August 7, 2020, 08:36 |
#261 |
Haoran Zhou
Rep Power: 6 |
Hi Pablo,
Thanks for your quick reply and the answers are very helpful! Best regards, Stan |
August 7, 2020, 23:13 |
#262 |
Pablo Higuera
Rep Power: 19 |
Hi Tomás and Stan,
you are very welcome. I will be in touch with you Tomás about the courses, but right now all in person courses are paused because of the pandemic. Hi Paul, I downloaded the case and tried to run it on 2006 since I do not have 1906 installed. I faced multiple errors with the simulation and was not able to run it. If you convert it to 2006 I will be able to take a look at it and check whether the wavemaker movement (mesh deformation on the main mesh) is compatible with overset grids. Best, Pablo |
August 10, 2020, 10:10 |
#263 |
Paul Tournant
Rep Power: 7 |
Hi Pablo,
Thank you for your answer I adapted my case for OF-v2006, I have an error when I run the overOlaDyMFlow solver, I modified the createField.H file to avoid a problem with the cellmask, I don't know if it's a good idea, but after that the case run. I send you the createField.H file that I modified. Thank you very much again for your answer. Best regards, Paul |
August 26, 2020, 15:49 |
#264 |
Isnard Baptiste
Rep Power: 6 |
Hello everyone and hello Pablo.
I use the v2006 version of openfoam to simulate two floats without coupling between the two. I want to use the oversetMesh with 6DoFRigidBody and then the solver overOlaDyMFlow. My simulation simulates about 8s then it crashes because the number of current diverges and I don't understand why. On these first 8 seconds the two floats follow the movement of the waves as desired. I noticed that it is when the first waves reach the outlet that the simulation crashes. So I don't know if this is a bug of olaFlow or me setting my simulation wrong. I have a big doubt about my dynamicMeshDict settings. I use the following commands: blockMesh snappyHexMesh -overwrite mergeMeshes . ../sphere1 -overwrite mergeMeshes . ../sphere2 -overwrite checkMesh setFields overOlaDyMFlow I hope that someone will be able to help me because I don't understand this discrepancy which is also present when I simulate with a finer mesh. Thank you in advance for your answers. the log during the simulation. Code:
Courant Number mean: 0.010681 max: 0.893793 Interface Courant Number mean: 0.00098299 max: 0.893793 deltaT = 0.00501741 Time = 7.12958 PIMPLE: iteration 1 forces forces: rho: rho Not including porosity effects 6-DoF rigid body motion Centre of rotation: (0 0 -0.195241) Centre of mass: (0 0 -0.195241) Orientation: (0.955012 0 -0.296566 0 1 0 0.296566 0 0.955012) Linear velocity: (-0 -0 -0.539762) Angular velocity: (0 -0.325654 0) forces forces: rho: rho Not including porosity effects 6-DoF rigid body motion Centre of rotation: (5 0 -0.131994) Centre of mass: (5 0 -0.131994) Orientation: (0.999527 0 -0.0307501 0 1 0 0.0307501 0 0.999527) Linear velocity: (0 0 0.366372) Angular velocity: (0 0.00937305 0) DICPCG: Solving for cellDisplacementx, Initial residual = 0.00257129, Final residual = 7.95348e-07, No Iterations 22 DICPCG: Solving for cellDisplacementy, Initial residual = 0, Final residual = 0, No Iterations 0 DICPCG: Solving for cellDisplacementz, Initial residual = 0.00650337, Final residual = 8.19429e-07, No Iterations 49 inverseDistance : detected 3 mesh regions zone:0 nCells:384840 