March 2, 2023, 07:54 |
extrude function - snap -- Snappyhexmesh -- y-direction
#441 |
Rep Power: 6 |
Hii,
I have been trying around making a mesh with only one cell in y-direction after doing snappyhexmesh ( I need snap function turned on). But without any progress. Take the example of breakater tutorial (https://github.com/phicau/olaFlow/tr...als/breakwater), if turn on the snap, then the whole thing wont be 2d. Can anyone suggest something to work around this ? I heard something like ExtrudeMeshDict or Extrude2dMeshDict, but could not clearly understand. May be for this breakwater case, snap function need not be necessary but for other complex geometries, it might be useful. Paul |
April 4, 2023, 05:44 |
piston wave maker
#442 |
Anne
Dear Pablo,
Thanks a lot for all your work and help. I have two questions: - I am using foam-extend 3.1 and trying to build a set up with the use of the wavemakertutorial in the old tutorials and FE_latest. I am trying to mimic a wave paddle signal from the lab and match surface elevation results. I feel like my results are off. The wave paddle is located a little bit to the right of the inlet and I feel like the moving wall boundary condition is not correct because of this. I would like the wave paddle to be located at the inlet, right? I added the result of the first time step, the layout of the flume, and 0.org. Should I change the bc's (I haven't modified them from the tutorial), or try and move the piston to the inlet (not sure how / don't understand why it starts there)? - Second, I want to plot surface elevation data at the wave gauges and using the breakwater tutorial for it, but the results are very very small. I added an example of the results from just trying to add wave gauges to the wavemakerflume tutorial. Do you recognize this problem? Best, Anne |
April 14, 2023, 01:36 |
compiling error
#443 |
Rep Power: 8 |
Hi. I am trying to compile olaFloe on openFoam2212. I get the following message:
In file included from overOlaDyMFlow.C:225: pEqn.H:13:18: fatal error: interpolatedFaces.H: No such file or directory 13 | #include "interpolatedFaces.H" | ^~~~~~~~~~~~~~~~~~~~~ compilation terminated. And the compilation failed. How can I fix it? Thanks |
April 16, 2023, 14:40 |
Error using olaDyMFlow
#444 |
Rep Power: 8 |
I tried to run the wavemakerTank using openFoam2206 and I have the following message:
otorres$ mpirun -np 4 olaDyMFlow -parallel > olaDyMFlow.log [0] #0 Foam::error:rintStack(Foam::Ostream&) at ??:? [0] #1 Foam::sigFpe::sigHandler(int) at ??:? [0] #2 ? in /lib/x86_64-linux-gnu/libc.so.6 [0] #3 Foam::inv(Foam::Field<Foam::Tensor<double> >&, Foam::UList<Foam::Tensor<double> > const&) at ??:? [0] #4 ? in ~/OpenFOAM/otorres-v2206/platforms/linux64GccDPInt32Opt/bin/olaDyMFlow [0] #5 ? in ~/OpenFOAM/otorres-v2206/platforms/linux64GccDPInt32Opt/bin/olaDyMFlow [0] #6 ? in ~/OpenFOAM/otorres-v2206/platforms/linux64GccDPInt32Opt/bin/olaDyMFlow [0] #7 ? in ~/OpenFOAM/otorres-v2206/platforms/linux64GccDPInt32Opt/bin/olaDyMFlow [0] #8 ? in /lib/x86_64-linux-gnu/libc.so.6 [0] #9 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 [0] #10 ? in ~/OpenFOAM/otorres-v2206/platforms/linux64GccDPInt32Opt/bin/olaDyMFlow [OTORRES:00521] *** Process received signal *** [OTORRES:00521] Signal: Floating point exception (8) [OTORRES:00521] Signal code: (-6) [OTORRES:00521] Failing at address: 0x3e800000209 [OTORRES:00521] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7ff66dc79520] [OTORRES:00521] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7ff66dccda7c] [OTORRES:00521] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7ff66dc79476] [OTORRES:00521] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7ff66dc79520] [OTORRES:00521] [ 4] /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam3invERNS_5FieldINS_6TensorI dEEEERKNS_5UListIS2_EE+0x4e2)[0x7ff66e707632] [OTORRES:00521] [ 5] olaDyMFlow(+0xa0259)[0x55c7c524e259] [OTORRES:00521] [ 6] olaDyMFlow(+0x1082d1)[0x55c7c52b62d1] [OTORRES:00521] [ 7] olaDyMFlow(+0x10e722)[0x55c7c52bc722] [OTORRES:00521] [ 8] olaDyMFlow(+0x348aa)[0x55c7c51e28aa] [OTORRES:00521] [ 9] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7ff66dc60d90] [OTORRES:00521] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7ff66dc60e40] [OTORRES:00521] [11] olaDyMFlow(+0x3f885)[0x55c7c51ed885] [OTORRES:00521] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that process rank 0 with PID 0 on node OTORRES exited on signal 8 (Floating point exception). Does any one know how to fix it? |
May 29, 2023, 07:19 |
NWT size
#445 |
Biku
Rep Power: 4 |
What is the general thumb rule do you all follow while setting up the domain size? How much do you truncate the flume?
