction manual, where <user> is my username and <version> is 1712, 1812, 1912, etc. and my OpenFOAM installation is located at /opt/OpenFOAM/ When I attempt to compile waves2Foam by entering ~/OpenFOAM/<user>-v<version>/OpenFoam/applications/utilities/waves2Foam and then running ./Allwmake , Ubuntu runs through the compilation to completion. However, in all cases, I get error messages like : -limmiscibleIncompressibleTwoPhaseMixture -lturbulenceModels -lincompressibleTurbulenceModels -lfiniteVolume -lfvOptions -lmeshTools -lsampling -L/home/bknorris/OpenFOAM/bknorris-v1712/platforms/linux64Gcc63DPInt32Opt/lib -lwaves2Foam -lwaves2FoamPorosity -lwaves2FoamSampling -L/usr/lib64 -lgsl -lgslcblas -lOpenFOAM -ldl \ -lm -o /home/bknorris/OpenFOAM/bknorris-v1712/platforms/linux64Gcc63DPInt32Opt/bin/porousWaveFoam /usr/bin/ld: cannot find -lwaves2Foam /usr/bin/ld: cannot find -lwaves2FoamSampling If I try to run say the waveFlume tutorial, I get the following error in one of the log files generated by ./Allrun, /opt/OpenFOAM/OpenFOAM-v1712/bin/tools/RunFunctions: line 146: setWaveParameters: command not found Can anyone help? I'm thinking that maybe waves2Foam is just incompatible with Ubuntu on Windows? I have attached my second run of ./Allwmake if it is of use. Thank you! Ben |
#23 |
Luiz Ferreira
Ubuntu and v1912.
Step by Step: sudo apt-get update && sudo apt-get upgrade sudo apt-get install gcc g++ gfortran gsl-bin make sudo apt-get install m4 bison flex subversion ptscotch cmake sudo apt-get install mpi-default-dev wget sudo apt-get install libz-dev libgsl-dev vim nano git cd $WM_PROJECT_DIR/etc nano bashrc Select the system compiler ->Go to the line where is written WM_COMPILER TYPE export WM_COMPILER_TYPE=system source $HOME/.basrhrc Compile waves2FOAM. If you have some problem at Ocean3D-Fortran go to the folder thirdparty and compile the VTK. Last edited by lppferreira; October 20, 2020 at 13:18. Reason: OpenFOAM version |
#24 |
Benjamin Norris
#25 | |
Vahid
Rep Power: 15 ![]() |
Dear Luiz Hi, Can you explain more how to select system compiler? I cant find it in nano bashrc page ![]() It is for some days that I am trying to install waves2Foam on Ubuntu 18.04. No success ![]() I have tried OpenFoam3.0.1 but failed. Now I have installed openFoam v2006 from source code in HOME folder (I was going to install 1712, but it is no longer available on https://www.openfoam.com/ ). I have done all steps I see in this thread but still no success. I have attached the log file when making waves2FOAM on OFv2006: Waves2FOAM.zip I really appreciate if anyone could help. Best Regards, Vahid |
#26 |
Benjamin Norris
Hi Vahid,
I have put together some instructions for installing waves2foam on Ubuntu (WSL). Please note that these installation instructions are for OF v1912, I do not know if they will work for other versions of OF. Also, you might try un-installing any third party dependencies ("sudo apt-get remove..."), including other OF installations, before trying a 'clean' install of waves2foam. Code:
# How to install waves2Foam on Ubuntu (Windows 10) Install OF v1912: 1. Download .tgz from here: https://www.openfoam.com/download/release-history.php to c:\Users\<USER>\Downloads 2. In Ubuntu, run command: cp -ar /mnt/c/Users/<USER>/Downloads/OpenFOAM-v1912-windows10.tgz . 3. run command: sudo tar -xvzf OpenFOAM-v1912-windows10.tgz -C /opt/ 4. run command: sudo chown -R $USER /opt/OpenFOAM 5. run command: echo "source /opt/OpenFOAM/OpenFOAM-v1912/etc/bashrc" >> ~/.bashrc 6. run command: source $HOME/.bashrc 7. OpenFOAM should work (hint: type 'whereis icoFoam'. If bash returns '/opt/OpenFOAM/OpenFOAM-v1912/platforms/linux64Gcc63DPInt32Opt/bin/icoFoam' then it is working) Install third-party dependencies: 1. run command: sudo apt-get update && sudo apt-get upgrade 2. run command: sudo apt-get install gcc g++ gfortran gsl-bin make 3. run command: sudo apt-get install m4 bison flex subversion ptscotch cmake 4. run command: sudo apt-get install mpi-default-dev wget 5. run command: sudo apt-get install libz-dev libgsl-dev vim nano git 6. run