voxels:(37 37 37) bb:(-5.00001 -2.00001 -5.00001) (5.00001 1.13441e-05 -0.0312387) zone:1 nCells:23788 voxels:(37 37 37) bb:(-1.00138 -1.00022 -1.20262) (1.00736 0.000117241 -0.153443) zone:2 nCells:23788 voxels:(37 37 37) bb:(3.99998 -1.00022 -1.1328) (4.80121 0.000116424 -0.132273) Overset analysis : nCells : 432416 calculated : 427058 interpolated : 4815 (interpolated from local:3819 mixed local/remote:730 remote:266) hole : 543 Velocity BC on patch inlet 3D_2D Absorption BC on patch outlet "Correction Levels" 1( -0.00767497 ) Execution time for mesh.update() = 2.51 s alpha.water BC on patch inlet smoothSolver: Solving for alpha.water, Initial residual = 0.000186063, Final residual = 5.0477e-11, No Iterations 3 Phase-1 volume fraction = 0.668349 Min(alpha.water) = -3.20914e-22 Max(alpha.water) = 1.00375 Applying the previous iteration compression flux MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet Phase-1 volume fraction = 0.668349 Min(alpha.water) = -1.03065e-22 Max(alpha.water) = 1.0035 Velocity BC on patch inlet 3D_2D Absorption BC on patch outlet "Correction Levels" 1( -0.00751351 ) DILUPBiCGStab: Solving for p_rgh, Initial residual = 0.00802394, Final residual = 7.45258e-05, No Iterations 15 time step continuity errors : sum local = 4.06803e-07, global = 2.30936e-07, cumulative = 4.49936e-05 DILUPBiCGStab: Solving for p_rgh, Initial residual = 0.000515334, Final residual = 3.88385e-08, No Iterations 95 Velocity BC on patch inlet 3D_2D Absorption BC on patch outlet "Correction Levels" 1( -0.00751351 ) time step continuity errors : sum local = 1.93763e-10, global = 8.17697e-11, cumulative = 4.49936e-05 PIMPLE: iteration 2 alpha.water BC on patch inlet smoothSolver: Solving for alpha.water, Initial residual = 0.000114652, Final residual = 3.97672e-11, No Iterations 3 Phase-1 volume fraction = 0.668348 Min(alpha.water) = -1.03065e-22 Max(alpha.water) = 1 Applying the previous iteration compression flux MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet Phase-1 volume fraction = 0.668348 Min(alpha.water) = -8.33406e-21 Max(alpha.water) = 1 Velocity BC on patch inlet 3D_2D Absorption BC on patch outlet "Correction Levels" 1( -0.00751389 ) DILUPBiCGStab: Solving for p_rgh, Initial residual = 0.00518126, Final residual = 5.1289e-05, No Iterations 27 time step continuity errors : sum local = 4.55422e-07, global = -3.55904e-07, cumulative = 4.46377e-05 DILUPBiCGStab: Solving for p_rgh, Initial residual = 0.000449179, Final residual = 9.08005e-08, No Iterations 90 Velocity BC on patch inlet 3D_2D Absorption BC on patch outlet "Correction Levels" 1( -0.00751389 ) time step continuity errors : sum local = 9.30491e-10, global = -4.75737e-10, cumulative = 4.46373e-05 smoothSolver: Solving for omega, Initial residual = 0.000200486, Final residual = 2.84176e-09, No Iterations 3 smoothSolver: Solving for k, Initial residual = 0.000921427, Final residual = 4.49709e-08, No Iterations 3 ExecutionTime = 12010.1 s ClockTime = 12038 s Courant Number mean: 0.0106844 max: 0.854315 Interface Courant Number mean: 0.000979434 max: 0.854315 deltaT = 0.00523556 Time = 7.13482 PIMPLE: iteration 1 forces forces: rho: rho Not including porosity effects 6-DoF rigid body motion Centre of rotation: (0 0 -0.198009) Centre of mass: (0 0 -0.198009) Orientation: (0.954506 0 -0.298193 0 1 0 0.298193 0 