For the Z direction how many divisions would be decent enough for good capturing of the free surface? |
June 6, 2023, 19:13 |
Curious about generate irregular wave spectrum
#446 |
HYUNGSIK HWANG
Dear colleague.
Hello, now I am study about olaFlow. I am success about generate regular waves(cnoidal, stokes1~4, solitary) in my olaflow samples. but, I do not know how can I generate irregular wave's waveDict file type of JONSWAP specturm(or BM spectrum)? Is there any material I can refer to in the tutorial? |
June 20, 2023, 15:21 |
Munmap_chunk(): invalid pointer fix
#447 |
Jacob Fontaine
Rep Power: 4 |
Hello everyone,
I experienced some headaches with figuring out the ER-AWA outlet condition and figured I would share the experience and how I fixed it. I was using OpenFOAM v2012 and would still get the "invalid pointer" error when trying to test the baseWaveFlumeNewAbs. I was using Ubuntu 20.04 (WSL2) at first, but then switched to Ubuntu 18.04 (WSL2) and installed OpenFOAM v2012 and the tutorial worked perfectly. In short, to fix the "invalid pointer" error for the ER-AWA in OpenFOAM v2012, switch to Ubuntu 18.04 if you are using Windows Subsystem for Linux 2 (WSL2). - Jacob |
June 28, 2023, 04:33 |
questions about velociity absorption on generation boundary
#448 |
Zheng Yuqian
Rep Power: 4 |
Hi Pablo!
I found a statement of absorption velocity in file "waveVelocityFvPatchVectorField.C" as
August 18, 2023, 06:39 |
Weird gauge plots
#449 |
Biku
Rep Power: 4 |
I am getting some weird plots for my free surface profile for Gauge no 4.
It is is a 3D simulation of a NWT using the cnoidal wave theory with depth 0.55m and wave height of 0.13m. The period is 3sec. There are no structures present. The gauge 4 readings are crooked for some reason. Last edited by Biku; August 18, 2023 at 06:51. Reason: Additional information to the reply. |
September 1, 2023, 21:26 |
Wrong water depth on olaflow
#450 |
Sarah Aguiar
Rep Power: 3 |
Hi, everyone, I'm having a problem with a case. I set my geometry with blockMesh and seems ok, I tested it running a simulation with the wavedict from BaseWaveFlume tutorial and it works good, BUT, when I set a diferent wave height and period the simulation do not work. The water depth is totally wrong and the simulation goes crazy, all the water goes with the wave like it was a tsuname.
I'm copping here a drive link with my blockmesh, log.olaflow and my wave dict. There are some pictures too with how the simulation had gone. I hope you guys enlight me, I'm a little desesperate. Thank you. https://drive.google.com/drive/folde...cw?usp=sharing |
October 8, 2023, 15:10 |
#451 |
Biku
Rep Power: 4 |
I did some mistakes
October 17, 2023, 17:40 |
waveFloatingObject_dimensions
#452 |
Yiannis Kapa
I would be grateful if someone has some answers about the meshing with olaDyMflow, and specifically with floating object tutorial. I'm trying to enhance the dimensions of a 3D cubic floating mass, but after some enlargement in dynamicMeshDict.sixDoF file (Lx, Ly, Lz) the simulation doesn't start.
