[cfMesh] cfMesh Installation with OpenFOAM 6?
Like Tree15Likes
Old   October 4, 2019, 20:20
Marc
marccfd is on a distinguished road
Originally Posted by Krao View Post
Try this I have just compiled on OpenFOAM 7
I followed the instructions in post 8 once again and installed cfMesh on my 64bit machine. There was no problem. I think they have made some changes to the make file already, as you can see in my post. Try it once, good luck.
I just followed the Wiki instructions. After running into an error I tried your change to the option File and ran it again.
I still get this error message
wmake libso meshLibrary
wmakeLnIncludeAll: running wmakeLnInclude on dependent libraries:
    wmakeLnInclude error: base directory /opt/openfoam7/src/edgeMesh/ does not exist
wmakeLnInclude: linking include files to ./lnInclude
All on Ubuntu 18.04.3 LTS and OpenFoam 7
Does anyone know how to tell cf Mesh that the EdgeMesh is not in src anymore?
marccfd is offline   Reply With Quote
Old   November 1, 2019, 06:45
Bruno Lebon
blebon is on a distinguished road
edgeMesh is in src/meshTools, so change line 35 to
-I$(LIB_SRC)/meshTools/edgeMesh/lnInclude \
to get rid of the error.
kcavatar likes this.
blebon is offline   Reply With Quote
Old   December 22, 2019, 10:09
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Originally Posted by wyldckat View Post
Greetings to all!
Merry Christmas! I am re-gifting cfMesh for OpenFOAM 5 and 6 to everyone this year
This to say that I've revised/revamped the wiki page for cfMesh at openfoamwiki.net: https://openfoamwiki.net/index.php/E...ilities/cfMesh
And that there you will now find instructions regarding:
  1. Where you can find cfMesh, its source code and in which OpenFOAM/foam-extend versions is already present and how to build it from source code if not present by default.
    • So much so that there are actually two sets of instructions on how to install cfMesh with OpenFOAM 5 and 6!
  2. Where you you can find the tutorials.
  3. Where you can find the User Guide.
Best regards,
Bruno
Works also for OpenFOAM 7 and the latest -dev Line of the Foundation version.
wyldckat likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   December 27, 2019, 16:45
Retired Super Moderator
Bruno Santos
@Tobi: Many thanks! I've updated the wiki page accordingly.
Old   March 28, 2020, 09:29
Calum Douglas
snowygrouch is on a distinguished road
Dont think this works because InInclude isnt in the edgemesh folder.
The wikipage instructions dont for for me in Ubuntu 18.04 and Of7 on either fork.
still showing compilation erros after wmake because there is no InInclude in edgemesh,
and it tries to create it, and fails.
Calum Douglas
Director
Scorpion Dynamics Ltd
Email: calum.douglas@scorpion-dynamics.com
Web: www.scorpion-dynamics.com
snowygrouch is offline   Reply With Quote
Old   July 19, 2020, 16:54
P
known_by_some is on a distinguished road
I'd also be curious if anyone has successfully compiled cfMesh with OF7. I'm using Ubuntu 20.04 and WSL.
Like snowygrouch said, there is no InInclude in edgemesh - I edited the various paths to fix the other issues as noted in previous comments, but the lack of InInclude in edgemesh seems to be a deal breaker. Am I missing something?
I've been using the included cfMesh as apart of the latest v2006 release, but it seems to have issues with tetMesh and pMesh and I'd like to compile cfMesh myself to see if that resolves it.
known_by_some is offline   Reply With Quote
Old   July 31, 2020, 16:02
iskionrocks is on a distinguished road
I was able to get it to work in OpenFOAM7 by just removing the line referring to edgeMesh as below. I'm not sure if this will have consequences later but I was able to successfully mesh a simple case I am working on right now.
