[Other] Explain about the coefficients in the kOmegaSSTLM turbulence Model
Old   April 2, 2018, 04:04
Default Explain about the coefficients in the kOmegaSSTLM turbulence Model
ESI
ht2017 is on a distinguished road
Hi everyone,
Now, I am working with kOmegaSSTLM turbulence model in the OpenFOAM but I have a question want to everyone explain. In this turbulence have the 6 default LM coefficients is "Ca1,Ca2,Ce1,Ce2,Cthetat,sigma theta". So that How to do you have the value of all coefficients and what is the meaning of the coefficients. I have read the three references which are the concerning this turbulence. this is:
- langtry,R.B.,& Menter, F.R.(2009). correlation-based transition modelling for unstructured parallelized computational fluid dynamics codes.
- Menter F.R., Langtry, R.,& Volker,s.(2006) transition modelling for general purpose CFD code.
- Langtry,R,B.(2006).
A correlation-based transition model using local variables for unstructured parallelized CFD codes. PhD. Thesis, University Stuttgart.
But I also understand the meaning of all coefficients and the range of them.
So if who can know about the coefficients above or have the range of value the coefficients. pleases Let's me know. I am very grateful for that.
Thank you so much.
ht2017 is offline   Reply With Quote
Old   April 24, 2019, 19:28
Alejandro
ancolli is on a distinguished road
As far as I understand. They are just correlation parameters that were obtained by fitting experimental results.
ancolli is offline   Reply With Quote
Old   April 23, 2020, 04:55
Gareth
bullmut is on a distinguished road
I wrote a paper on the coefficients in the model and how they were fitted
bullmut is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Spalarat - Allmaras turbulence model saisanthoshm88 Main CFD Forum 1 June 16, 2014 17:33
What model of turbulence choose to study an external aerodynamics case raffale OpenFOAM 0 August 23, 2012 06:45