command: cd $WM_PROJECT_DIR/etc 7. edit bashrc: nano bashrc 7a. Select the system compiler -> Go to the line where is written WM_COMPILER TYPE and change 'ThirdParty' to 'system' # [WM_COMPILER_TYPE] - Compiler location: # = system | ThirdParty WM_COMPILER_TYPE system 7b. save bashrc and exit nano 7c. run command: source $HOME/.bashrc Compile waves2Foam: 1. run command: cd ~/ 2. run command: mkdir $HOME/../applications/utilities 3. run command: cd $HOME/../applications/utilities 4. run command: svn co http://svn.code.sf.net/p/openfoam-ex...her/waves2Foam 5. run command: cd waves2Foam/ 6. run command: ./Allwmake 7. waves2Foam should now be compiled; type 'whereis waveFoam', bash should return '/opt/OpenFOAM/OpenFOAM-v1912/platforms/linux64Gcc63DPInt32Opt/bin/waveFoam' Last edited by bknorris; December 18, 2020 at 13:58. Reason: formatting |
#27 | |
Luiz Ferreira
Dear Vahid,
I would strongly suggest to you to use OFv1712 rather OFv2006. Here is the link of the respository for the version https://sourceforge.net/projects/openfoam/files/v1712/ Also, I don't believe that waves2Foam has v2006 version. Finally, to find the bashr of OpenFOAM, you need to search for the etc folder the OpenFOAM installation. For example, /home/<Folder where is installed your OpenFOAM>/etc In a more tangible sample, considering that you are using OFv2006: /home/OpenFOAM-v2006/etc There will be the bashrc. Obs.: if you compiled the source code you don't need to change the bashrc because it will be already at system compiler. Cheers, LP Quote:
#28 |
Vahid
Hello Every one,
Many thanks for quick reply. I will do your instructions and get back soon. Regards, Vahid |
#29 | |
Vahid
I finally made it ![]() As Luiz said, I installed OFv1712 from source code on my Ubuntu18.04. Then downloaded and compiled Wave2Foam exactly according to instructions in its manual. For installing GNU SCIENTIFIC LIBRARY (GSL) dependencies, I found following page helpful: GSL I also tried to install waves2Foam on Ubuntu WSL (on windows10), but it was not successful. I compiled waves2Foam but the tutorials didn't run. Anyway, thank you all for your time. ![]() Best Regards, Vahid |
#30 | |
le
Rep Power: 16 ![]() |
I install wave2foam in OF1812 in centos, get the error "cannot find -lwaves2Foam" Could you give some tips, please. Many Thanks. |
#31 |
Luiz Ferreira
You need to compile the thirdparty inside waves2foam. AfterShip you need tô compile Ocean3d again.
#32 | |
le
I also install wave2foam in of1812 centos 7, i get error "cannot find -lwaves2Foam" Could you give some tips please, thanks. |
#33 |
le
Hello
I also install wave2foam in OF1812 Centos 7, but i got error: cannot find -lgfortran cannot find -lwaves2Foam Could you give me some hints, please. Thanks |
#34 | |
le
#35 |
Sandana Socrates
Rep Power: 0 ![]() |
Dear all,
I am facing an issue with waves2Foam installation in Ubuntu 22.04 with OpenFOAM-v2012. can anyone help me to find this issue? thanks |
#36 |
Kossivi GOKPI
Hello Sandana,
I'm facing an issue installing the version 2012 of openfoam with the same issues that yours. Did you find any solutions to them? Thanks. Kossivi
Thanks in advance, Kossivi. |
#37 |
abdulsalam musaad
Rep Power: 2 ![]() |
Hi Kossivi,
I am facing similar error to what Sandana has attached. i am using openfoamv2312. Please let me know if you found a solution to this problem. Thanks in advance. %%%%%%%%%%% i found the solution to this problem in this thread: Compilation on Ubuntu 22.04 Last edited by AbdoMusaad; April 28, 2024 at 07:16. |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
[OpenFOAM.org] icoFoam: Command not found in OpenFOAM 3.0.1 installation on Ubuntu 16.10 | febriyan91 | OpenFOAM Installation | 2 | July 27, 2020 00:23 |
[OpenFOAM.org] what happens for OpenFOAM related codes when upgrading ubuntu | babakflame | OpenFOAM Installation | 4 | December 31, 2014 09:40 |
Installing OpenFOAM 2.2.0 on Ubuntu 12.10 i686 | AHutchison | OpenFOAM Installation | 6 | June 4, 2013 12:11 |
OpenFOAM vs Ubuntu 10.10 64 bit | vkrastev | OpenFOAM Installation | 12 | April 23, 2011 10:14 |