0.954506) Linear velocity: (-0 -0 -0.517473) Angular velocity: (0 -0.325108 0) forces forces: rho: rho Not including porosity effects 6-DoF rigid body motion Centre of rotation: (5 0 -0.130057) Centre of mass: (5 0 -0.130057) Orientation: (0.999529 0 -0.0307002 0 1 0 0.0307002 0 0.999529) Linear velocity: (0 0 0.373639) Angular velocity: (0 0.00970519 0) DICPCG: Solving for cellDisplacementx, Initial residual = 0.00266548, Final residual = 8.28228e-07, No Iterations 22 DICPCG: Solving for cellDisplacementy, Initial residual = 0, Final residual = 0, No Iterations 0 DICPCG: Solving for cellDisplacementz, Initial residual = 0.00666075, Final residual = 8.42939e-07, No Iterations 49 inverseDistance : detected 3 mesh regions zone:0 nCells:384840 voxels:(37 37 37) bb:(-5.00001 -2.00001 -5.00001) (5.00001 1.13441e-05 -0.0312387) zone:1 nCells:23788 voxels:(37 37 37) bb:(-1.0014 -1.00022 -1.20543) (1.00741 0.000117241 -0.155846) zone:2 nCells:23788 voxels:(37 37 37) bb:(3.99998 -1.00022 -1.13086) (4.80121 0.000116424 -0.130336) Overset analysis : nCells : 432416 calculated : 427058 interpolated : 4815 (interpolated from local:3821 mixed local/remote:728 remote:266) hole : 543 Velocity BC on patch inlet 3D_2D Absorption BC on patch outlet "Correction Levels" 1( -0.00751389 ) Execution time for mesh.update() = 2.38 s alpha.water BC on patch inlet smoothSolver: Solving for alpha.water, Initial residual = 0.000194079, Final residual = 5.73563e-11, No Iterations 3 Phase-1 volume fraction = 0.668378 Min(alpha.water) = -8.33406e-21 Max(alpha.water) = 1 Applying the previous iteration compression flux MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet Phase-1 volume fraction = 0.668378 Min(alpha.water) = -2.89421e-20 Max(alpha.water) = 1 Velocity BC on patch inlet 3D_2D Absorption BC on patch outlet "Correction Levels" 1( -0.00734289 ) DILUPBiCGStab: Solving for p_rgh, Initial residual = 0.00800932, Final residual = 5.59405e-05, No Iterations 31 time step continuity errors : sum local = 3.36135e-07, global = 3.17438e-07, cumulative = 4.49547e-05 DILUPBiCGStab: Solving for p_rgh, Initial residual = 0.000791277, Final residual = 9.99602e-08, No Iterations 88 Velocity BC on patch inlet 3D_2D Absorption BC on patch outlet "Correction Levels" 1( -0.00734289 ) time step continuity errors : sum local = 4.54526e-10, global = 3.75677e-10, cumulative = 4.49551e-05 PIMPLE: iteration 2 alpha.water BC on patch inlet smoothSolver: Solving for alpha.water, Initial residual = 0.000120128, Final residual = 4.38125e-11, No Iterations 3 Phase-1 volume fraction = 0.668376 Min(alpha.water) = -2.89421e-20 Max(alpha.water) = 1 Applying the previous iteration compression flux MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet Phase-1 volume fraction = 0.668376 Min(alpha.water) = 0 Max(alpha.water) = 1 Velocity BC on patch inlet 3D_2D Absorption BC on patch outlet "Correction Levels" 1( -0.00734335 ) DILUPBiCGStab: Solving for p_rgh, Initial residual = 0.00556939, Final residual = 5.31079e-05, No Iterations 37 time step continuity errors : sum local = 4.69313e-07, global = -3.942e-07, cumulative = 4.45609e-05 DILUPBiCGStab: Solving for p_rgh, Initial residual = 0.000432787, Final residual = 8.78947e-08, No Iterations 80 Velocity BC on patch inlet 3D_2D Absorption BC on patch outlet "Correction Levels" 1( -0.00734335 ) time step continuity errors : sum local = 1.13017e-09, global = -5.47563e-10, cumulative = 4.45603e-05 smoothSolver: Solving for omega, Initial residual = 0.000209942, Final residual = 3.35653e-09, No Iterations 3 smoothSolver: Solving for k, Initial residual = 0.000963983, Final residual = 5.32966e-08, No Iterations 3 ExecutionTime = 12022.6 s ClockTime = 12050 s Courant Number mean: 0.0111692 max: 0.819765 Interface Courant Number mean: 0.00102689 max: 0.792375 deltaT = 0.00575911 Time = 7.14058 PIMPLE: iteration 1 forces forces: rho: rho Not including porosity effects 6-DoF rigid body motion Centre of rotation: (0 0 -0.200916) Centre of mass: (0 0 -0.200916) Orientation: (0.953946 0 -0.299978 0 1 0 0.299978 0 0.953946) Linear velocity: (-0 -0 -0.492294) Angular velocity: (0 -0.324511 0) forces forces: rho: rho Not including porosity effects 6-DoF rigid body motion Centre of rotation: (5 0 -0.127882) Centre of mass: (5 0 -0.127882) Orientation: (0.99953 0 -0.0306433 0 1 0 0.0306433 0 0.99953) Linear velocity: (0 0 0.381572) the log before the Crash. Code:
Courant Number mean: 9.61061e-05 max: 135.956 Interface Courant Number mean: 3.56171e-05 max: 47.2014 deltaT = 1.31232e-35 Time = 8.15117 PIMPLE: iteration 1 forces forces: rho: rho Not including porosity effects 6-DoF rigid body motion Centre of rotation: (0 0 0.0970353) Centre of mass: (0 0 0.0970353) Orientation: (0.790348 0 -0.612658 0 1 0 0.612658 0 0.790348) Linear velocity: (-0 -0 -1.94601e+12) Angular velocity: (0 6.86843e+09 0) forces forces: rho: rho Not including porosity effects 6-DoF rigid body motion Centre of rotation: (5 0 0.183756) Centre of mass: (5 0 0.183756) Orientation: (0.999365 0 -0.0356307 0 1 0 0.0356307 0 0.999365) Linear velocity: (0 0 7.92543e+08) Angular velocity: (0 -168651 0) DICPCG: Solving for cellDisplacementx, Initial residual = 0.0263145, Final residual = 9.61785e-07, No Iterations 41 DICPCG: Solving for cellDisplacementy, Initial residual = 0, Final residual = 0, No Iterations 0 DICPCG: Solving for cellDisplacementz, Initial residual = 0.00785397, Final residual = 9.42835e-07, No Iterations 37 inverseDistance : detected 3 mesh regions zone:0 nCells:384840 voxels:(37 37 37) bb:(-5.00001 -2.00001 -5.00001) (5.00001 1.13441e-05 -0.0312387) zone:1 nCells:23788 voxels:(37 37 37) bb:(-1.00668 -1.00022 -0.920245) (1.01723 0.000117288 0.209848) zone:2 nCells:23788 voxels:(37 37 37) bb:(3.99998 -1.00022 -0.81714) (4.80137 0.000116424 0.183429) Overset analysis : nCells : 432416 calculated : 427056 interpolated : 4816 (interpolated from local:3722 mixed local/remote:813 remote:281) hole : 544 Velocity BC on patch inlet 3D_2D Absorption BC on patch outlet "Correction Levels" 1( 0.0441978 ) Execution time for mesh.update() = 2.46 s alpha.water BC on patch inlet smoothSolver: Solving for alpha.water, Initial residual = 1.87093e-05, Final residual = 7.54055e-16, No Iterations 3 Phase-1 volume fraction = 0.664191 Min(alpha.water) = -592.027 Max(alpha.water) = 441.086 Applying the previous iteration compression flux MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet Phase-1 volume fraction = 0.664191 Min(alpha.water) = -591.819 Max(alpha.water) = 81.4569 Velocity BC on patch inlet 3D_2D Absorption BC on patch outlet "Correction Levels" 1( 0.0441978 ) DILUPBiCGStab: Solving for p_rgh, Initial residual = 