[PyFoam] PyFoam 6.6.9 installation problems
Old   March 6, 2018, 17:13
Default PyFoam 6.6.9 installation problems
Klaus
klausb will become famous soon enough
PyFoam is not working properly. I installed it using pip so I can plot the residuals from my new OpenFoam 5.0 installation.
Issue 1: the installed gnuplot version 5.2.2-7 is not recognized
I tested gnuplot and it works fine.
Issue 2: pyFoamVersion.py seems to identify the installed OpenFoam 5.0 as a fork version
Issue 3: The residual plot using pyFoamPlotRunner.py doesn't work at all.
pyFoamVersion.py gives the following information:
Machine info: Linux | test | 4.15.7-60.current | #1 SMP PREEMPT Thu Mar 1 13:02:55 UTC 2018 | x86_64 |
Python version: 2.7.14 (default, Feb 17 2018, 10:27:51)
[GCC 7.3.0]
Python executable: /usr/bin/python2.7
Python 2.7 is one development platform for PyFoam (along with Python 3)
PYTHONPATH is not set
Location of this utility: /usr/bin/pyFoamVersion.py
 PyFoam WARNING on line 202 of file /usr/lib/python2.7/site-packages/PyFoam/FoamInformation.py : Basedir /home/klaus/foam for fork extend does not exist or is not a directory
Version 5.0 (reported as number 5.0 )Fork openfoam of the installed 1 versions:
openfoam-5.0 : /home/klaus/OpenFOAM/OpenFOAM-5.0
pyFoam-Version: 0.6.9
Path where PyFoam was found (PyFoam.__path__) is ['/usr/lib/python2.7/site-packages/PyFoam']
Configuration search path: [('file', '/etc/pyFoam/pyfoamrc'), ('directory', '/etc/pyFoam/pyfoamrc.d'), ('file', '/home/klaus/.pyFoam/pyfoamrc'), ('directory', '/home/klaus/.pyFoam/pyfoamrc.d')]
Configuration files (used): []
Installed libraries:
cython                         :  No      Not used. Maybe will by used later to spped up parts of PyFoam
cProfile                       :  Yes
docutils                       :  No      Not necessary. Needed for RestructuredText to HTML conversion
Gnuplot                        :  No      Not a problem. Version from ThirdParty is used
hotshot                        :  Yes
line_profiler                  :  No      Not a problem. Can't profile using this library
ipdb                           :  No      Not necessary. Only makes debugging more comfortable
IPython                        :  No      Not necessary. But the interactive shell may be more comfortable
matplotlib                     :  No      Only Gnuplot-plotting possible
mercurial                      :  No      Not a problem. Used for experimental case handling
pytest                         :  No      Only needed for running the unit-tests (developers only)
numpy                          :  Yes      version: 1.14.1
openpyxl                       :  No      Not a problem. Only used for exporting pandas-data to Excel-files (advanced). If xlsxwriter is installed it will handle this (xlsxwriter is recommended anyway)
xlsxwriter                     :  No      Not a problem. Only used for exporting pandas-data to XLSX-files (advanced). If openpyxl is installed then this module can handle that
pandas                         :  No      Not a problem. Only used for handling of advanced data-handling
ply                            :  No      Not a problem. Version from ThirdParty is used
profile                        :  Yes
psyco                          :  No      Not a problem. Acceleration not possible
PyQt4                          :  No      Only some experimental GUI-stuff relies on this
PyQt4.Qwt5                     :  No      Only an alternate plotting back-end
scipy                          :  No      Not yet used. Possibly use signal-fitting etc
Tkinter                        :  Yes      version: $Revision: 81008 $
twisted                        :  No      Not yet used. Possibly reimplement MetaServer with it
vtk                            :  No      Not a problem. Only used for some utilities