this is the message:-> FOAM FATAL IO ERROR: Failed wmake "dynamicCode/_7943fda7fcceb244a28b7ac8d2015c23de27c1e2/platforms/linux64GccDPInt64Opt/lib/libcodeStream_7943fda7fcceb244a28b7ac8d2015c23de27 c1e2.so" file: /home/johnkaz/olaFlow/tutorials/AQUABREAK/constant/dynamicMeshDict.sixDoFRigidBodyMotionCoeffs from line 25 to line 0. From function static void (* Foam::functionEntries::codeStream::getFunction(con st Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&) in file db/dictionary/functionEntries/codeStream/codeStream.C at line 218. FOAM exiting and that's my attempt: |
November 3, 2023, 00:49 |
OLAFLOW Download errors
#453 |
Hi, when I download OlaFlow I get the following errors
Making dependency list for source file waveFun.C Making dependency list for source file wavemakerMovement.C wmkdepend: parse error while scanning 'wavemakerMemberFun.H' ... perhaps missing a final newline . . . wmkdepend: could not open 'PointPatchFieldMapper.H' for source file ' wmkdepend: parse error while scanning 'classicWriting.H' ... perhaps missing a final newline In file included from overOlaDyMFlow.C:86:0: CorrectPhi.H:1:1: error: expected unqualified-id before ‘{’ token { ^ make[1]: *** [/opt/OpenFOAM/OpenFOAM-v2012/wmake/rules/General/transform:35: Make/linux64Gcc63DPInt32Opt/overOlaDyMFlow.o] Error 1 make[1]: Leaving directory '/mnt/c/Users/user/Desktop/OPEN/OpenFOAM/OpenFOAM-v2012/olaFlow/solvers/olaFlowOFv_com_latest/overOlaDyMFlow' make: *** [/opt/OpenFOAM/OpenFOAM-v2012/wmake/makefiles/apps:29: overOlaDyMFlow] Error 2 olaFlow solvers compilation failed Also when I try to run a tutorial case I get the following errors which I guess they arise from installation problems ./runCase: line 13: setOla: command not found Running... ./runCase: line 16: olaFlow: command not found Simulation complete. The download process I followed is the one described here https://olaflow.github.io/source-code/, with the olaFlow folder being downloaded inside my OpenFOAM-v2012 folder. Can you please help me resolve them? Many thanks in advance |
November 20, 2023, 10:31 |
floatingObject_mesh movement
#454 |
Kazakis Ioannis
Rep Power: 10 |
hello
I noticed that using olaflow and OFv1806, floatingObject patch doesn't follow mesh movement!? How is this possible? In version OF5x, everything is ok! Maybe it's something obvious, but I have stuck here. I would be grateful if someone provides me some help. Kind Regards Yiannis update I noticed that this is happening with openFoam.com versions!, not openFoam.org versions! openFoam.org versions seems to work Fine! What am i doing wrong? seems to be pretty confused! update2: this doesn't happen in of2006 and later. Maybe it was something like a bug. Last edited by Giannis_Kaz; November 30, 2023 at 16:00. |
November 27, 2023, 02:37 |
#455 |
Mehdi Badri
Rep Power: 13 |
Hi there,
On OF2112, I installed olaFlow using the provided scripts in the leading directory. I attempted to run the ''waveFloatingObject' tutorial, but in vain. I ran it as was; however, it diverged after t = 0.6 (delta t approaches zero). Could you please let me know if I should make any special considerations for my setup and installation? Also, I must mention that the "currentWaveFlume" tutorial works as intended. |
November 30, 2023, 15:56 |
#456 |
Kazakis Ioannis
Rep Power: 10 |
Dear Mehdi
I am facing a lot of same problems regarding the instability of the specific solver (inteDyMFoam) I manage to stabilize relative simulations but, there are plenty of "difficult points' which must be taking into account to simulate the dynamic Mesh. The source of the problem is the pressure instabilities that are making their presence as the simulation proceeds. To handle this in my opinion is first to study at the constraints/restraints in dynamicMeshDict, to choose properly your time step (preferable the NON adjustable time step), to chose carefully your geometry, (e.g. a box is not a hudrodynamically friendly object), and further more, try to use the overSet Mesh utility. if you have any update concerning the overSet please let me know as it is in my field of interest right now. Regards Yiannis |
