April 10, 2022, 03:29 |
#401 |
Lolita
Rep Power: 10 |
April 14, 2022, 10:39 |
More details about olaFlow
#402 |
Tarek Hadj Hassen
Rep Power: 4 |
Hi Pablo,
Thanks for your excellent work. Thanks for sharing your knowledge with the CFD community. I am a master student in coastal and marine engineering and I am very keen on olaFlaw. When I read your phd thesis, there was some question.
Tarek |
April 25, 2022, 16:40 |
wavemakerMotionDict using tveta
#403 | |
Christopher Goody
Rep Power: 8 |
PIMPLE: iteration 1 Point displacement BC on patch inlet Initial water depth Paddle_inlet = 6.95758 [0] [0] [0] --> FOAM FATAL IO ERROR: (openfoam-2112) [0] incorrect first token, expected <int> or '(', found on line 3019: double 0.6787 [0] [0] [0] file: [1] [1] [1] --> FOAM FATAL IO ERROR: (openfoam-2112) [1] incorrect first token, expected <int> or '(', found on line 0: double 0.6787 [1] [1] [1] file: [2] [2] [2] --> FOAM FATAL IO ERROR: (openfoam-2112) [2] incorrect first token, expected <int> or '(', found on line 0: double 0.6787 [2] [2] [2] file: stream.paddleEta at line 0. Mahalo nui Chris |
April 25, 2022, 23:52 |
Problem Solved. Problem created.
#404 | ||
Christopher Goody
Rep Power: 8 |
Unfortunately, the results look nothing like what I expected. The input WSE amplitude range is on the order of +/- 1.5 m in 6.5 m depth, with velocities +/- 2-3 m/s, and within the first 10 s of the simulation, the water appears to just drain down to -6m at the inlet patch and never recovers, with no wave propagation. Hmmm. Does this effect sound familiar to anyone? A working tveta wavemaker tutorial case would be extremely useful if anyone has a simple one they could share.. I've attached my working case here, just to show the waveDict setup and the v and eta time series if anyone's interested. Mahalo Update: So interesting development - experimenting with different v and eta timeseries, even setting them all to zero, produces the same result. Which is water draining out through the inlet wave maker and no wave generation. This suggests that the tveta wavemaker (as I have it set up) is either not reading the data, or that it is simply not passed to the appropriate place. But since there are no errors generated at runtime, and it does complain if I format the time series incorrectly, it leads me to believe that it is reading the file, I'm just not getting it to the right place in the code. A little bit baffling. I must be missing something here... Update Update: Quote:
May 4, 2022, 05:53 |
overOlaDyMFlow
#405 |
ych
Rep Power: 4 |
Hello, I have a problem about overOlaDyMFlow now, could you please answer it for me?I have changed a case of overinterdydmfoam solver,but when I start to run it using overOlaDyMFlow solver,it did not work,and the terminal's information is that:
--> FOAM FATAL IO ERROR: (openfoam-2106) Cannot have both dictionary entry 'oversetInterpolationSuppresed' and 'oversetInterpolationRequired' for field cellMask file: /run/media/kemove/246ce341-170f-3c47-9bdc-a094e4bc81e5/olawavestokes2/ov/background/system/fvSchemes at line 19. From void Foam:versetFvPatchField<Type>::initEvaluate(Foam ::UPstream::commsTypes) [with Type = double] in file oversetPolyPatch/oversetFvPatchField.C at line 138. FOAM exiting |
May 6, 2022, 22:22 |
#406 |
Pablo Higuera
Rep Power: 19 |
Hi Tarek,
Since phases are random, iteratively means that the random phases are generated until the resulting sea state fulfills the quality control criteria and is close enough to what we were trying to obtain. All parameter are defined at the wave generation boundary. Any other model will do. Hi Chris, sorry for the late reply, too much work going on here. Glad to find out that you managed to solve the issue and you appreciate the static wavemaker BC! In later version it will be called timeSeries or something similar to avoid the confusion with the moving wavemaker. A quick note: generally setting the angle to anything above 360 will make olaFlow to calculate the correct perpendicular angle for you. This is the easiest and safest way, so if you try it and for any reason it does not work for any particular case just let me know. Hi ych, It does not seem related to olaFlow, since OpenFOAM is complaining of two conflicting options. Anyway: How to give enough info to get help Best, Pablo |
May 7, 2022, 05:13 |
overOlaDyMFlow
#407 | |
ych
Rep Power: 4 |
May 15, 2022, 09:12 |
#408 |
Pablo Higuera
