January 7, 2022, 12:26 |
#381 |
Lolita
Rep Power: 10 |
hi Pablo,
Thanks for this wonderful solver, i was wondering if it also be incorporated for icoReactingMultiphaseInterFoam in openFoam2106. regards |
February 8, 2022, 05:54 |
Extended Range Active Wave Absorption
#382 |
Ernane Silva
Hello!
I followed the instructions to add the Extended Range Active Wave Absorption to olaFlow (https://olaflow.github.io/blog/new-b...ed-to-olaflow/) but it keeps not recognizing the waveAbsorptionVelocity boundary condition. It seems the OlaFlow project wave generation boundary conditions compilation failed after following the commands: git checkout git pull git checkout Dev Then I started everything from scratch. I downloaded olaflow and compiled it again. It worked perfectly. Then, the three git commands aforementioned and ./allmake. This resulted the same message "OlaFlow project wave generation boundary conditions compilation failed" and when I run the simulation: [2] --> FOAM FATAL IO ERROR: [2] Unknown patchField type waveAbsorptionVelocity for patch type patch Does anyone have an idea of the problem? I am using OpenFOAM 9. Best regards, Ernane Last edited by ernanesilva; February 9, 2022 at 05:07. |
February 9, 2022, 05:15 |
#383 |
Pablo Higuera
Rep Power: 19 |
Hi All, I am just back from vacation. Let's clear the backlog
Hi Philip (Dec 1), No idea. Perhaps that this may be an issue with your line coinciding with the side faces of cells? Anyway, I wouldn't use nPoints parameter but use the lineCellFace type sampling. See the breakwater tutorial for an example. Hi Haoran (Dec 5), - Yes, if you program a BC to prescribe the flux (based on pressure drop or something else) it should work. - I would suggest editing the coupling tool to handle the coordinate transformation, since gravity pointing in the -Z direction in olaFlow is a must. Hi Felix (Dec 14, 21), Quite an extreme example, but Niels is completely right. Yes, the solution will be wrong because the wavelength computed and used in the calculations is also wrong, as it has not converged yet. A quick fix would be to change 100 into, say, 1 million. This may be overkill, but the performance of the solver will not be compromised, since this is only calculated once in the simulation and the loop is extremely fast to compute anyway. Hi rupak504 (Jan 7), I currently have no plans to port olaFlow to icoReactingMultiphaseInterFoam, but it works with multiphaseInterFoam under certain conditions, so perhaps you should try. You can check it out here: https://github.com/phicau/olaFlow_su...phaseInterFoam Hi Ernane, Unfortunately I have had no time to test/adapt the Dev branch to work with OpenFOAM 9 yet, so I presume that there might be a problem with the compilation of the BCs to start with. It shouldn't be too difficult to modify it following the steps that I have been performing in the master branch, though. Nevertheless, this will definitely be solved in the new release, but it is taking longer than I expected and cannot currently offer a tentative release date. Best, Pablo |
February 9, 2022, 05:28 |
#384 |
Ernane Silva
Hello Pablo!
Welcome back and thanks for the reply. Which is the most recent version of OpenFOAM the Dev branch should work fine? Best regards, Ernane |
February 10, 2022, 03:17 |
corrABSfactor
#385 |
Felix S.
Rep Power: 6 |
Hello Pablo!
Thanks for the clarification on the wave length! I have been able to fix that! I have yet another question regarding the implementation. The correctional velocity in the waveVelocityFvPatchVectorField.C-file (https://github.com/phicau/olaFlow/tr...n/waveVelocity; line 710 and 728) is multiplied with a corrABSfactor, which is just the ratio of the calculated water level and the measured water level or vice versa. In contrast to that does the code of IHFoam (waveModel.C) in the standard OpenFOAM implementation not use this factor (https://develop.openfoam.com/Develop...dels/waveModel; line 390). What is the explanation of this implementation? As I cannot find this factor in the paper from 2013 (http://dx.doi.org/10.1016/j.coastaleng.2012.07.002). Thank you in advance for helping me understand! Have a nice day, Felix |
February 10, 2022, 06:15 |
#386 |
philip lu
Rep Power: 7 |
Hello, Phicau,
many thanks for the reply: I made another try, then it worked, but no idea why anyway, great to see you again. though late, but still Happy New Year to you philip |
February 11, 2022, 05:00 |
#387 |
Pablo Higuera
Rep Power: 19 |
Hi Ernane,
I believe the latest supported version in the Dev branch at this point is OF6 Hi Felix, this is a correction factor that I have found to work very well to reduce the reflection, especially for irregular wave simulations. It is a tuning factor acting on the input and output absorption velocities, useful when very high crests or deep troughs reach the absorption boundary. Best, Pablo |
February 11, 2022, 05:14 |
#388 |
Felix S.