0.737662, Final residual = 0.00720823, No Iterations 200 time step continuity errors : sum local = 1.2337e-23, global = 7.53078e-24, cumulative = 3.6607e-05 DILUPBiCGStab: Solving for p_rgh, Initial residual = 0.0102754, Final residual = 7.6213e-08, No Iterations 548 Velocity BC on patch inlet 3D_2D Absorption BC on patch outlet "Correction Levels" 1( 0.0441978 ) time step continuity errors : sum local = 1.19765e-26, global = -1.16671e-26, cumulative = 3.6607e-05 PIMPLE: iteration 2 alpha.water BC on patch inlet smoothSolver: Solving for alpha.water, Initial residual = 7.85003e-05, Final residual = 1.20071e-10, No Iterations 4 Phase-1 volume fraction = 0.664188 Min(alpha.water) = -4.92729e-54 Max(alpha.water) = 1.09933 Applying the previous iteration compression flux MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet MULES: Correcting alpha.water alpha.water BC on patch inlet Phase-1 volume fraction = 0.664188 Min(alpha.water) = -1.41717e-54 Max(alpha.water) = 1.01982 Velocity BC on patch inlet 3D_2D Absorption BC on patch outlet "Correction Levels" 1( 0.0441978 ) DILUPBiCGStab: Solving for p_rgh, Initial residual = 0.662083, Final residual = 0.00641316, No Iterations 269 time step continuity errors : sum local = 1.49182e-21, global = 1.43781e-22, cumulative = 3.6607e-05 DILUPBiCGStab: Solving for p_rgh, Initial residual = 0.146793, Final residual = 1.74675e-05, No Iterations 1000 Velocity BC on patch inlet 3D_2D Absorption BC on patch outlet "Correction Levels" 1( 0.0441978 ) time step continuity errors : sum local = 2.35761e-23, global = 2.10182e-23, cumulative = 3.6607e-05 smoothSolver: Solving for omega, Initial residual = 0.000228342, Final residual = 1.66199e-08, No Iterations 3 smoothSolver: Solving for k, Initial residual = 5.61889e-06, Final residual = 1.27576e-10, No Iterations 3 ExecutionTime = 15762.8 s ClockTime = 15800 s Courant Number mean: 0.000110915 max: 630.6 Interface Courant Number mean: 3.96238e-05 max: 630.6 deltaT = 1.87295e-38 Time = 8.15117 Baptiste |
September 2, 2020, 03:09 |
#265 |
Isnard Baptiste
Rep Power: 6 |
the problem with my simulation from the previous post is that my oversetMesh doesn't move uniformly and there is a mesh deformation inside de oversetPatch and and can't find the solution to have my overset mesh which move why my rigidBody. There is a solution? Thank you for your answers and have a nice day. Baptiste |
September 2, 2020, 05:08 |
#266 |
Pablo Higuera
Rep Power: 19 |
Hi Paul and Isnard,
sorry, this is a busy time with teaching in NZ, I will take a look at your cases. A quick question for you both, why are you interested in running the moving wavemaker? From my own experience the moving wavemaker is only necessary when you require very high fidelity with physical experiments, at the cost of being up to 40% slower due to the mesh deformation routines required. The coolness factor plays a role too, but apart from that you can get as good results and much faster with the static boundary wave generation. @All, An important announcement, the library of multiphase turbulent models for waves that I maintain aside from olaFlow is now fully compatible with OpenFOAM 8/dev and 2006+. Enjoy! https://github.com/phicau/olaFlow_su...enceMultiphase Best, Pablo |
September 2, 2020, 05:58 |
#267 |
Isnard Baptiste
Rep Power: 6 |
Thank you for your answer Pablo.