EXE_INC = \
    $(OMP_FLAGS) $(CFMESH_MACROS) \
    -I$(LIB_SRC)/triSurface/lnInclude \
    -I$(LIB_SRC)/surfMesh/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude
LIB_LIBS = $(LIBS)
iskionrocks is offline   Reply With Quote
Old   August 6, 2020, 17:47
Utkun Malkocoglu
Malkocoglu is on a distinguished road
I also tried to compile cfMesh in both versions (OpenFOAM-dev and OpenFOAM-8) by applying suggestions mentioned in this thread (for example, posts #20, #22 and #27) and another thread on this issue (Compiling cfMesh with OpenFOAM 4.x). However, I was not able to compile and I encountered with errors. I attached log file generated during compilation attempt (please see attachment named "log_Allwmake.txt"). So, I am the new one that joined to the crowd. If someone has a solution on this problem, I would be very thankful.
Thanks in advance.
Malkocoglu is offline   Reply With Quote
Old   September 12, 2020, 10:07
giovanni
gian93 is on a distinguished road
I experienced the same issue on of7 and ubuntu 18.04.
I've modified the file "meshLibrary/Make/options" to point correctly at
HTML Code:
Anyway it does not solve the second set of errors . These are the errors related to lnInclude
HTML Code:
lnInclude/DynListI.H: In instantiation of ‘Foam::DynList<T, staticSize>::DynList(const ListType&) [with ListType = int; T = long int; long int staticSize = 16]’:
lnInclude/helperFunctionsTopologyManipulationI.H:491:34:   required from here
lnInclude/DynListI.H:195:15: error: request for member ‘size’ in ‘l’, which is of non-class type ‘const int’
     setSize(l.size());
lnInclude/DynListI.H:197:32: error: subscripted value is neither array nor pointer
         this->operator[](i) = l[i];
lnInclude/DynListI.H: In instantiation of ‘Foam::DynList<T, staticSize>::DynList(const ListType&) [with ListType = int; T = Foam::Vector2D<double>; long int staticSize = 6]’:
lnInclude/helperFunctionsGeometryQueriesI.H:1059:37:   required from here
     setSize(l.size());
please someone that is more skilled than me can have a look into?
thanks
gian93 is offline   Reply With Quote
Old   September 12, 2020, 10:29
Utkun Malkocoglu
Hi gian93,
I overcame this problem by compiling OpenFOAM with WM_LABEL_SIZE=32 option as Bruno (a.k.a wyldckat , former forum moderator) mentioned in another thread. This way, I was able to compile and run cfMesh successfully in OpenFOAM v7 & Ubuntu 20.04.1 LTS.
Hope that it helps, regards,
Malkocoglu
HTML Code:
HTML Code:
     setSize(l.size());
     setSize(l.size());
thanks
Old   September 13, 2020, 01:44
giovanni
Originally Posted by Malkocoglu View Post
Hi gian93,
Malkocoglu
thank you!.. I also tried to build OpenFOAM with WM_LABEL_SIZE=32 and now cfMesh succesfully works.
Old   October 20, 2020, 17:17
Joseph Urich
jurich is on a distinguished road
Hello All,
I have built and run cfMesh successfully in OpenFOAM v7 & v8 using the instructions above & wiki from Bruno (wyldkat). I used WM_LABEL_SIZE=32 and
from the replies above.
In addition I was able to build and run under the current -dev branch by adding this line:
#include "OSspecific.H"
to these source files:
HTML Code:
/meshLibrary/utilities/checkMeshDict/checkMeshDict.C
/meshLibrary/utilities/dataConversion/foamToFPMA/writeMeshFPMA.C
/meshLibrary/utilities/meshes/polyMeshGen/polyMeshGen.C
jurich is offline   Reply With Quote
Old   December 24, 2020, 08:50
Exclamation cartesianMesh : command not found
  #33
Anusha
Anushaa is on a distinguished road
I am using OpenFOAM 6 and in its modules cfMesh is included.But when I wanted use commands like " surfaceFeatureEdges" and "cartesianMesh" it said its not found.
Please let me know how to proceed.