Rep Power: 6 |
Hey Pablo,
thanks for the clarification! I was just confused why both implementations had different velocity corrections. Have a nice day, Felix |
February 16, 2022, 06:56 |
#389 |
Callum Guy
Rep Power: 6 |
Hi All,
quick question, how is everyone tracking wave height? I'm looking to process wave height during runTime, but I'm getting some strange outputs. See this post: runTime processing of water level (wave height) Be interested to hear everyone else's thoughts! Cheers, Callum |
March 6, 2022, 07:00 |
#390 |
philip lu
Rep Power: 7 |
Hello, Phicau,
I tried the ola-tutorial in the turbulence modules, except with irregular waves (general wave steepness is checked) and bit mesh-refinement than your org Both kOmegaSSTstable, kOmegaSSTbouyancy gave bit "backward breaking" immediately after inlet-patch (instead of breaking toward outlet-dir) By your experience, it's permissible or still possible to mitigate such early backward breaking? thank you in advance and also thank you for sharing us the excellent but easy2use tools philip @CallumG: hello CallumG, in ola-pkg, Phicau offered tutorial of tracing wave height, you can have a look |
March 15, 2022, 10:09 |
#391 |
Pablo Higuera
Rep Power: 19 |
Hi Philip,
Generally turbulence models are reported to induce wave breaking slightly earlier than expected, but I have never experienced them producing breaking at the wave generation boundary on their own. This phenomenon usually occurs when waves are "too" steep to simulate with a fixed boundary wave generation BC and is a known limitation in case the waves are not too steep to break in nature. Early breaking or back-breaking will normally compromise all further results. To simulate such conditions using a relaxation zone may be a solution. Best, Pablo |
March 16, 2022, 04:49 |
#392 |
philip lu
Rep Power: 7 |
Hello, Phicau,
thank you for the reply. Assuming, your advice doesn't imply me to "leave", as "ER-AWA + relaxationZone" not published yet, so I'll first try to fix it inside ola, especially besides easy2use, I never encountered "core dumped" in ola. Btw. ER-AWA needs T-input, in irregular waves can I use Tp for wavePeriod? To save your time, pls. don't reply if I'm right. thank you again for the info and ola-tools philip |
March 25, 2022, 21:39 |
PSA for Mac users and olaFlow
#393 |
Christopher Goody
Rep Power: 8 |
Aloha-
It looked like there were maybe a few other unicorns out there that were trying to compile OlaFlow on Mac OS, so just thought I'd post this fix for everyone that is. The clang compiler throws ambiguity errors for some of the temp variables on the original code. This tweak fixed those errors and compiled successfully on Mac OS Monterey 12.2.1 using OpenFOAM-v2112. It may not be (likely is not) the cleanest or best way to make it compatible, but it does the trick. Should be easy to adapt for other versions, and I think this is good for v19xx and up on the ESI branch. I tested it on a couple of the provided tutorials and it worked fine. Just expand the attached *.tar.gz and merge with the source code from https://github.com/phicau/olaFlow. BTW, thank you Pablo. Really like OlaFlow, its such a great utility. Mahalo Chris |
March 29, 2022, 13:28 |
Running opposing waves in the Wave Flume
#394 |
Callum Guy
Rep Power: 6 |
Hi Pablo,
I hope you are well! I'm currently using the wave flume example you helped me to code in the shear profile for, and I'm interested in reversing the wave direction such that the current runs left to right say, and the waves run right to left. Could you help me understand the easiest way of implementing this? I naively expected that setting waveDir to 180 would suffice! As always, I appreciate any help you can give! All the best, Callum |
March 29, 2022, 19:55 |
#395 |
Pablo Higuera
Rep Power: 19 |
Thanks a lot Chris! I have included your post in the olaFlow Github so that it is easier to find for the users https://github.com/phicau/olaFlow/wiki