December 12, 2023, 16:43 |
compilation error
#457 |
Olorunfemi Omonigbehin
Hello
So, I tried to compile the olaFlow solvers with the OpenFOAM-v2306 and I got the following errors: wmake overOlaDyMFlow make[1]: Entering directory '/home/omonifemi/olaFlow/solvers/olaFlowOFv_com_latest/overOlaDyMFlow' Making dependencies: overOlaDyMFlow.C wmkdepend: could not open 'interpolatedFaces.H' for source file 'overOlaDyMFlow.C': No such file or directory g++ -std=c++14 -m64 -pthread -DOPENFOAM=2306 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I. -I.. -I/usr/lib/openfoam/openfoam2306/src/finiteVolume/lnInclude -I/usr/lib/openfoam/openfoam2306/src/meshTools/lnInclude -I/usr/lib/openfoam/openfoam2306/src/sampling/lnInclude -I/usr/lib/openfoam/openfoam2306/src/transportModels/twoPhaseMixture/lnInclude -I/usr/lib/openfoam/openfoam2306/src/transportModels -I/usr/lib/openfoam/openfoam2306/src/transportModels/incompressible/lnInclude -I/usr/lib/openfoam/openfoam2306/src/transportModels/interfaceProperties/lnInclude -I/usr/lib/openfoam/openfoam2306/src/TurbulenceModels/turbulenceModels/lnInclude -I/usr/lib/openfoam/openfoam2306/src/TurbulenceModels/incompressible/lnInclude -I/usr/lib/openfoam/openfoam2306/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/usr/lib/openfoam/openfoam2306/src/dynamicMesh/lnInclude -I/usr/lib/openfoam/openfoam2306/src/dynamicFvMesh/lnInclude -I/usr/lib/openfoam/openfoam2306/applications/solvers/incompressible/pimpleFoam/overPimpleDyMFoam -I/usr/lib/openfoam/openfoam2306/src/overset/lnInclude -iquote. -IlnInclude -I/usr/lib/openfoam/openfoam2306/src/OpenFOAM/lnInclude -I/usr/lib/openfoam/openfoam2306/src/OSspecific/POSIX/lnInclude -fPIC -c overOlaDyMFlow.C -o Make/linux64GccDPInt32Opt/overOlaDyMFlow.o In file included from overOlaDyMFlow.C:225: pEqn.H:13:18: fatal error: interpolatedFaces.H: No such file or directory 13 | #include "interpolatedFaces.H" | ^~~~~~~~~~~~~~~~~~~~~ compilation terminated. make[1]: *** [/usr/lib/openfoam/openfoam2306/wmake/rules/General/transform:38: Make/linux64GccDPInt32Opt/overOlaDyMFlow.o] Error 1 make[1]: Leaving directory '/home/omonifemi/olaFlow/solvers/olaFlowOFv_com_latest/overOlaDyMFlow' make: *** [/usr/lib/openfoam/openfoam2306/wmake/makefiles/apps:28: overOlaDyMFlow] Error 2 olaFlow solvers compilation failed Might anyone know where I am getting it wrong? Thank you. |
March 27, 2024, 00:59 |
Problems in force computation after rerunning the case in OpenFOAM 5.x
#458 |
Biku
Rep Power: 4 |
I use OpenFOAM 5.x for my simulations. My simulations stop after 3 days and I have to rerun the case to continue. I am using the OlaFlow module in openfoam based on interfoam which is used to simulate water waves. Whenever I resume the simulation from the decomposed case or reconstructing at latestTime and then decomposing and rerunning the case, my force computations (forces.dat) come out to be very weird and non physical. Has anyone faced and knows how to tackle this issue? Please help.
July 10, 2024, 02:57 |
#459 |
Nghiep
Rep Power: 4 |
Hi OMONIFEMI, Have you solved this problem? I am facing it
September 12, 2024, 11:47 |
compilation error solution
#460 | |
Hi there, I had a similar issue. It seems that this specific header was removed after v2206. To fix it I downloaded the file from https://develop.openfoam.com/Develop...?ref_type=tags Then I copied the file in the directory `<path-to-olaFlow>/olaFlow/solvers/olaFlowOFv_com_latest/overOlaDyMFlow`. This is a hack solution but it compiles and I was able to run the wavemakerFlume tutorial. |
olaflow, waves |
Divergence detected in AMG solver: k when udf loaded | google9002 | Fluent UDF and Scheme Programming | 3 | November 7, 2019 23:34 |
udf problem | jane | Fluent UDF and Scheme Programming | 37 | February 20, 2018 04:17 |
UDF velocity profile | willroca | Fluent UDF and Scheme Programming | 2 | January 10, 2016 03:13 |
Error messages | atg | enGrid | 7 | August 30, 2013 11:16 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