Anushaa is offline   Reply With Quote
Old   December 29, 2020, 07:46
Default Wm_label_size
  #34
Kahnbein.Kai is on a distinguished road
sorry to interrupt, i would like to install cfmesh with OF v8.
I changed the line 35 in the options file but still get an error while compiling.
ops, i forgot to post my error:
    mkdir: das Verzeichnis »/opt/openfoam8/src/meshTools/edgeMesh//lnInclude“ kann nicht angelegt werden: Keine Berechtigung
wmakeLnInclude error: failed to create include directory /opt/openfoam8/src/meshTools/edgeMesh//lnInclude
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -DUSE_OMP -fopenmp -DNoSizeType -I/opt/openfoam8/src/triSurface/lnInclude -I/opt/openfoam8/src/surfMesh/lnInclude -I/opt/openfoam8/src/meshTools/edgeMesh/lnInclude -I/opt/openfoam8/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam8/src/OpenFOAM/lnInclude -I/opt/openfoam8/src/OSspecific/POSIX/lnInclude   -fPIC -c utilities/meshes/polyMeshGen/polyMeshGen.C -o Make/linux64GccDPInt32Opt/utilities/meshes/polyMeshGen/polyMeshGen.o
In file included from lnInclude/meshSubset.H:162,
                 from utilities/meshes/polyMeshGen/polyMeshGenPoints.H:45,
                 from utilities/meshes/polyMeshGen/polyMeshGenFaces.H:40,
                 from utilities/meshes/polyMeshGen/polyMeshGenCells.H:40,
                 from utilities/meshes/polyMeshGen/polyMeshGen.H:39,
                 from utilities/meshes/polyMeshGen/polyMeshGen.C:28:
lnInclude/meshSubsetI.H: In member function ‘bool Foam::meshSubset::operator==(const Foam::meshSubset&) const’:
lnInclude/meshSubsetI.H:173:18: warning: self-comparison always evaluates to false [-Wtautological-compare]
  173 |     if( ms.type_ != ms.type_ )
In file included from utilities/meshes/polyMeshGen/polyMeshGen.C:28:
utilities/meshes/polyMeshGen/polyMeshGen.H: At global scope:
utilities/meshes/polyMeshGen/polyMeshGen.H:52:9: error: ‘IOdictionary’ does not name a type; did you mean ‘dictionary’?
   52 |         IOdictionary metaDict_;
      |         dictionary
utilities/meshes/polyMeshGen/polyMeshGen.H: In member function ‘const Foam::dictionary& Foam::polyMeshGen::metaData() const’:
utilities/meshes/polyMeshGen/polyMeshGen.H:89:20: error: ‘metaDict_’ was not declared in this scope; did you mean ‘metaData’?
   89 |             return metaDict_;
      |                    metaData
utilities/meshes/polyMeshGen/polyMeshGen.H: In member function ‘Foam::dictionary& Foam::polyMeshGen::metaData()’:
utilities/meshes/polyMeshGen/polyMeshGen.H:95:20: error: ‘metaDict_’ was not declared in this scope; did you mean ‘metaData’?
   95 |             return metaDict_;
      |                    metaData
utilities/meshes/polyMeshGen/polyMeshGen.C: In constructor ‘Foam::polyMeshGen::polyMeshGen(const Foam::Time&)’:
utilities/meshes/polyMeshGen/polyMeshGen.C:40:5: error: class ‘Foam::polyMeshGen’ does not have any field named ‘metaDict_’
   40 |     metaDict_
utilities/meshes/polyMeshGen/polyMeshGen.C: In constructor ‘Foam::polyMeshGen::polyMeshGen(const Foam::Time&, const pointField&, const faceList&, const cellList&)’:
utilities/meshes/polyMeshGen/polyMeshGen.C:64:5: error: class ‘Foam::polyMeshGen’ does not have any field named ‘metaDict_’
   64 |     metaDict_
utilities/meshes/polyMeshGen/polyMeshGen.C: In constructor ‘Foam::polyMeshGen::polyMeshGen(const Foam::Time&, const pointField&, const faceList&, const cellList&, const wordList&, const labelList&, const labelList&)’:
utilities/meshes/polyMeshGen/polyMeshGen.C:100:5: error: class ‘Foam::polyMeshGen’ does not have any field named ‘metaDict_’
  100 |     metaDict_
utilities/meshes/polyMeshGen/polyMeshGen.C: In member function ‘void Foam::polyMeshGen::write() const’:
utilities/meshes/polyMeshGen/polyMeshGen.C:156:5: error: ‘metaDict_’ was not declared in this scope; did you mean ‘metaData’?