Hi Callum, the oppositeSolitariesFlume tutorial in olaFlow shows you how to run waves in the negative x direction and currentWaveFlume how to run currents in either direction. If this does still not help feel free to send me an email. Pablo |
April 6, 2022, 08:42 |
#396 | |
Lolita
Rep Power: 10 |
Thanks for the suggestion ! One more question i wanted to ask is, does the code works fine with AMR? I tried this with adaptive mesh refinement, and straightway it gives error, while without it, it is running fine What do you think the problem is? regards |
April 7, 2022, 22:23 |
Wave buoy data to drive generator boundary
#397 |
Christopher Goody
Rep Power: 8 |
Aloha,
Curious to know if anyone out there has successfully utilized wave buoy or probe time series data to drive a CFD wave generation boundary either through OlaFlow or other? For example, if one has a time series record of eta (free surface elevation) and u (velocity in the axis of propagation at the free surface, if they've been able to use the wave maker code to replicate those waves in a model? It seems like there should be a way to utilize the flapWaveGen.py script to generate the appropriate wavemakerMovement.txt input file.. if I figure it out, will post the method here. Mahalo Chris |
April 8, 2022, 19:15 |
How to draw the power spectrum density from time series ?
#398 |
Tarek Hadj Hassen
Rep Power: 4 |
Hi All,
I try to draw the spectral density of a time series in order to compare it with the JONSWAP spectrum. The problem is the density value calculated by this script was divided by 1000. Please can anyone check the script ? Code:
#FFT Analysis time=elevation[200:11070,0] H=elevation[200:11070,1] tfd=np.fft.fft(H) fft_freq=np.fft.fftfreq(N,time[1]-time[0]) #Power spectral density PSD=tfd * np.conj(tfd)/np.square(N) plt.plot(fft_freq,PSD) plt.xlim(0,0.4) #plt.title('spectral density') plt.xlabel('frequency,f,[Hz]') plt.ylabel('Spectral density [m**2 s]') plt.show() Tarek |
April 8, 2022, 22:04 |
#399 |
Pablo Higuera
Rep Power: 19 |
Hi rupak504,
Yes, Adaptive Mesh Refinement should work. How to give enough info to get help Hi Chris, Yes, I have done that often. If waves are irregular I calculate FFT and feed the components (amplitude, frequency and phase) to the irregular wave module. If waves are regular and still clean at that location I often go for the expected regular wave theory for the given wave conditions. If waves are close to shallow water conditions you can use the static wavemaker module, in which you feed a time series of free surface elevation directly, see the reference manual for a full description. Hi Tarek, I normally use Welch’s method. Nevertheless, your question is probably a better fit for StackOverflow. Best, Pablo |
April 9, 2022, 11:19 |
How can we generate an irregular wave
#400 |
Tarek Hadj Hassen
Rep Power: 4 |
Hi all,
I will generate an irregular wave. I have the type of spectrum (JONSWAP with y=1.1), Hs=3m and Ts=8s I use the formula in GODA 2000 to calculate the spectral density S(f). The irregular wave was a superposition of multi regular waves. To generate an irregular wave, I will have (H, T, phase) of each regular wave. From the formula of the spectral density, I can have T = 1/f, but I seek how to calculate H from S(f)? Can I choose a random phase for each regular wave ? Is the spectral density in the book of GODA 2000 mean power spectral density? or they are different. Best regard |
olaflow, waves |
Divergence detected in AMG solver: k when udf loaded | google9002 | Fluent UDF and Scheme Programming | 3 | November 7, 2019 23:34 |
udf problem | jane | Fluent UDF and Scheme Programming | 37 | February 20, 2018 04:17 |
UDF velocity profile | willroca | Fluent UDF and Scheme Programming | 2 | January 10, 2016 03:13 |
Error messages | atg | enGrid | 7 | August 30, 2013 11:16 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
