[Other] .STL face splitting tool
Old   December 6, 2017, 19:53
Default .STL face splitting tool
Chris L
vbchris is on a distinguished road
UPDATE 2: Now runs fast.
UPDATE 1: Made more verbose and significantly improved performance.
Hi all,
I hacked together a program that I use for splitting .STL files into different faces. I've seen a few threads on the forum that essentially have the same issue I had and would like to share this program for feedback.
If anyone knows of a better method please let me know!! This is the bane of my meshing existance.
There are a number of features that are in development but which are not currently included.
Objective:
Create a simple command line tool which automatically identifies faces in a .stl file and splits the solid into individual components.
Secondary objective, pre-process .STL file prior to use by snappyHexMesh to check for common quality issues, grid alignment with surfaces, water-tightness, etc.
How to:
Github link -> https://github.com/vbchrist/stlFaceFinder
Download stlFaceFinder.exe
Currently windows 32-bit only (which works on 64-bit too).
Use windows command promt to run from command line.
stlFaceFinder.exe [inputFile] [outputFile]
[inputFile] = either local file or complete file path (validation of file not done) [outputFile] = either local file or complete file path (will overwrite files without warning)
Example:
Download pipe.STL (from this repo) and place it in the directory of stlFaceFinder.exe. Open windows command promt or power shell. change directory to where stlFaceFinder.exe and pipe.stl are located.
Run the program using
stlFaceFinder.exe pipe.STL output.STL
The output should be,
C:\path\to\files> ./stlFaceFinder.exe wier.STL release.stl
Importing C:\path\to\files\wier.STL... Done.
6162 facets in file.
Generating edge list ... Sorting edges ... Done. (1.50148)
Matching facets ... Done.
Successfully matched 18486 of 18486 facet edges.
Doing setup ... Done.
Searching for surfaces ... Done.
Assigning new surfaces to STL solids ... Done.
Writing to C:\path\to\files\release.stl... Done.
vbchris is offline   Reply With Quote
Old   January 22, 2018, 19:12
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
I moved it to the contributors forum. However, is there a linux based version too?
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   March 27, 2018, 01:19
Lucky
I get the missing MSVCP140D.dll error.
However, I have tried MS VS C++ redist 2015 & 2017, x86 and x64 and it is not still not detected. Seems to be a build error.
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[ANSYS Meshing] Workbench Meshing Tool - Max Face Size Parameter MaxHeat ANSYS Meshing & Geometry 3 March 2, 2021 08:50
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 19:25
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