  156 |     metaDict_.writeHeader(fName);
      |     metaData
make: *** [/opt/openfoam8/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/utilities/meshes/polyMeshGen/polyMeshGen.o] Fehler 1
wmake executables
wmake cartesian2DMesh
make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfMesh/executables/cartesian2DMesh“ wird betreten
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -DNoSizeType -I/opt/openfoam8/src/triSurface/lnInclude -I/opt/openfoam8/src/meshTools/lnInclude -I/opt/openfoam8/src/finiteVolume/lnInclude -I/opt/openfoam8/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/opt/openfoam8/src/OpenFOAM/lnInclude -I/opt/openfoam8/src/OSspecific/POSIX/lnInclude   -fPIC -c cartesian2DMesh.C -o Make/linux64GccDPInt32Opt/cartesian2DMesh.o
In file included from ../../meshLibrary/lnInclude/meshSubset.H:162,
                 from ../../meshLibrary/lnInclude/polyMeshGenPoints.H:45,
                 from ../../meshLibrary/lnInclude/polyMeshGenFaces.H:40,
                 from ../../meshLibrary/lnInclude/polyMeshGenCells.H:40,
                 from ../../meshLibrary/lnInclude/polyMeshGen.H:39,
                 from ../../meshLibrary/lnInclude/cartesian2DMeshGenerator.H:38,
                 from cartesian2DMesh.C:33:
../../meshLibrary/lnInclude/meshSubsetI.H: In member function ‘bool Foam::meshSubset::operator==(const Foam::meshSubset&) const’:
../../meshLibrary/lnInclude/meshSubsetI.H:173:18: warning: self-comparison always evaluates to false [-Wtautological-compare]
In file included from ../../meshLibrary/lnInclude/cartesian2DMeshGenerator.H:38,
../../meshLibrary/lnInclude/polyMeshGen.H: At global scope:
../../meshLibrary/lnInclude/polyMeshGen.H:52:9: error: ‘IOdictionary’ does not name a type; did you mean ‘dictionary’?
      |         dictionary
../../meshLibrary/lnInclude/polyMeshGen.H: In member function ‘const Foam::dictionary& Foam::polyMeshGen::metaData() const’:
../../meshLibrary/lnInclude/polyMeshGen.H:89:20: error: ‘metaDict_’ was not declared in this scope; did you mean ‘metaData’?
      |                    metaData
../../meshLibrary/lnInclude/polyMeshGen.H: In member function ‘Foam::dictionary& Foam::polyMeshGen::metaData()’:
../../meshLibrary/lnInclude/polyMeshGen.H:95:20: error: ‘metaDict_’ was not declared in this scope; did you mean ‘metaData’?