Rep Power: 19 |
Hi ych,
I have never experienced such a thing except when I had set the BCs wrong. Please double check that all the BCs for all fields are right. If this does not fix it, it may as well be an issue with the overset method which, as far as I know (and if it has not been fixed yet), does not conserve mass; nevertheless, you should be able to play with the Courant number or with the numerical schemes to improve conservation. Best, Pablo |
May 15, 2022, 09:31 |
#409 | |
ych
Rep Power: 4 |
At first,thanks for your reply,and now I get an another question about setOla,I can use it successfully in olaflow and oladymflow,but when I use it in overOlaDyMFlow,it can't work,I find the log.setOla and I just find that Time=9,and nothing in it,so I want to know whether setOla can work in overOlaDyMFlow and oversetmesh,and my moving subject all is under the watersurface,I wonder if this will affect setOla's work. Looking forward to your reply, thanks again. |
May 16, 2022, 05:34 |
#410 |
Zheng Yuqian
Rep Power: 5 |
Hi Pablo,
I have done some great work with olaFlow and olaFlow is great. Now i am comfused that the gravity has to act in the negative direction of Z aixs? if I changed the direction of g to (0 -9.81 0),will olaflow still work correctly? |
May 17, 2022, 06:22 |
#411 |
Pablo Higuera
Rep Power: 19 |
Hi ych,
I have never used setOla with an overset mesh, so unfortunately I cannot offer any insights. Hi Yuqian, Gravity needs to act in the negative Z axis in order for olaFlow to work. If you change it to the negative Y direction, wave generation and absorption will not work. What you can do is use OpenFOAM's transformPoints utility to rotate your geometry, so that gravity points in the correct direction. Best, Pablo |
May 26, 2022, 05:39 |
#412 | |
Zheng Yuqian
Rep Power: 5 |
Now I have annother question.It seems that the Dev branch of olaFlow is not compatible with OF9 as I use "./allMake" following with some function‘s errors.Which version is Dev branch compatible with ? or I meet some unexpected mistakes? |
May 26, 2022, 11:52 |
#413 |
Pablo Higuera
Rep Power: 19 |
Hi Yuqian,
The Dev branch was added for OF7 / OF+20xx Full forward compatibility will happen when I release the new version of the code, for which I still have no fixed date. Best, Pablo |
June 23, 2022, 20:44 |
Missing Solver in dynamicMeshDict
#414 |
Justin Enjo
Rep Power: 10 |
Deleted message due to accidental double post. See post #415
Last edited by jenjo7873; June 24, 2022 at 15:05. Reason: Deleted message due to accidental double post. See post #415 |
June 23, 2022, 20:58 |
Solver missing in dynamicMeshDict
#415 |
Justin Enjo
Rep Power: 10 |
Hi all - Back into OlaFlow after a few years out. I'm running OlaFlow on Ubuntu 22.04 with OpenFoam 9
All OpenFOAM tutorials works. Most OlaFlow tutorials work expect those that use a dynamic mesh. I am trying to run the tutorial wavemakerTank with runParallelCasePiston. Here are lines 18-21 of dynamicMeshDict 18 dynamicFvMesh dynamicMotionSolverFvMesh; 19 motionSolverLibs ("libfvMotionSolvers.so"); 20 21 solver displacementLaplacian; Here is the error from olaFlow.log: Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh [0] [0] [0] --> FOAM FATAL IO ERROR: [0] keyword motionSolver is undefined in dictionary "/home/len/OpenFOAM/len-9/run/wavemakerTank/constant/dynamicMeshDict" [0] [0] file: /home/len/OpenFOAM/len-9/run/wavemakerTank/constant/dynamicMeshDict from line 18 to line [1] [1] [1] --> FOAM FATAL IO ERROR: [1] keyword motionSolver is undefined in dictionary "IOstream" [1] [1] file: IOstream from line 0 to line 0. [1] [1] From function T Foam::dictionary::lookup(const Foam::word&, bool, bool) const [with T = Foam::word] [1] in file /home/ubuntu/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/dictionaryTemplates.C at line 43. [1] FOAM parallel run exiting Does anyone have any experience with this error? It looks like a path to a library is incorrect, or maybe i need to call some additional libraries in controlDict? Please let me know. thanks, -Justin Last edited by jenjo7873; June 23, 2022 at 21:07. Reason: updated OpenFOAM version |
June 23, 2022, 21:05 |
First Peak Project & OlaFlow
#416 |
Justin Enjo
Rep Power: 10 |
Just for fun, here's a link to a model run and a video we did a few years ago. Using OlaFlow with dynamic piston. The model was low resolution but we plan on making some higher resolution runs soon.