I'm just trying to simulate that to use 6DOFmotionSolver with more than one body. It's just a test for my next simulation which will be a simulation for a Naval company and I need to be precise. But here I just try to adapt the floattingBody tutorial for two bodies but I am completely stuck. I am therefore waiting for your help, which will undoubtedly be invaluable. Thanks in advance for your help. Baptiste |
September 3, 2020, 21:54 |
#268 |
Tomas Cuevas
Rep Power: 7 |
Pablo,
I found some time to come back to wave modelling with olaFlow. I'm running an irregular sea state on a wave flume, the mesh resolution and dimensions are the same you used in your paper: Enhancing active wave absorption in RANS models. The wave parameters are: Hm0 = 0.05, Tp = 3 and depth = 0.4. The wave components using a jonswsap spectrum and 512 frequencies. The case setup is attached. The significant wave height computed from the wave components is approx 0.05m. I'm using the function interfaceHeight to extract times series of the surface elevation 7.5, 8, and 9m away from the inlet. The results are quite different from the CB, see a figure attached. The significant wave height of the outputs is close to 0.024. In the three output points, Hs is similar. I've computed Hs as the average of the higher third peak to peak amplitudes. I don't know why my results are so different from the BC, any guidance you can give me will be very appreciated. Cheers Tomás |
September 9, 2020, 10:44 |
#269 | |
Paul Tournant
Rep Power: 7 |
Hi Pablo Good luck with your teaching. I decided to use this wave generation method because I am working on a WEC system close to a breackwater. The presence of the breackwater induces a strong reflection, which can go up to a reflection coefficient of 1. I understood that the wave generation method with a static boundary does not allow a suitable absorption of the waves in strong reflection. This is why I am interested in this method. During this time, I am working on another way to control the movement of the buoy using sliding interfaces as in the tutorial : "tutorials/multiphase/compressibleInterDyMFoam/laminar/sphereDrop" Thank you very much for you reply and your time, Have nice day Best regards, Paul |
September 10, 2020, 17:58 |
#270 |
Pablo Higuera
Rep Power: 19 |
Hi Paul,
whenever reflections and re-reflections are significant the system becomes quite chaotic fast, but the static boundary wave generation can have active wave absorption connected and handle even the most reflective cases (I have run standing wave cases without issues). You should try this approach before discarding it. In the end, if the waves are not very close to the deep water regime, the wave absorption will work just right. For the record, active wave absorption for the piston wavemaker is based on the same (shallow water wave) theory, and the absorption for the flap wavemaker has not been released yet. Best, Pablo |
September 12, 2020, 20:44 |
#271 |
Sergio Croquer
Rep Power: 15 |
Hello Pablo
Good to know that it works now with OF2006! Thanks for keeping the code up to date. I was not aware that there are training courses for olaFlow. I might be interested in that as well! Regards, |
October 13, 2020, 17:51 |
olaFlow installation failed
#272 |
Grivalszki Péter
Rep Power: 7 |
I can not install OlaFlow, it crashes with these errors: Code:
gpeter@DESKTOP-DKDTKSQ:~/olaFlow$ ./allMake wmake libso genAbs/waveGeneration ln: ./lnInclude Making dependency list for source file wavemakerMovement.C wmkdepend: parse error while scanning 'wavemakerMemberFun.H' ... perhaps missing a final newline wmkdepend: could not open 'PointPatchFieldMapper.H' for source file 'wavemakerMovement/wavemakerMovement.C': No such file or directory wmkdepend: parse error while scanning 'newWriting.H' ... perhaps missing a final newline wmkdepend: parse error while scanning 'classicWriting.H' ... perhaps missing a final newline Making dependency list for source file waveVelocityFvPatchVectorField.C wmkdepend: parse error while scanning 'memberFun.H' ... perhaps missing a final newline wmkdepend: parse error while scanning 'profileStokesI.H' ... perhaps missing a final newline wmkdepend: parse error while scanning 'profileStokesII.H' ... perhaps missing a