      |                    metaData
make[1]: *** [/opt/openfoam8/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/cartesian2DMesh.o] Fehler 1
make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfMesh/executables/cartesian2DMesh“ wird verlassen
make: *** [/opt/openfoam8/wmake/makefiles/apps:39: cartesian2DMesh] Fehler 2
wmake utilities
wmake checkSurfaceMesh
make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfMesh/utilities/checkSurfaceMesh“ wird betreten
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -DNoSizeType -I/opt/openfoam8/src/triSurface/lnInclude -I/opt/openfoam8/src/meshTools/lnInclude -I/opt/openfoam8/src/finiteVolume/lnInclude -I/opt/openfoam8/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/opt/openfoam8/src/OpenFOAM/lnInclude -I/opt/openfoam8/src/OSspecific/POSIX/lnInclude   -fPIC -fuse-ld=bfd -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/checkSurfaceMesh.o -L/opt/openfoam8/platforms/linux64GccDPInt32Opt/lib \
    -lmeshTools -ltriSurface -lfiniteVolume -ledgeMesh -L/home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/lib -lmeshLibrary -lOpenFOAM -ldl  \
     -lm -o /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/bin/checkSurfaceMesh
/usr/bin/ld.bfd: -ledgeMesh kann nicht gefunden werden
/usr/bin/ld.bfd: -lmeshLibrary kann nicht gefunden werden
collect2: error: ld returned 1 exit status
make[1]: *** [/opt/openfoam8/wmake/makefiles/general:142: /home/kai/OpenFOAM/kai-8/platforms/linux64GccDPInt32Opt/bin/checkSurfaceMesh] Fehler 1
make[1]: Verzeichnis „/home/kai/OpenFOAM/kai-8/cfMesh/utilities/checkSurfaceMesh“ wird verlassen
make: *** [/opt/openfoam8/wmake/makefiles/apps:39: checkSurfaceMesh] Fehler 2
Where can i find the WM_LABEL_SIZE Option or the original thread of wyldckat or even better the wiki post ?
Best regards
Kai
Kahnbein.Kai is offline   Reply With Quote
Old   December 29, 2020, 11:46
Is this the "right" file $WM_PROJECT_DIR/etc/bashrc ?
At line 80 ? The value is already at 32 at my file.
Best regards
Kai
Old   December 30, 2020, 12:29
Utkun Malkocoglu
@Anushaa
Are you sure that Foundation (CFD Direct) branch of OpenFOAM contains built-in cfMesh? I also use CFD Direct OpenFOAM and I have never seen any utility regarding cfMesh? I have additionally compiled cfMesh with OpenFOAM. So, you may need to re-compile it as well.
Old   December 30, 2020, 12:55
Utkun Malkocoglu
      |         dictionary
      |                    metaData
      |                    metaData
   40 |     metaDict_
   64 |     metaDict_
  100 |     metaDict_
      |     metaData
wmake executables
      |         dictionary
      |                    metaData
      |                    metaData
wmake utilities
Best regards
Kai
Hello @Kahnbein.Kai
Because there is not extended instructions for OpenFOAM-8 in OFWiki, I have to direct you to OpenFOAM-7 (there is no significant difference from 7 to 8 - at least, in this issue) variant in OFWiki, the link is:
https://openfoamwiki.net/index.php/I...7/Ubuntu/18.04
Here, when you are building OpenFOAM in step 7:
"For x86_64, it depends on whether you need 64-bit integer support or not:
For building with the normal 32-bit integer support (maximum 2.147×109 cells, faces or points):
source $HOME/OpenFOAM/OpenFOAM-7/etc/bashrc FOAMY_HEX_MESH=yes
Therefore, you may either use this form or alternatively:
source $HOME/OpenFOAM/OpenFOAM-7/etc/bashrc WM_LABEL_SIZE=32 FOAMY_HEX_MESH=yes
I do not know how you complied at the building phase, but in post 30, I meant this way.
I struggled to find it, unfortunately, but I was not able to do. However;
I do not know if you directly source OpenFOAM or use alias for sourcing every time that you use OpenFOAM, anyway does not matter, source your OpenFOAM by using WM_LABEL_SIZE=32 option (at least when you would like to use cfMesh, as well). If you use alias, please update your ~/.bashrc file regarding that.
If this also does not work, turn back and build your OpenFOAM by using "WM_LABEL_SIZE=32" as written above.