enjoy! https://www.instagram.com/p/CS0u6a9H1V3/ more info about the project on www.firstpeak.org |
June 24, 2022, 16:23 |
#417 |
Justin Enjo
Rep Power: 10 |
Regarding Post #415
Figured it out. Changed dynamicMeshDict Line 21 from "solver" to "motionSolver" It's been a while. Last edited by jenjo7873; July 1, 2022 at 08:56. Reason: Linking to original post #415 |
June 30, 2022, 11:46 |
Reducing OlaFlow runs storage requirements with NO_WRITE
#418 |
Justin Enjo
Rep Power: 10 |
Hello fellow OlaFlow'ers
I need some help reducing the storage requirements for OlaFlow runs. I only need alpha.water and U for my analysis. Therefore I would like to reduce my cases. It is easy to recursively delete p, p_rgh for example, and other unused variables AFTER the model run using bash script. However, I would like to prevent these variables from being written. I've recompiled the olaFlow code by changing various IOobject calls to "NO_WRITE". For example, in createFields.H LINE 14 I've changed IOobject::NO_WRITE for p_rgh, therefore p_rgh will not write to disk, greatly saving storage space. I've done this for as many variables as I could find in various .C and .H files, but I cannot find the write functions in the source code for the following variables (using OlaDyMFlow): alphaPhi0.water alpha.water.org cellDisplacement meshPhi phi pointDisplacement Uf Can anyone help me find where these variables are written in the source code? |
July 1, 2022, 09:09 |
#419 |
Pablo Higuera
Rep Power: 19 |
Hi Justin,
I wouldn't necessarily recommend stopping the program from outputting the fields, because if the simulation blows up you cannot restart it and you would need to run the whole simulation again from the beginning with different parameters. Here are a couple of strategies that can help you: - Compress the fields or use binary format. You can set these flags in controlDict (writeFormat binary; compression on; ). - Reduce the number of time steps saved by increasing writeInterval. You can still sample the variables of interest at particular locations at a high frequency (basically all time steps). - Write a small bash/python script to erase the fields that you don't want. I would program it in a way to just delete files from the penultimate time folder, every time it detects that a new one has been created. There is another option, which may not be helpful for you directly: - Use purgeWrite to select the number of latest time step snapshots that you want to keep. Older ones will be erased during the simulation. You could couple this one with a runtime function to store the fields of interest in vtk files (sounds feasible, but don't really know if this is available). Best, Pablo |
July 2, 2022, 01:48 |
An error is output when running the tutorial 'baseWaveFlumeNewAbs' in Ubuntu 20.04
#420 |
Peicen Wang
Rep Power: 5 |
Hello Pablo,
I've tried to run the tutorial case 'baseWaveFlumeNewAbs' from 'Dev' branch. I've not change anything of this tutorial case, and only run the './runCase' script. When this script execute the line 'olaFlow > olaFlow.log', the terminal outputs some errors, and olaFlow couldn't work well: Code:
Preparing 0 folder... Setting the fields... Running... munmap_chunk(): invalid pointer ./runCase: line 16: 37408 Aborted (core dumped) olaFlow > olaFlow.log Simulation complete. Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _7bdb509494-20201222 OPENFOAM=2012 patch=210414 Arch : "LSB;label=32;scalar=64" Exec : olaFlow Date : Jul 02 2022 Time : 11:57:48 Host : hpws13 PID : 37453 I/O : uncollated Case : /home/wpc/wpcdata/olaFlowTutorials/baseWaveFlumeNewAbs nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From static Foam::IOstreamOption::compressionType Foam::IOstreamOption::compressionEnum(const Foam::word&, Foam::IOstreamOption::compressionType) in file db/IOstreams/IOstreams/IOstreamOption.C at line 115 Unknown compression specifier 'uncompressed', using compression off Create mesh for time = 0 Selecting dynamicFvMesh staticFvMesh PIMPLE: Operating solver in PISO mode Reading field porosityIndex Porosity NOT activated Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Selecting laminar stress model Stokes Reading g Reading hRef Calculating field g.h No MRF models present No finite volume options present DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 Courant Number mean: 0 max: 0 Starting time loop Courant Number mean: 0 max: 0 Interface Courant Number mean: 0 max: 0 deltaT = 0.00119048 Time = 0.00119048 PIMPLE: iteration 1 MULES: Solving for alpha.water alpha.water BC on patch inlet Wave Generation BC Wave theory: cnoidal H: 0.1 T: 3 h: 0.4 L: 6.0043 m parameter: 0.9771 Direction: 0? Phase-1 volume fraction = 0.571429 Min(alpha.water) = 0 Max(alpha.water) = 1 alpha.water BC on patch inlet MULES: Solving for alpha.water alpha.water BC on patch inlet Phase-1 volume fraction = 0.571429 Min(alpha.water) = 0 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.00153011, No Iterations 1 time step continuity errors : sum local = 0.001208, global = -1.49667e-10, cumulative = -1.49667e-10 DICPCG: Solving for p_rgh, Initial residual = 0.000715141, Final residual = 2.98713e-05, No Iterations 16 Velocity BC on patch inlet Wave Generation BC Wave theory: cnoidal H: 0.1 T: 3 h: 0.4 L: 6.0043 m parameter: 0.9771 Direction: 0? Active wave absorption BC on patch outlet "Initial water depths for absorption" 1( 0.4 ) Selecting active wave absorption model extendedRangeAWA AWA model: patch outlet Theory: extendedRangeAWA Number of paddles: 1 Reference water depth: 1(0.4) Wave period: 3 Updating extendedRangeAWA absorption model for patch outlet munmap_chunk(): invalid pointer Aborted (core dumped) Then I tested the tutorial 'baseWaveFlume' which was not using the extendedRangeAWA model in Ubuntu 20.04 system(OpenFOAM-v2012). And olaFlow worked very well. So I think there are no errors when I compiled the olaFlow codes. On July 1st, I tried the tutorial case 'baseWaveFlumeNewAbs' in other work station whose system version is CentOS 7.9.2009 (gcc version is 7.3.1) and OpenFOAM version is also v2012, and this tutorial runs very well. So I think there must be some difference between these work stations. This error confused me a few days. Is this something to do with the system version that I am using to run ? Hope for your answer. Thanks, Peicen P.S. Sorry for posting my question in your old thread(The OLAFOAM Thread). Please ignore it. :) |
olaflow, waves |
Divergence detected in AMG solver: k when udf loaded | google9002 | Fluent UDF and Scheme Programming | 3 | November 8, 2019 00:34 |
udf problem | jane | Fluent UDF and Scheme Programming | 37 | February 20, 2018 05:17 |
UDF velocity profile | willroca | Fluent UDF and Scheme Programming | 2 | January 10, 2016 04:13 |
Error messages | atg | enGrid | 7 | August 30, 2013 12:16 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 15:37 |