final newline wmkdepend: parse error while scanning 'profileStokesIII.H' ... perhaps missing a final newline wmkdepend: parse error while scanning 'profileStreamFunction.H' ... perhaps missing a final newline wmkdepend: parse error while scanning 'newWriting.H' ... perhaps missing a final newline wmkdepend: parse error while scanning 'classicWriting.H' ... perhaps missing a final newline Making dependency list for source file waveAlphaFvPatchScalarField.C wmkdepend: parse error while scanning 'memberFun.H' ... perhaps missing a final newline wmkdepend: parse error while scanning 'newWriting.H' ... perhaps missing a final newline wmkdepend: parse error while scanning 'classicWriting.H' ... perhaps missing a final newline g++ -std=c++11 -m64 -pthread -DOPENFOAM=2006 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOFVERSION=2006 -DOFFLAVOUR=2 -I/home/gpeter/OpenFOAM/OpenFOAM-v2006/src/finiteVolume/lnInclude -I./waveVelocity/velProfiles -I../common -I../common/checks -I../common/calculateWaterLevel -iquote. -IlnInclude -I/home/gpeter/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude -I/home/gpeter/OpenFOAM/OpenFOAM-v2006/src/OSspecific/POSIX/lnInclude -fPIC -c waveAlpha/waveAlphaFvPatchScalarField.C -o Make/linux64Gcc63DPInt32Opt/waveAlpha/waveAlphaFvPatchScalarField.o In file included from /home/gpeter/OpenFOAM/ThirdParty-v2006/platforms/linux64/gcc-6.3.0/include/c++/6.3.0/x86_64-pc-linux-gnu/bits/c++config.h:507:0, from /home/gpeter/OpenFOAM/ThirdParty-v2006/platforms/linux64/gcc-6.3.0/include/c++/6.3.0/cstddef:49, from /home/gpeter/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude/Hasher.H:49, from /home/gpeter/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude/string.H:54, from /home/gpeter/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude/word.H:46, from /home/gpeter/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude/wordList.H:49, from /home/gpeter/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude/patchIdentifier.H:41, from /home/gpeter/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude/polyPatch.H:45, from /home/gpeter/OpenFOAM/OpenFOAM-v2006/src/finiteVolume/lnInclude/fvPatch.H:42, from /home/gpeter/OpenFOAM/OpenFOAM-v2006/src/finiteVolume/lnInclude/fvPatchField.H:50, from /home/gpeter/OpenFOAM/OpenFOAM-v2006/src/finiteVolume/lnInclude/fixedValueFvPatchField.H:59, from /home/gpeter/OpenFOAM/OpenFOAM-v2006/src/finiteVolume/lnInclude/fixedValueFvPatchFields.H:31, from waveAlpha/waveAlphaFvPatchScalarField.H:80, from waveAlpha/waveAlphaFvPatchScalarField.C:48: /home/gpeter/OpenFOAM/ThirdParty-v2006/platforms/linux64/gcc-6.3.0/include/c++/6.3.0/x86_64-pc-linux-gnu/bits/os_defines.h:39:22: fatal error: features.h: No such file or directory #include <features.h> ^ compilation terminated. make: *** [/home/gpeter/OpenFOAM/OpenFOAM-v2006/wmake/rules/General/transform:35: Make/linux64Gcc63DPInt32Opt/waveAlpha/waveAlphaFvPatchScalarField.o] Error 1 \n\nOlaFlow project wave generation boundary conditions compilation failed Thank you in advance! |
October 13, 2020, 21:15 |
#273 |
Pablo Higuera
Rep Power: 19 |
Hi Grivalszki,
this line over here: Code:
/home/gpeter/OpenFOAM/ThirdParty-v2006/platforms/linux64/gcc-6.3.0/include/c++/6.3.0/x86_64-pc-linux-gnu/bits/os_defines.h:39:22: fatal error: features.h: No such file or directory #include <features.h> I am not sure why this failed but depending on how you installed OpenFOAM the pre-compiled versions sometimes may work but present similar flaws when doing things out of the box. I suggest that you install by compiling the code yourself and if it still doesn't work after you can always open a thread in the installation subforum. Best, Pablo |
October 14, 2020, 13:34 |
#274 | |
Grivalszki Péter
Rep Power: 7 |
Hi! I reinstalled Ubuntu bash, OF v2006 (compiling the code myself), but still the same:
OlaFlow compiled successfully, but it came with several errors like i posted. Then I try a tutorial, and it comes with this: Quote:
October 14, 2020, 17:49 |
#275 |
Pablo Higuera
Rep Power: 19 |
Hi Peter,