Hope that it helps, take care of yourselves,
Malkocoglu
Old   December 30, 2020, 19:32
Anusha
This is what I have :
anusha@DESKTOP-JPOD8EC:~$ cd /mnt/c/OpenFOAM-v2006/modules/
anusha@DESKTOP-JPOD8EC:/mnt/c/OpenFOAM-v2006/modules$ ls
Allwmake OpenQBMM README.md adios avalanche cfmesh doc external-solver list-modules visualization
anusha@DESKTOP-JPOD8EC:/mnt/c/OpenFOAM-v2006/modules$ cd cfmesh/
anusha@DESKTOP-JPOD8EC:/mnt/c/OpenFOAM-v2006/modules/cfmesh$ ls
Allwclean Allwmake README executables meshLibrary python testingInterfaces tutorials userGuide utilities
anusha@DESKTOP-JPOD8EC:/mnt/c/OpenFOAM-v2006/modules/cfmesh$ cd tutorials/
anusha@DESKTOP-JPOD8EC:/mnt/c/OpenFOAM-v2006/modules/cfmesh/tutorials$ ls
Allclean Allrun cartesian2DMesh cartesianMesh pMesh tetMesh
anusha@DESKTOP-JPOD8EC:/mnt/c/OpenFOAM-v2006/modules/cfmesh/tutorials$ cd cartesianMesh/
anusha@DESKTOP-JPOD8EC:/mnt/c/OpenFOAM-v2006/modules/cfmesh/tutorials/cartesianMesh$ ls
asmoOctree elbow_90degree multipleOrifices sawOctree singleOrifice
bunnyOctree intakePortOctree sBendOctree ship5415Octree trial
anusha@DESKTOP-JPOD8EC:/mnt/c/OpenFOAM-v2006/modules/cfmesh/tutorials/cartesianMesh$ cd asmoOctree/
anusha@DESKTOP-JPOD8EC:/mnt/c/OpenFOAM-v2006/modules/cfmesh/tutorials/cartesianMesh/asmoOctree$ cartesianMesh
cartesianMesh: command not found
i tired compile the code but ... I got this :
anusha@DESKTOP-JPOD8EC:~$ git clone https://github.com/blueCFD/cfMesh.git cfmesh
fatal: destination path 'cfmesh' already exists and is not an empty directory.
anusha@DESKTOP-JPOD8EC:~$ w (0.36-0ubuntu0.18.04.1) ...
anusha@DESKTOP-JPOD8EC:~$ me-support (3.60ubuntu1) ...
anusha@DESKTOP-JPOD8EC:~$ eadahead (0.100.0-21) ...
anusha@DESKTOP-JPOD8EC:~$ stall-info (6.5.0.dfsg.1-2) ...
anusha@DESKTOP-JPOD8EC:~$ bc-bin (2.27-3ubuntu1.3) ...
anusha@DESKTOP-JPOD8EC:~$ stemd (237-3ubuntu10.43) ...
anusha@DESKTOP-JPOD8EC:~$ cd cfmesh
anusha@DESKTOP-JPOD8EC:~/cfmesh$ git checkout development-OF5x
fatal: not a git repository (or any of the parent directories): .git
anusha@DESKTOP-JPOD8EC:~/cfmesh$ ls
cfmesh
anusha@DESKTOP-JPOD8EC:~/cfmesh$ ./Allwmake > log.make 2>&1
-bash: ./Allwmake: No such file or directory
Old   December 31, 2020, 08:06
Hey Malkocoglu, thank you for this detailed answer. I'm a little bit confused now, to install OF v7 and v8 i used this https://openfoam.org/download/8-ubuntu/ instruction. Both installations are placed in Computer/opt/openfoam(7 or 8). In my home folder i copied the tutorial folder, to edit and run it. Is this the wrong way to install OpenFaom ? Your linked instruction is much longer then i have used. Best regards and i wish you a healthy start into the new year, Kai
cfmesh, installation
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
[Discussion] Restructuring the Installation page at openfoamwiki.net wyldckat OpenFOAM Installation 16 November 2, 2013 12:43
Trouble shooting about OpenFOAM installation in Ubuntu 12.04 Nait OpenFOAM Installation 2 December 12, 2012 11:20
Installation of OpenFOAM 1.7.1 to OprnSUSE 11.2 superfxfund OpenFOAM Installation 3 November 11, 2010 03:15