xlwt                           :  No      Not a problem. Only used for exporting pandas-data to Excel-files
xlrd                           :  No      Not a problem. Only used for importing Excel-files to pandas-data
requests                       :  Yes      version: 2.18.4
zeroconf                       :  No      Not a problem. Necessary to find existing runs. Install with 'pip install zeroconf'
psutil                         :  No      Not a problem. Provides better calculation of the maximum used memory
PyFoam.ThirdParty.ply.yacc     :  Yes      version: 3.9
PyFoam.ThirdParty.Gnuplot      :  Yes      version: 1.8
PyFoam.ThirdParty.tqdm         :  Yes      version: 4.8.4
PyFoam.ThirdParty.IPy          :  Yes      version: 0.51
PyFoam.ThirdParty.pyratemp     :  Yes      version: 0.2.0
PyFoam.ThirdParty.six          :  Yes      version: 1.10.0
PyFoam.ThirdParty.winhacks     :  Yes
Library locations
cProfile                       : /usr/lib/python2.7/cProfile.py
hotshot                        : /usr/lib/python2.7/hotshot/__init__.py
numpy                          : /usr/lib/python2.7/site-packages/numpy/__init__.pyc
profile                        : /usr/lib/python2.7/profile.py
PyFoam.ThirdParty.Gnuplot      : /usr/lib/python2.7/site-packages/PyFoam/ThirdParty/Gnuplot/__init__.pyc
PyFoam.ThirdParty.IPy          : /usr/lib/python2.7/site-packages/PyFoam/ThirdParty/IPy.pyc
PyFoam.ThirdParty.ply.yacc     : /usr/lib/python2.7/site-packages/PyFoam/ThirdParty/ply/yacc.pyc
PyFoam.ThirdParty.pyratemp     : /usr/lib/python2.7/site-packages/PyFoam/ThirdParty/pyratemp.pyc
PyFoam.ThirdParty.six          : /usr/lib/python2.7/site-packages/PyFoam/ThirdParty/six.pyc
PyFoam.ThirdParty.tqdm         : /usr/lib/python2.7/site-packages/PyFoam/ThirdParty/tqdm/__init__.pyc
PyFoam.ThirdParty.winhacks     : /usr/lib/python2.7/site-packages/PyFoam/ThirdParty/winhacks.pyc
requests                       : /usr/lib/python2.7/site-packages/requests/__init__.pyc
Tkinter                        : /usr/lib/python2.7/lib-tk/Tkinter.pyc
Checking additional envirnoment variables
Checking for PYFOAM_DIR : Location of the PyFoam-installation. Not strictly necessary
PYFOAM_DIR missing from environment
Checking for PYFOAM_SITE_DIR : Location of non-PyFoam-disctributions script. Set and used by some Foam-distributions
PYFOAM_SITE_DIR missing from environment
User information
Username:             klaus
Temporary directory:  /tmp/PyFoam_klaus
Public key:           3be4f830574208f17776e286f2609b:052e3e1262b0781fa5026f3281772dab
What's wrong with the installation?
Klaus
klausb is offline   Reply With Quote
Old   March 6, 2018, 20:29
Assistant Moderator
Bernhard Gschaider
Originally Posted by klausb View Post
[GCC 7.3.0]
cProfile                       :  Yes
hotshot                        :  Yes
profile                        :  Yes
Library locations
User information
Username:             klaus
Klaus
Installation seems to be OK. The problem is probably with gnuplot. Can you elaborate on "I tested gnuplot"? Also: which terminal does gnuplot use when you see plots with windows ("x11" or something different?)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 2, 2022, 06:56
Sanjay R
SanWick002 is on a distinguished road
Have you solved the problem? since I too seem to have the same issue...
SanWick002 is offline   Reply With Quote
[PyFoam] Problems with installing PyFoam Christoph_84 OpenFOAM Community Contributions 34 October 26, 2021 12:25
[OpenFOAM.com] v1606+ Problems of installation on iMac Intercooled OpenFOAM Installation 4 November 15, 2016 21:22
Problems installing SVN in Ubuntu (for later installing PyFoam for OpenFOAM) immortality Lounge 2 May 24, 2014 04:05
Problems with installation batta31 OpenFOAM Installation 2 September 4, 2012 08:01
installation problems on upgrade from win 3.26 to mic Siemens 5 June 20, 2007 10:40