this is a different error. The solution that I provided solved the previous error and now olaFlow has been compiled correctly. The new issue has to do with Python dependencies. To generate the movement of the flap wavemaker you need to have the Numpy package installed for your Python distribution. This is usually very easy and can be sorted out with a fast google search. Best, Pablo Last edited by Phicau; October 15, 2020 at 18:06. |
November 11, 2020, 20:13 |
#276 | |
wangyang
Rep Power: 7 |
Can you give me anything about the olaFlow training course? Thank you Yang Wang |
November 12, 2020, 15:31 |
#277 |
Pablo Higuera
Rep Power: 19 |
December 15, 2020, 21:58 |
Question about the 'useTransient' in createPorosity.H
#278 |
Haoran Zhou
Rep Power: 6 |
Hi Pablo,
I have a few questions while reading the file 'createPorosity.H' and 'UEqn.H'. 1) The default value of 'useTransient' is 'false'. Does it mean that the oscillation flow is not considered in porous media? And in what situations should we switch it to 'true'? 2) In 'UEqn.H', the momentum conservation equation includes the transient formulation '(1.0 + useTransMask * 7.5 / KCPorField)'. The KCPorField is equal to KC number which is set to 1.0 in default. The 'useTransMask' is given as 'if ( useTransient ) {useTransMask[item] = 1.0;}' which means 'useTransMask' is 1.0 while 'useTransient' is true. However, what is the value of 'useTransMask' when 'useTransient' is 'false' as default? Best regards, Stan |
January 16, 2021, 08:34 |
Different simulation results with the same initial conditions using olaFlow
#279 |
Haoran Zhou
Rep Power: 6 |
Hi Pablo,
These days I've been doing a simulation about a breakwater on the porous seabed using olaFlow. The schematic diagram of the numerical model is shown in the attachment. There are two kinds of porous media in the seabed and there are rubble mound in front of the breakwater. The turbulence model I chose was KEpsilon and the wave theory adopted was Stokes V. The number of mesh grids are about 1800000. My main focus of the simulation is the pressure or force on the breakwater. As the first simulation result is a bit lower than I expected, I ran a second case with the same mesh and initial conditions. The wave profile of the two cases is similar. However, the pressure at the same point on the breakwater is two times of the first case. I'm quite confused about this problem. Why could two cases with the same mesh and initial settings lead to different numerical results? Is the problem caused by the wrong choice of turbulence model? Or it is because the mesh near the breakwater is coarse which lead to the convergence of the wrong result? Thanks in advance! Sincerely, Stan Zhou Last edited by Stan Zhou; January 22, 2021 at 06:10. Reason: The attachment hasn't been uploaded |
January 25, 2021, 20:42 |
#280 |
Pablo Higuera
Rep Power: 19 |
Hi Stan,
1) You are right, 'useTransient' is false by default, therefore the oscillatory flow enhancement is disconnected. This is to allow using the porous media friction in cases such as the dam break tutorial included in olaFlow, in which the flow is not oscillatory. If can connected in cases in which you have oscillatory flow and you want to consider the turbulence enhancement created by the oscillatory flow. In that case you set 'useTransient' to true and you also need to provide the value for KC in the dictionary. 2) The default value of 'useTransMask' is 0, so it will have no effect if not intended to. Similarly, 'KC' default value is 1, to prevent dividing by 0, but that is irrelevant because 'useTransMask' is 0 already. 3) I suggest that you take a look here: How to give enough info to get help There are thousands of things that can contribute to getting unexpected values. I would suggest you starting with a simpler mesh/case to validate the case and select the porous media parameters. A quick sanity check is that the hydrostatic pressure is alright; if that is not the case you know you have probably done something wrong. Best, Pablo |
olaflow, waves |
Divergence detected in AMG solver: k when udf loaded | google9002 | Fluent UDF and Scheme Programming | 3 | November 7, 2019 23:34 |
udf problem | jane | Fluent UDF and Scheme Programming | 37 | February 20, 2018 04:17 |
UDF velocity profile | willroca | Fluent UDF and Scheme Programming | 2 | January 10, 2016 03:13 |
Error messages | atg | enGrid | 7 | August 30, 2013 11:16 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
