[PyFoam] PyFoam 0.6.9 wrong path to gnuplot
Old   March 2, 2018, 19:53
Default PyFoam 0.6.9 wrong path to gnuplot
Klaus
klausb will become famous soon enough
I installed PyFoam 0.6.9 using pip. Problem is, the path to the gnuplot installation is wrong hence the residual plot cannot be displayed.
I get the following error message:
Expected X11 driver: /usr/lib64/gnuplot/gnuplot/5.2/gnuplot_x11
Exec failed: No such file or directory
See 'help x11' for more details
I tested both programs and both work fine independently.
I also checked an older Ubuntu installation and in both cases, Ubuntu and my new Linux installation, gnuplot is installed in the /usr/bin /usr/share/gnuplot /usr/share/gnuplot/5.2 or /usr/lib/gnuplot directories.
How/Where can I adjust the path to gnuplot in PyFoam 0.6.9?
The workaround I tried is:
1: Create the expected folder structure /usr/lib64/gnuplot/gnuplot/5.2/gnuplot_x11
2: Create a symbolic link to gluplot
3: Now I had to create SSL certificates
And got the following errors:
gnuplot> BSR
line 0: invalid command
gnuplot> X -1 1 1 -1 -1
gnuplot> BSR
gnuplot> BSR
gnuplot> BSR
gnuplot> X 0 1 1 -1 -1
line 0: line 0: invalid commandinvalid command
gnuplot> BSR
line 0: invalid commandline 0:
invalid command
gnuplot> BSR
line 0:
invalid command
gnuplot> BSR
gnuplot> npyFoam: Bounded variables
line 0: invalid command ^
gnuplot> BSR
line 0: invalid command line 0:
invalid command^
gnuplot> BSR
line 0:
gnuplot> npyFoam: Continuity
invalid command
gnuplot> npyFoam: Residuals
Any idea how to fix this?
Klaus
klausb is offline   Reply With Quote
Old   March 6, 2018, 20:23
Assistant Moderator
Bernhard Gschaider
Originally Posted by klausb View Post
gnuplot> BSR
gnuplot> BSR
gnuplot> BSR
gnuplot> BSR
gnuplot> BSR
invalid command
gnuplot> BSR
line 0:
invalid command
gnuplot> BSR
gnuplot> BSR
invalid command^
gnuplot> BSR
line 0:
invalid command
Klaus
The Gnuplot-library that is installed with PyFoam uses the first gnuplot-command it finds in the PATH (check with "which gnuplot")
Which Linux are you using (you stated that your "old" installation was an Ubuntu. The current is just called "new Linux")
One frequent problem is that some distros have a generic gnuplot-package that can do no graphics. For plotting windows another package gnuplot-x11 (or similar) is needed. Check if that is the problem in you case
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 8, 2018, 08:52
Klaus
which gnuplot gives me:
/usr/bin/gluplot
When I start gnuplot, gnuplot> plot sin(x) shows the expected graph on screen.
When I use "gnuplot as a function" and enter: gnuplot '-p -e sin(x)' directly in the terminal, the parameter -p is required to get the same result. Without -p, the graph is just showing up for a fraction of a second.
Terminal type is 'wxt'
Old   March 14, 2018, 08:35
Assistant Moderator
Bernhard Gschaider
/usr/bin/gluplot
By default PyFoam uses the x11-terminal and if that is not there it's got a problem. But you could try to add the option --gnuplot-terminal=wxt
Old   March 15, 2018, 11:01
Klaus
I am using the option: --gnuplot-terminal=wxt
The plot starts but the gnuplot errors in the logfile remain.
Old   March 15, 2018, 15:28
Assistant Moderator
Bernhard Gschaider
The "BSR"-errors? No idea. Don't get them with wxt (and without too)
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
udf error srihari FLUENT 1 October 31, 2016 15:18
meshing of a compound volume in GMSH shawn3531 OpenFOAM 4 March 12, 2015 11:45
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
One critical error while compiling lam711 billpeace OpenFOAM Installation 0 October 30, 2006 05:41
